Results 1 to 9 of 9
Thread: Cleaning MAF Sensor and Replacing Air Filter
    SV6
    Dec 2009
    Default Cleaning MAF Sensor and Replacing Air Filter
    Step 1. Take off air intake guard.
    Step 2. Undo bolt connecting the MAF sensor to the Air intake to the engine. Disconect MAF wires.
    Step 3. Undo Air box cover, 3 screws. Put a rag in the pipe coming out of the engine to stop crap getting into the engine. Replace Air filter and clean bugs out of the bottom of the air box.
    Step 4. Clean the MAF senor and connection with CRC MAF sensor Cleaner. Do not touch the MAF senosr at all other wise you will be up for a new one. It will dry in a few minutes by itself.
    Step 5. Put everything back together. Make sure you have a good seal between the engine air intake pipe and the MAF sensor pipe.
    After doing my sv6 i notice it to run and drive a lot smoother. Will be doing it every service from now on.
    Enjoy
    VX II Calais L67 Manual 17 PSI W2A + MAFLESS
    Apr 2009
    Great Thread mate thanks.
    Will give it a go shortly. Did you notice a big improvement?
    VX Berlina - GENIII
    Mar 2010
    Qld, Australia
    Good article.
    I recently did this to my LS1 VX as it had a slight flat spot of idle. This car has 115,000 on it with more than half the k's I have put on it. It had not been done in the time I have had it. On removing the MAF I noticed a slight film of dust on the criss cross air intake bit. I used carby cleaner and left it to dry.
    Over the last 200km (since I did it) it seems to have cleared up the flat spot sensation up, I have actually been getting slightly better fuel economy (dropped from 18L to 16L around town) and it idles a bit higher. Prior to this the idle also did not seem to udle up much for cold mornings (I am in Qld) where now it does idle about 900rpm when I first start it.
    I will be doing it again (if I don't go mafless prior)
    Qldkev
    VX 'S' S1
    Apr 2005
    South East,Victoria
    I tried some of that cleaner today . Mine was pretty black . Havn't taken it for a drive yet . Mine had something that looked like part of a rose petal stuck to it . That could have had something to do with the uneven idle i was having trouble with . Know idea how it got there
    DoggFather is offline Banned
    VZ SV6
    Mar 2012
    Fairfield
    You see how you have a pic on step 4, do I just spray the whole inside with CRC MAF cleaner? IE the black plastic parts
    VZ SV6
    Mar 2012
    Fairfield
    Also the MAF would be still connected to the top half of the air box right?
    vr 3.8 ute
    Feb 2012
    brisbane
    Yes it would. If u want to clean out your intake tube dismantle intake tube from throttle body and maf and clean out by hand. Just remember to assemble ur maf sensor the right way around it should have an arrow on it with direction of air flow and as wassaby said DON'T touch the sensors on maf if you have maf off completely you can spray it from both sides
    NZ Pioneer is offline NZ Pioneer
    WH Statesman GenIII 5.7
    Apr 2012
    Paihia, Bay of Islands
    Thanks wassaby ... very straight forward and seems sound advice! NZ Pioneer
    Shooter03's Avatar
    Shooter03 is offline Nek Minnit
    Vz wagon
    Feb 2012
    Narre warren
    Cheers mate, doing it when I get home tonight.
    Posted with my iPhone 4s through tapatalk
    I Used To Have a Open Mind But My Brains Kept Falling Out
    Originally Posted by drewVHSS
    If you wish to buy that, i have some sweat from the ball sack of an elderly yak, if you rub it on the rocker covers of your engine, it'll unleash 1-2 killerwasps of powah!.
  1. Cleaning your MAF Sensor
    By jesse'sVT5.0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2010, 08:49 PM
  2. Cleaning Pod Filter (Kingdragon)
    By torana9x in forum General
    Last Post: 10-11-2009, 04:06 PM
  3. Cleaning K&N filter
    By pando666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2009, 09:13 PM
  4. cleaning MAF sensor
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2009, 11:01 PM
  5. cleaning k&n filter
    By greatone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-05-2006, 09:15 AM
