Results 1 to 20 of 20
Thread: How to make your own air box!
    98 VT Exec
    Jan 2010
    Redbank Plains, QLD
    Default How to make your own air box!
    Ok guys.I do not take responsibility for your shitness.
    So let's get on with it. This is probably the easiest & cheapest mod you can do for highly noticeable performance.
    Things you'll need:
    -Sheet metal (1m x 1.5m)
    -Cardboard (the bigger the better)
    -Paint (optional)
    -Screws & screwdrivers
    -Rubber mallet (for bending the sheets)
    So.... start by making templates out of cardboard.
    When you're happy with the result,simply transfer it onto the sheet metal.
    Make sure you include little tabs to screw the box to the body.
    Now you can do the cutting with tin snips which would take ages for a crap result.I used a jigsaw with a blade for metal,makes life easy.
    Drill the holes for the screws on the box off the car, then mark then in the car.
    I'm only focusing on the air box because you can make the plumbing to your desire. (eg. silicone hoses, or whatever you can find)
    when you're happy with the result you can paint it.(or not)
    Here are some pics that might make it easier. feel free to ask anything as I can make them to order if you're interested.
    Attached Thumbnails Attached Thumbnails How to make your own air box!-dsc00415.jpg   How to make your own air box!-dsc00417.jpg   How to make your own air box!-dsc00416.jpg   How to make your own air box!-dsc00418.jpg   How to make your own air box!-dsc00420.jpg   How to make your own air box!-dsc00419.jpg   How to make your own air box!-dsc00421.jpg
    How to make your own air box!-dsc00422.jpg   How to make your own air box!-dsc00424.jpg   How to make your own air box!-dsc00425.jpg   How to make your own air box!-dsc00423.jpg   How to make your own air box!-dsc00428.jpg   How to make your own air box!-dsc00427.jpg   How to make your own air box!-dsc00459.jpg
    How to make your own air box!-dsc00458.jpg   How to make your own air box!-dsc00451.jpg   How to make your own air box!-dsc00452.jpg   How to make your own air box!-dsc00460.jpg   How to make your own air box!-dsc00463.jpg   How to make your own air box!-dsc00462.jpg
    VL V8 & supercharged VX
    Nov 2006
    western vic
    looks good there ive made one from strut tower to headlight and on a charged car massive blower whine.
    VS acclaim
    Aug 2010
    Mooroolbark
    looks great... whats the induction sound like?
    and what sort of ducting are you using because I want to upgrade to 4" but dont really want to pay 100 bucks for the one advertised online (i forget where)
    I want to buy one but i can see freight being alot cuz im in melbourne...
    CAI, 2.5 inch system with extractors.
    yella terra roller rockers.
    mace manifold spacer.
    WISH LIST... mace throttle body, 4" maf ducting, sc14
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    So this is a DIY home job of the MACE CAI kit...
    not bad
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    98 VT Exec
    Jan 2010
    Redbank Plains, QLD
    Wink
    The ducting i'm using is 4.5" semi-flexible construction piping/tubing.
    The sound is not as loud as before it was enclosed,but you still get the "vaccum track". lol
    98 VT Exec
    Jan 2010
    Redbank Plains, QLD
    VS 666 if you're really interested i can send it flat so you just have to bend it!
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Can I suggest you find some pipe work that ISN'T convoluted.
    The convolutions actually disrupt air flow and cause it to tumble inside the piper. Smooth bore pipe is much more efficient.
    You'll notice bugger all difference, but every little bit counts.
    Good job on the box too, looks the goods.
    98 VT Exec
    Jan 2010
    Redbank Plains, QLD
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    good right up,
    i would do it but nooone sells pod adaptor for the efi vk
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    VY Commodore Ute
    Dec 2009
    North Adelaide,SA (uni) / Mildura, VIC (home)
    Im currently in the process of doing this mod, Only difference is i picked up some Thermal shield foam from Clarke rubber to line the inside, comes with silver lining and adhesive already on it, only costs $25 per meter and when you only need 20cm makes it cheap and should really help keep the box temp down.
    VS Calais S1
    Jul 2006
    Kadina, SA
    98 VT Exec
    Jan 2010
    Redbank Plains, QLD
    commodore
    Aug 2009
    australia
    looks the goods, neat job!
  15. #15
    VS Calais S1
    Jul 2006
    Kadina, SA
    Quote Originally Posted by NightRIDA View Post
    thats what the tabs are for!!
    My bad, I must have read over that bit.
  16. #16
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Very nice result. As said before the pipe isnt a huge issue but some aluminium pipe and some silicone elbows if you want a little more for performance and looks even though its probably only going to be 1/4 of a KW or less.
    Also Ive seen silicon pipes made to order from $2-4 USD per meter on a Chinese website but minimum order is 500 meters so that doesnt really help for you, but then "performance companies" stamp a logo on it and sell the elbows for $25 and straight lengths from $20-50, huge profit from them.
    Best RPG ever
  17. #17
    VN Wagz's Avatar
    VN Wagz is offline PshhhhHHT- **TuTuTuTu**
    VN Berlina V6 Wagon
    Sep 2008
    Dunlop (North Canberra)
    The best part about a CAI system isnt the POWAHHHH that you get (woo- 2rwkW if you're VERY lucky lol), its the ability to run a damn-near unrestricted flow path for ambient air, assuming you put a large free flowing filter panel or pod in your airbox.
    Means that when you stomp the throttle at idle, when rolling along, whenever- you'll be getting colder air than you would from a stock setup or (god help us) an under-bonnet pod filter/hot air suction machine. This generally equates to a snappier throttle response, a few extra Nm (which is where the rear gains are) and a full hektik noise.
    i ran a 90mm poly- pipe CAI setup on the wagon on the wagon for a few WSID runs, was all sprayed temp-proof black and with no other mods i dropped 0.5 seconds on average on all my runs. 60ft times (while crap) was where i got my gains. Gained 1mph
  18. #18
    98 VT Exec
    Jan 2010
    Redbank Plains, QLD
    Here's how it looks now!! Brand new MAF + Genuine Rubber!!!!!! wouldn't change it.
    Attached Thumbnails Attached Thumbnails How to make your own air box!-y-piece-egr-061.jpg   How to make your own air box!-y-piece-egr-052.jpg   How to make your own air box!-y-piece-egr-053.jpg
  19. #19
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    Great guide
    Quote Originally Posted by coplzr View Post
    At the end of the day its not about the money its about how you want it and were u wanna stop, i mean i could have just tinted windows put kit and chrome wheels on the car and lowered it and started a thread if thats what you all wanted but i love cars i love the feeling u get when ppl say mate u done a great job on this thing now that feeling is the very exact reason ill do it again on another car i enjoy any part i can play in the build and i def enjoy driving it
  20. #20
    98 VT Exec
    Jan 2010
    Redbank Plains, QLD
    Thanks mate!
  1. Make a VN go a little better.
    By holdensmychoice in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2010, 03:25 PM
  2. How can I make my VX look like a VY/VZ
    By bignath in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-11-2009, 08:17 PM
  3. how to make look gud
    By xcopr in forum General
    Last Post: 17-09-2009, 12:58 AM
  4. How can I make my car low?
    By Aaronthestig in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-08-2008, 10:55 PM
  5. Make Over
    By AlX in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-08-2005, 09:01 AM
