hi this has most likely been done before but i took some photo when i was fitting my towbar so i may as well share them. sorry about photos they are off my iphone the camera is so sh!t.
STEP 1: remove rear bumper
Attachment 88482
three Phillips head screws
four phillips head screws in the plastic so you can fold back carpet
four clips in bumper
two 10mm nut on each side under each tail light
STEP 2: remove support bar and brackets
remove the 4 bolts i think they are 17mm from memory
remove 19mm nuts to remove brackets
STEP 3: fit towbar
fit towbar and put nuts back on
STEP 4: install wiring loom and replace bumper bar
wiring loom plugs in on driver side under tail light, then you can put the rear bumper bar on and put the carpet back in the boot. hope this is a help to someone.
Does this apply to removing a towbar as well?
I have the actual bit(with the round chrome ball on top) which connects to the trailer off, however I still have this bit that seems to be bolted in just under the spare and covered in some yellowy glue or something.
I have the plastic cover for the exterior to cover the gap where this bit sticks out of, where the black plastic bit is..I'm sure you get the idea.
will a vy sedan towbar also suit a wagon?
^^^^ Yes wagon and sedans have the same ass end and mounting points
Hey Guys,you can fit a tow bar without taking the rear bumper off, just put one on my vx calais. its not easy but still better than removing the rear bumper.
Yeah, considering the bars virtually fall off just by yelling at them, i'd just take it off..
Hi, long time reader, first time poster...
aza03, thanks for the thread as I was thinking of DIY installing a towbar myself... In terms of the wiring loom, how do you run the wires from the rear of the vehicle to the bonnet? Is there a plug pre- mounted by Holden that you plug into or is it a complicated auto- electrical task? I have a S2 VY wagon.
Apologies for the stupid question...
Gi'day mate this is my first post reply so excuse me if its shabby...
the wiring for the trailer plug i dont know why you want to get the feeds from the bonnet?..
you can use one of the rear light clusters, you can get your earth, indicator, stop, tail and reverse lights. Its easy to do yourself, the pin number and wire colour is;
1. yellow - left indicator
2. black - aux
3. white - earth
4. green - right indicator
5. blue - aux
6. red - stop
7. brown - tail
That is guessing your going to get 7 seven pin plug,and no holden don't leave a plug there for you.
hope that helps
Thanks guys for the info
Great write up mate, I'm gonna use it to take mine off.
Does anyone know if I need to put the support bar and brackets back on after I've removed the tow bar? If so where can I get some from?
