Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By holdencple
  • 1 Post By oska
Thread: + VY Easier Way To Disable Traction Control (ETC)
    '04 VY2 SV8
    Oct 2009
    Default + VY Easier Way To Disable Traction Control (ETC)
    For those wanting to do it the easy way without unhooking the battery and fooling around with the ABS module then using electrical tape to seal it back up.
    here it is : located at the firewall passenger side is the traction control unit unplug the conector plug with the blue top, tie it off out of the way and your done,no traction control and easy to connect back up when needed :-)
    May not be usable on all Commodores :- this has been used on a 2001 VX Clubsport and a 2004 series 2 VY SV8 LS1 without any error codes coming up not sure what other models this will suit.
    Pretty sure your able to do this with all ls1 engines.
    refer to pictures attached.
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    I would suggest AGAINST doing it this way for anyone. Also, this is only for Gen 3 engines. For the only way Holden supports disabling ETC for the V6 and V8's refer to: + VY How to disable Traction Control (ETC)
    The connector pictured above is YE127. YE127 is the connector that connects the throttle relaxer to the Automatic Throttle Relaxer Module. This will not disable ETC properly, only knocks out the Automatic Throttle Relaxer motor. If it disables it it will be causing errors or the vehicle will be still retarding sparks but not having control over the throttle.
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    Vyss
    Jan 2011
    Darwin
    Default Hi
    Have been reading about disabling tc will try it
    Im also after info on my vy ss it has many options factory leather seats
    Extractors and i was trying to find out what sort
    Of kilowatt i would have
    vx custom 600RR
    Oct 2010
    i'm confused
    if you have traction control then you have the button yeah? is it so hard to just push the button after starting the car ?
    boomnvn's Avatar
    boomnvn is offline SOLDER, NO CRIMP.
    VT Exec S1 V6
    Oct 2006
    Croydon
    it's instead of having to push the button after starting the car each time.
    permanently disabled, until plugged back in.
    I would also prefer the single wire method, as if you're crafty enough, a relay and switch could be wired in as a traction control master switch.
    Cheers,
    Spudley.
    CAR: VT Commodore Sedan audio car - SOURCE: 7" double DIN DVD/GPS - AMP: Pioneer monoblock / Pioneer 4 ch. - SUB: Kenwood DB+ 12" in 22lt slot ported box - REARS: Kicker RS60.2 splits - FRONTS: Kenwood KFC-S702P splits - MISC: Custom fiberglass iPhone4 dock moulded in center console, White / red LED cluster and dash lighting, SAAS Vortex drivers seat
  1. [VT-VX] + VY How to disable Traction Control (ETC)
    By alien in forum Holden Commodore How-To's
    Last Post: 08-08-2011, 06:17 PM
  2. stability control...traction control???
    By m05tw4nt3d in forum VE Holden Commodore (2006 - ?)
    Last Post: 28-03-2011, 09:30 PM
  3. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  4. Traction control
    By Nathan72 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2006, 08:41 AM
  5. Traction control disable in VT2 SS
    By achimw in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2006, 11:22 PM
