Results 1 to 4 of 4
Thread: removal and replacement of 4 speed auto transmissions
    12/02 VX Commodore Lumina Sedan
    Aug 2010
    tamworth
    Question removal and replacement of 4 speed auto transmissions
    Hi, first post, i have replaced gearboxes before(not on hodens though), but never an auto transmission. I was wanting to know is there any difference to replacing a manual box to an auto, and if so how is it different? Thx.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Well you have to remove the flex plate bolts.
    Remove the starter motor and you will see the flex plate which has three bolts connecting it to the torque convertor. Turn the flexplate with a large screwdriver or prybar by putting the end in the teeth and levering it around and undo each bolt.
    Also need to remove the trans cooler lines.
    Silver Certified.
    Aug 2010
    tamworth
    sorry for the lateness, but, thanks very much ricey. Info was short and precise and made my job heaps easier. Thx again mate.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    No worries
    Silver Certified.
  1. VR/VS - Dash/Instrument Cluster Removal & Replacement
    By NKX in forum Holden Commodore How-To's
    Last Post: 30-12-2010, 07:06 AM
  2. Which auto transmissions will fit the VS?
    By Ozpacman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2009, 12:11 AM
  3. z-bar removal / bush replacement
    By BOX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2005, 09:43 AM
  4. VN-VS Fan Speed Resistor Removal
    By Darren in forum Holden Commodore How-To's
    Last Post: 09-08-2004, 09:44 AM
  5. Passenger Door Trim Removal/Mirror Replacement
    By db_1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-04-2004, 02:24 PM
