Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By SAMO-87
Thread: Changing front struts on a vt/vx Commodore
    98 VT Commodore
    Sep 2010
    Adelaide, South
    Default Changing front struts on a vt/vx Commodore
    First step: Jack your car up remember too put a brick behind
    the back tyer then take front tyer off.
    Second step: Place a jack so that you can lift the rotter up
    to a height that is just enough and it is less stress on you.
    Third step: Now it's time to remove the Strut. Remove the 2 nuts on top
    and bottom of the rod.i found when You undo any of the nuts
    the rod still turns so i put a justable spanner on the rod
    were its flat to stop it from turning.
    forth step: Take the sturt rod out easy way to do it
    get somethig thats stong then place underneath tension rod on top
    of the sway bar and lift up then strut rod will come out
    (you will need a bit of strenght to do this because on
    some car's they can be pricks to get off lol).
    Fith step: Now it's time to get the new rod (the ones i got were thicker and they were
    bent because of the design of the rod and it fit's in a bit better) to put the new rod in
    just reverse the method you started with by lifting the sway bar place rod in the start to do the
    nuts up dong forget the rod will turn so use an ajustable spanner to hold the rod
    when its done up take the jack out from underneath the rotter put tyer on an take it
    for a drive an feel the differnce in your steering.
    Thanks for having a look if you have any questons just ask.
    sorry if the pics were to big coz im still learning on how to use this site lol !!!
    Attached Thumbnails Attached Thumbnails Changing front struts on a vt/vx Commodore-dscn0005.jpg   Changing front struts on a vt/vx Commodore-dscn0004.jpg   Changing front struts on a vt/vx Commodore-dscn0003.jpg   Changing front struts on a vt/vx Commodore-dscn0007.jpg   Changing front struts on a vt/vx Commodore-dscn0002.jpg   Changing front struts on a vt/vx Commodore-dscn0006.jpg
    02' VX Berlina 5.7L
    Feb 2005
    S.E Melb
    Just to stop confusion, the part you have replaced is NOT called the strut...
    It is in-fact the sway bar link.
    98 VT Commodore
    Sep 2010
    Adelaide, South
    ok the manual i have called them struts and the shop were i got them from seid the same to but they all work the same
    but it has made the ca feel grate an the clunking noise has stoped when i do a sharp turn but thanks for the feed back
    GSXR1000
    Apr 2010
    WA
    With the clunking noise, did you also get it just driving along in a straight line etc when you hit bumps etc?
    My car is doing that and I know my front shocks etc are gone too, so I'm considering swapping out the shocks/springs and lowering the car slightly whilst I'm at it.
    VX Acclaim Wagon
    Feb 2010
    Thanks for the pics and posts.
    When I changed my front struts (shocks) i found my sway bar link was bent so I changed that as well.
    I was getting a clunking noise when driving in a straight line over bumps. A few mechanics said it was the engine bushes (or something like that)
    Because changing the rear shocks and front struts was going to cost a fortune from a mechanic, I decided to tackle this one myself. Took me all day but got them all replaced. No more clunking noises now and also no more shuddering when braking.
    The sway bar link in the vx commodore is a little different at the bottom but mostly the same as those VT pics.
    VZ MY06 SS
    Aug 2008
    Quote Originally Posted by SAMO-87 View Post
    Hahahahahahaha
  1. Changing front struts on a vt/vx Commodore
    By mantice in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-09-2010, 09:00 PM
  2. changing vp struts
    By juice1929 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-08-2010, 06:03 PM
  3. Changing Bonet Struts
    By Grennan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-08-2009, 07:37 PM
  4. changing front struts/springs
    By somerandom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2009, 11:05 AM
  5. changing front struts on my vs commodore
    By tbblitz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2007, 04:19 PM
