Results 1 to 2 of 2
Thread: How to Fix Steering Column Horn Contact VN Commodore
    Dec 2009
    Default How to Fix Steering Column Horn Contact VN Commodore
    If your horn stops working it may be a worn out spring loaded contact which is part of the upper bearing assembly on the steering column. To replace it with a new one requires a whole new upper bearing assembly.
    An easy fix is to remove the steering wheel and using a suitable soldering iron put a blob of solder on top of the work contact, do not overheat. Additionally a small brass nut can be soldered there if you want a harder surface. The solder blob should last for several years and can be reapplied easily when it wears out.
    1989 Vn Commodore Sedan
    Aug 2011
    south australia
    thanks for this tip, because my horn didnt work. I went out and brought myself a pair of air horns
    and the bloody thing still dont work followed the diagram so now i have two horns that dont work.
    Any help on this matter would be appreciated.
  1. steering column help!
    By Wadeo.. in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2008, 10:07 PM
  2. Steering column (with a twist)
    By stockhorse in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-11-2007, 10:29 PM
  3. vr steering column
    By 5Lvrss in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-03-2006, 06:47 PM
  4. VN horn contact removal
    By redcane in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-10-2004, 12:52 PM
