I just put in my Supercharged (L67) OTR (Over the Radiator) Cold Air Intake on my VS. Hope this guide is helpful to all those wanting to put this kit on their VR/VS.
Before I start I don't take responsibility for any damage caused by using this guide or related to using this guide. Use at your own risk.
What You Will Need
1. The Cold Air Intake kit (Available from Holden dealerships, Ebay etc etc)
2. 3Very short screws, probably 12mm
3. Hacksaw
4. Socket/Screwdriver Set
5. Power Drill with bit
6. Silicone (If needed)
Time = About 30 mins
Step 1: Remove the top of the airbox by undoing the 5 metal clips on the four edges of the box
Step 2: Remove your air filter panel by simply lifting up. This will show the empty bottom section of your airbox, with 3 screws (approx 10mm) holding the bottom box to the engine bay. Use your socket set (the smallest one you can find) to undo the nuts. If you don't have a socket set, just use a set of pliers or an appropriate sized wrench to loosen the nuts and then unscrew them using your fingers.
Step 3: Remove the tiny little stock pipe from the airbox (it should just pop out, if not just pull it hard and then put it in the bin...most worthless piece of equipment I have ever seen, amazing air even goes into it). Get your inlet pipe (the connector between OTR CAI manifold and the bottom section of the air box) and line it up to the bottom air box and using a Stanley Knife or Box Cutter, score the box to the appropriate size that will accomodate the new larger inlet.
Using your hacksaw, cut along the score lines and cut out the larger hole required.
Step 4: Attach the new inlet into the larger hole and silicone the gaps between the box and the inlet if required (if you cut the hole too large). Put the bottom section of the box back into the engine bay and put the screws back on. The end result should look like this:
Step 5: Line up your OTR CAI manifold on the top of the radiator, plug the inlet pipe into the manifold and see how it sits. It should sit flush, if it doesn't, play around with it because you have done something wrong.
Get your drill and drill through the little holes in the top of the manifold on the little plastic rims, aim for the middle of one of the side sections, it should go through the plastic lip on the top of the radiator and go down in the gap between the plastic and the radiator. When you feel the drill go through the bottom layer, stop and pull it back out. The hole is adequate. Do this to all 3 holes and then get your screws and screw them in. Like this:
Step 6: Make sure everything is sturdy. Stand back and admire how great the new OTR CAI looks than the old Radiator/Fan shroud. Take it for a test drive and see how it feels!
For the hacksaw bit if you dont wanna do that, you can buy the bottom part to suit from holden
this is betta than the other how-to on this cause it has picture
and how well does it go with the gas setup
Good write up mate, nice and easy to do and the pictures really help
MY VS - http://forums.justcommodores.com.au/...executive.html
You have a pussy, i have a dick, so whats the problem? Lets do it quick!!
will this work on a vn?
Good write up.
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
My VS II Berlina Wagon
MY12 II SV6 Sportwagon
Thanks a million mate, props to ya for photo's because it always helps out THAT much more! Highly appreciated! Got mine yesterday, will be throwing it on within the next half hour! =)
Yeah she drones... But do I give a F***? ...No!
Great tutorial. It helped alot :3 only took an hour to do.
Minus the running around to buy a hacksaw etc :P.
Here's the finished product.
I used 1"4 washers and spring washers to hold it into place.
