Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
Like Tree3Likes
Thread: Splice in LED light strips to your fog light wires.
  1. #26
    VS Executive S2
    Jun 2011
    Frankston
    I doubt it would be illegal caus all the better VE's (clubsport, maloo etc.) have exact same look as part of the standard light and across the kit's trims, so unless its illegal because its not a standard upgrade from the dealership (which is ricidulous its just a modification like speakers, wheels, chargers, your just upgrading) it would be fine. Thats just my opinion though, dont blame me if you get a ticket, which could be easily talked out of
  2. #27
    Ando227's Avatar
    Ando227 is offline Serious?
    Vy Series II Ute
    Nov 2008
    Lightning Ridge
    Good advice on the splicing... I use to have these under my headlights on my VZ here are some Laws from the RTA for NSW.
    Road Transport (Vehicle Registration) Regulation 2007
    Schedule 2 Vehicle standards
    Division 4 Daytime running lights
    94 Daytime running lights
    (1) A pair of daytime running lights may be fitted to a motor vehicle.
    (2) A pair of daytime running lights fitted to a vehicle with 4 or more wheels must be fitted with the centre of each light:
    (a) at least 600 millimetres from the centre of the other light, and
    (b) not over 510 millimetres from the nearer side of the vehicle.
    (3) However, a pair of daytime running lights fitted to a motor vehicle under 1300 millimetres wide may be fitted with the centre of each light not under 400 millimetres from the centre of the other light.
    Location of daytime running lights on a vehicle
    (4) When on, a daytime running light must:
    (a) show a white or yellow light visible from the front of the vehicle, and
    (b) not use over 25 watts power.
    Note. The third edition ADRs only allow white daytime running lights.
    (5) Daytime running lights must be wired so they are off when a headlight, except a headlight being used as a flashing signal, is on.
    (6) For subclause (3), the width of a vehicle is measured disregarding any anti-skid device mounted on wheels, central tyre inflation systems, lights, mirrors, reflectors, signalling devices and tyre pressure gauges.
  3. #28
    VY Exec S2
    Jan 2012
    looks neat mate im wanting to install a small strip inside the engine bay near the front grill but only to come on when i unlock the car. any ideas what circuit i should follow i.e the interior light so that when i turn the car on, it goes off.
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  3. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  4. Berlina/Calais/Statesman Roof Inteior light into basic model with standard light
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2008, 10:07 PM
  5. Wires/Plugs behind light selector
    By Lloyd1986 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2007, 04:36 PM
Tags for this Thread
