SLIVZ
- Aug 10, 2010
- 10
- 2
- 0
- Age
- 33
- Location
- koo wee rup
- 05 VZ Calais 3.6
Things Youll Need.
Music
10mm Socket
13mm Socket
16mm Plug Socket
Multi Grips or Pliers
Phillips head
Flat Blade screw driver
6 Spark Plugs(i got mine from holden but you can get them from Autobarn aswell)
1 pair of inlet Manifold Gaskets
First things First, You have to pull of these 2 Vaccum Hoses
Undo this Bold with your 10mm socket
Undo the 3 screws holding the Airbox lid on Using a Phillips head
Remove radiator Cover by using your Flat bladed Screw Driver
Now Unplug your AFM
Undo the Clamp on your Induction pipe with a small shifter, Unplug the Throttle body(underneath), And take off the vaccum hose on the left hand side
Use Pliers to squeeze the clamp on the Master Cylinder vaccum hose and pull it off, Unplug the to plugs just behind the manifold and undo the 6 13mm bolts holding down the manifold
You are now faced with this
Start by undoing the 6 10mm bolts Holding down the Coil packs, they should now just pull out and now use your 16mm plug socket with extension to remove the plugs
Now clean the Runner gasket area with some Metho or petrol and a razor blade( WARNING: TRY NOT TO DIG THE BLADE INTO THE SURFACE AS IT WILL CUT GROOVES INTO EASILY AS ITS ONLY ALLOY) once that is done Place new Gaskets and reverse all the steps and your done
Music
10mm Socket
13mm Socket
16mm Plug Socket
Phillips head
Now Unplug your AFM
