GE4CE
- Aug 26, 2006
- 58
- 2
- 0
- Location
- Western Suburbs/Melbourne
- VT SS 5.7
Just fitted some VY sports pedals to my VT with info i got from Andyos
Thought i would put his original info up and add some photos and tips
Choose the pedals that will suit your application (Manaul or Auto)
The accelerator pedal is a bit tricky and easier to do if you remove the pedal assembly from the car.
You have to lay on your back and look right up the shaft of the accelerator pedal and you can see where the accelerator cable is clipped into a plastic clip.Just release it.
Then there are four bolts holding the pedal assembly into the car
The accelerator pedal is held on by a pin running through the pedal and through the middle of a spring.
Hold the assembly in a vice and knock out pin remembering which way the spring was sitting.
Fit new pedal put spring and pin back in and assemble back in car remembering to attach accelerator cable again
The foot rest is 2 10mm bolts remove,fit new footrest and tighten
(touch up bolts with matt black or similar)
The Brake pedal you just pull the rubber one off and fit the new one on.
Hope this helps others that want to try this
....................Cheers ..........GE4CE
