Results 1 to 4 of 4
Thread: Electric window maintenance
    VL Calais
    Feb 2010
    Default Electric window maintenance
    Hi All,
    Here's an idea to prevent horrible problems with the lecky windows in the future.
    As part of your beloved Commodore's regular maintenance try squirting a little Armoral into the window track. Open the window half way and slowly squirt Armoral into the groove that the window runs up and down in. Have a cloth handy to clean up any spillage.
    Operate the window (with the engine running to prevent battery drain) and you should notice a difference within a day or two. Armoral lubricates and softens vinyl and rubber surfaces reducing friction on window winder motors. Worked well on my VL Calais that had sat for ages prior to purchase.
    I have to repace Passenger and both rear door motors as a result of motor burn out. Common problem.
    I'll post an easy to follow guide on how to do this soon. (Rear doors are cabled and not looking forward to that!)
    Cheers.
    Pete
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    does it have to be armorall .. or will any silicone lubricant work? .. im guessing Inox and WD40 would suck as their oil-based and would get soaked up by the rubber?
    VY SS
    Jun 2006
    Albany
    VS V6 Commodore Acclaim
    Dec 2010
    Just a concern... how does this effect any window tinting??? I have old tinting which I'm not really worried about (since we do plan to replace it at some stage) but I will need to know for future reference as well as maintaining what we have for the moment...
  1. electric window problem
    By redcedar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-03-2011, 11:13 PM
  2. Electric window help please
    By LiamVK in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-02-2010, 04:09 PM
  3. F@#KED Electric Window
    By Tas_HSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2008, 06:22 PM
  4. Electric Window Switch
    By dathro in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-04-2008, 09:00 PM
  5. electric window button
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2007, 02:40 PM
