Page 1 of 2 12 LastLast
Results 1 to 25 of 45
Like Tree6Likes
Thread: How To Install Cup Holders into VR VS
    VR Wagon
    Oct 2008
    Central Coast, NSW
    Default How To Install Cup Holders into VR VS
    I was sick of putting my drink in the compartment under the arm rest in the centre console, so i decided to put one in beside the hand brake, this is what i did.
    Yes i know afew of you have done stuff similar to this but thought i would post a how-to for those who haven't.
    You will need,
    Flat blade screw driver
    Philips Head screw driver
    Hair dryer or heat gun
    Cold water tap near by
    Cup Holder itself - Pic Below
    Adhesive - I used liquid Nails
    Plastic spray paint
    Hole Saw Bits
    This is the plumbing fitting i am going to be using, bought it from bunnings, cost $3 max, what ever you use make sure a drink fits in it, can etc, dont just guess.
    #1 Remove the Centre Console
    #2 Remove the Arm rest from the centre console, i only did this as it makes it easier to work on the console.
    #3 You need to remove the vents at the back of the console in order to take out the air ducting which runs up both sides of the console, once you have taken the vents out undo the 2 screws ( 1 each side ) of the console and the plastic ducting will come out.
    #4 Now with that out, mark where you want your cup holder, you SHOULD be able to fit 2 of these in 1 behind the other, but my console has holes drilled in it from a mobile phone cradle and i put mine in a location abit further back than i would of with a undamaged console. Keep in mind the ducting has to go back in.
    #5 Get your hole saw and make sure the blade is slightly smaller than the pvc cup holder BUT still big enough to fit a can etc. and start cutting, double checking your drilling in the right spot. Go slow as you dont want to damage the console EG crack it. Once you have cut the hole DONT throw out the off piece as that comes into use later.
    #6 Once the hole is cut tidy the edges up with a small file etc if needed, now put the cup holder into position to make sure its a nice fit.
    Give the top of the cup holder abit of a scuff up with some sand paper so the glue has something to stick to, if your cup holder has embossed writing on it like mine did on the top make sure you take that off too.
    Now get the offcut and give it a good clean as well as the base of the cup holder, My offcut fit perfectly on the base of the cup holder, so i used it as the base. Simply glue it in place.
    Allow the glue to dry give the whole lot a clean and then give it afew coats with your plastic paint.
    #7 Now put the ducting back into position and test fit your cup holder, mine was hitting on the ducting so i used a Hair Dryer ( No its not mine :P ) to soften the ducting up where the cup holder was hitting it and moulded it to suit, This took afew goes to get right and make sure you put it under cold water when you are finished as that will harden the plastic back up and it should retain its shape.
    This was my first go at the ducting, i had to give it 3 more goes before i was happy. You could cut the section out that hits the cup holder and drill some holes into the holder itself so that when you put the a/c on it cools your drink at the same time, i think this would work as long as the holes lined up with the section you cut out.
    #8 Put the Ducting back in and put plenty of adhesive around the top of the cup holder and clamp it into place. Let it dry, this can take anywhere from an hour to afew days depending what you use.
    It should look something like this now.
    Once it has set properly give it a light sand if the adhesive has oozed out like mine did and mask up around the hole and give it a final coat of plastic paint OUTSIDE the car and Cut a round piece of carpet to fit into the base of the holder. If your happy with the final finish thats great, but i plan on finding some piping to fit onto the lip of the holder to give it a neater look.
    I am yet to do the final stage as my cup holder adhesive is still setting. Once its set properly i will get some pics of the final product.
    Hope this was Helpful!
    Josh
    Cheers Josh
    jujibelly's Avatar
    jujibelly is offline ERROR_PATH_NOT_FOUND
    Vr Commodore
    Apr 2009
    Melb
    Let me start off by saying f*ck you Holden. As if you wouldn't install one of these.
    Excellent how to mate, I would imagine a crap load of people will benefit from this. Too bad for people like me who have power window switches
    I think a o ring around the lip of the holder would be a good idea. Colour matched obviously.
    Anyway good stuff.
    VR Wagon
    Oct 2008
    Central Coast, NSW
    Cheers, i have been planing to do it for some time but never got around to it, i know afew people have done some similar stuff, some look good and some not so good and thought others would benefit from a how to. It was easy to do as i have the tools here at home.
    If anyone has any questions let me know, more than happy to help.
    I could knock up a how to for my carpeted handbrake boot to if enough interest?
    Cheers Josh
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Just a hint to people with power windows just move the switches to another location eg.. if you dont smoke mod em into the lighter/ashtray section, I`ve seen it done, even seen climate control placed there.
    jujibelly's Avatar
    Vr Commodore
    Apr 2009
    Melb
    Yeah this mod is so extremely useful and very easy to do.
    I think the more how to's on this site the more rich and benficial it is to users wanting different perspectives when it comes to all mods. So I do beleive you should include the handbrake how to as well.
    Cheers Sam.
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    hmm in theory couldnt you buy the vz console ones and put them in, thatd be interesting.
