Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By F1carbonuk
Thread: Make your own Transmission Manualiza plug for $6.00
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Default Make your own Transmission Manualiza plug for $6.00
    I TAKE NO CREDIT FOR THIS MOD AS IT NOT MINE
    Taken from L67torque.com from member VRTIDY
    This is wired the same as the Transmission Manualiza plug that RVO and DTM transmissions are supplying for large amounts of money.
    This transmission manualizing plug disables the Automatic gear change and allows the 4L60 transmission to be manually gear changed under full trans line pressure.
    It will give a smooth manual gear change at low Revs/Power, and Hard as manual gear changes at High Revs/High Power.
    1 x 4L60E transmission plug from a VR - VY Commodore loom. cut it off with between 100mm - 200mm of wire on it. $5.00
    1 x IN5408 4 amp silicone rectifier diode. $1.00
    4 X Stubbies of Harn light
    Solder the yellow and light green wire on to the anode side of the diode and insulate.
    Solder the yellow/black and Brown/yellow to the Cathode side of the Diode ( Side with the silver band).
    supply 12volts from the ignition (reds) to the pink/blue wire to power the transmission.
    Cut off remaining unused wires.
    vn
    Dec 2009
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    triggers the shift solinoids manually when you select gears instead of the ecu controlling it.it uses the gear position switch in the trans to directly activate the solinoid required for the gear you want
    Vn commodore executive
    Mar 2010
    delco is this legit? Guessing if it is it would only work from vp onwards
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    also how do you select 4th gear? Is D still full auto?
    If I put it in D, is it going to be in 4th and have no take off power?
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    Mar 2010
    if this is legit it is very cool, but the only car i would be game doing it to is the vn hahaha but that aint gunna happen
    i'm not tailgating, i'm keeping up with the pace car
    vn
    Dec 2009
    yer thats what i was thinkin as im getin a vn calais auto soon and ive got a engine and 5speed conversion already sitin in the shed so was thinkin of doin this for abit of fun thats why id lik some more details
    Chevy Lumina SS
    Aug 2010
    Saudi Arabia
    Hasn't it already been mentioned that manualy shifting an Auto kills the box.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by delcowizzid View Post
    obviously this looses torque convertor lockup and trans temperature 4th gear lockout good for doing an engine swap into an old vehicle with no ecu and a non-lockup convertor not so good on a commodore with standard convertor will cook the box if its driven at highway speeds without a non-lockup convertor and accompanying fluid mods inside the box for the TC
    Taken from the other thread.
    Transmission Manualiser
    в∞ѕтεכ √&
    Jul 2008
    NZ
    will only work vr onwards auto
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    i dont see how you need this as i can hold gears with my box as it is i just dont as it ####ed my last commodore
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    Quote Originally Posted by vr1uz-fe View Post
    try holding it in first and taking off. it will change into second.
    VX S S/C & BA XR6T
    Feb 2009
    If youve tried to dyno a L67 $speed then you will understand.It has very hard to get a good plot from 80kmhr in 3rd with 3/4 throttle at least because it will kickback to second.This mods fixes that issue.One should only be carrying out this mod to for the dyno reason and nothing else.
    vr berlina
    Aug 2010
    australia
    ah i see now
    i just remeberd that i used to hold the gears in my vp some plz slap me across the face
  15. #15
    в∞ѕтεכ √&
    Jul 2008
    NZ
    Quote Originally Posted by karlos View Post
    normally just command it too stay in 3rd with the laptop for dyno runs then it wont shift also lock the TCC watch the HP rise
  16. #16
    VE Omega
    Apr 2011
    Pakenham Victoria
    thats the one thing i quiete enjoy about the auto in a VE
    it wants to stay in the gear you like without automatically shifting,
    probably the only thing decent about it really
  1. Make your own 4L60E Transmission Manualiza plug for $6.00
    By zapper-l67 in forum Electrical Wiring / Questions
    Last Post: 19-12-2011, 12:46 PM
  2. Replies: 0
    Last Post: 17-11-2008, 01:51 PM
  3. auto reverse light plug to manual plug
    By The Darkness in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-08-2008, 10:40 PM
  4. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  5. Replies: 11
    Last Post: 26-12-2005, 10:48 PM