    The Black Beauty
    vs v6/ vr ss
    Apr 2005
    brissy
    funny thing is only time i've ever seen anyone use the factory cupholders in the glove box is to cut weed
    fkford is offline Love The Beast!
    VS exec S2
    Mar 2009
    if you cbf doing this just buy a caprice console lid.. they have hidden cup holders you have to cut the leather at the front and then pull out the two cup holders out when you want to use them.. saw it in street commos
    stop droolin
    Fonzie's Avatar
    Fonzie is offline Just lost the game.
    300zx 2+2 Targa
    Aug 2008
    Gippsland, Victoria.
    I was always intending to do this to mine before it got written off, I was planning on using a VY/VZ center console cup holder though. Great write up mate I would never have thought to use a hairdryer to get the ducting out of the way.
    EDIT: Also, for people with power window switches... Rip your auto shifter surround off (Because let's face it, for the grand total of THREE PEOPLE with manual VS's you can suck it up and hold your cups)... Fiberglass the hole where the ash/coin/random-crap tray usually goes and put the power window switches there. Also something I always intended to do.
    Quote Originally Posted by Philthy View Post
    ....man, I love how white your car is
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    i just keep my center console empty and keeps my drinks in there it holds a large fine fine
    VR Wagon
    Oct 2008
    Central Coast, NSW
    I was putting my drink in the centre console too but it was getting annoying, i should get it finished this weekend, i'll throw some pics up.
    Cheers Josh
    VR Calais
    Aug 2009
    Thumbs up my not so neat solution
    Excellent solution Josh. Do you reckon two cupholders would fit though?
    I have a temporary solution with a couple of cupholders from SuperCheap. They are on an angle and you lose the ciggy lighter - not that we use it, except for iPod and phone charger, but we run thise from the lighter at the rear. The angle doesn't seem to be prob.
    The lower holder is screwed into the ashtray lid - there's rubber packing over the lid to get a level surface. The front cup is clipped to the rear one, and has packing underneath so it sits against the console.
    One day I'll get around to shifting the window controls and go with your system.
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Quote Originally Posted by Fonzie View Post
    thats what im thinking of doing to mine one day
  15. #15
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    good thread mate! might give this a shot. anyone got more info on the power window switch relocation?
    I don't have power windows yet but it's in the plan!
  16. #16
    sik_VR's Avatar
    sik_VR is offline monster VR
    VR Berlina
    May 2009
    VR Wagon
    Oct 2008
    Central Coast, NSW
    2 cup holders should fit if you move the front cup holder forward, mine is only in that spot as i had holes drilled into the console for a phone holder and didn't want them left behind, when i put the last cup holder in i will have to modify it as the console starts to curve up to the armrest.
    Cheers Josh
  18. #18
    vr calais series 2
    Mar 2010
    nstone63's Avatar
    nstone63 is offline wants a new car
    1988 VN Executive
    Mar 2010
    Roxby Downs SA
  20. #20
    Vz Sv6 04
    Nov 2009
    Bundaberg
    awesome guide, definitely gonna give it a go so i dont have gay k-mart holders on my vents lol
  21. #21
    Raremetal's Avatar
    Raremetal is offline Best of both worlds.
    Series 2 94 VR Wagon
    Jul 2010
    NSW
    Nice job there Josh, but Id put a ring around the top maybe matching your colour scheme in your car. But good job, and nice how-to!
    Rare.
    Current ride: 94 VR Commodore Wagon, Series 1 engine in a Series 2 body.
    Wheels: VE SS 19's custom machined to fit VR.
    Sound: Kenwood + matching speakers.
  22. #22
    VS Executive S2
    Aug 2010
    I find placing the drink in between the seat near the seat buckle and your center console it holds it in place nice and firmly
  23. #23
    VSII Exec S/W
    Aug 2010
    VS Series II Supercharged Statesman
    Nov 2010
    Talking No real cup holder in a statesman ... ahhammm.... i think not ;)
    hehehe... vs statesman supercharged, told no cup holder in the centre-box lid ..... WWWWRONG
    just another option from the caprice they hid in the others
    A little bit of leather trim playing, fibreglass cutting and its all done
    it looks as though holden just plastic welded the slider in place, a knife takes care of that.
    next time i might even mod the lid (it has a huge storage shelf in it doing NADDA!)
    By choppareid
    By choppareid
    By choppareid
    PS: I know my interior is ratty, but i am getting it there (tiny) bit by bit
  25. #25
    VR Wagon
    Oct 2008
    Central Coast, NSW
    Rare, i never got to finish it completely as i sold it. It was meant to get a ring around the top. I will be doing another one of these in the girlfriends vs soon, but with a different design. I'll add it to this when i'm done.
    Cheers Josh
  1. cup holders
    By Black.Label in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2008, 06:17 PM
  2. VS Cup Holders
    By Goldie87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2008, 01:54 AM
  3. cup holders
    By hardv8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-04-2006, 05:13 PM
  4. Cup holders are go!!!
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2006, 10:23 AM
  5. cup holders
    By vpwgn in forum General
    Last Post: 12-10-2005, 08:09 PM
