Results 1 to 5 of 5
Thread: Adding a switch to courtesy light.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Default Adding a switch to courtesy light.
    To add an on/off switch to the courtesy light you will need to add a small switch to the circuit at the light unit. This will give you full control over the operation of the lamp without complicated wiring.
    After first disconnecting the main battery, you will need to remove the cover from the lamp unit - then undo the 4 screws that hold the unit to the roof. Pull the unit downwards slightly and you will see that the unit has 2 orange wires which disappear behind the headlining. Cut either of these wires so that you can solder in a small switch as shown in the picture.
    I found it easiest to solder 2 wires about 150mm long to the switch and then feed them thru one of the openings and then solder to the unit. A hole is drilled in the cover for the switch as shown in the picture.
    The pictures explain it all. Good Luck.
    Attached Thumbnails Attached Thumbnails Adding a switch to  courtesy light.-wiring.jpg   Adding a switch to  courtesy light.-switch.jpg   Adding a switch to  courtesy light.-finishedlite.jpg
    VS Series II Equipe
    Dec 2010
    Australia
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    Quote Originally Posted by MaverickAus View Post
    Why bother? What's wrong with the switch on the headlight switch?
    can't turn it off from that switch.
    good write up/idea hako
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    take the bulb out. i haven't had one in mine for years. i only use the rear passenger courtesy lights which are switch-able
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. courtesy light wire for footwell lights.
    By jasnos in forum Electrical Wiring / Questions
    Last Post: 26-08-2010, 07:12 PM
  2. adding switch to factory footwell lights
    By nathanVY in forum Electrical Wiring / Questions
    Last Post: 16-08-2010, 12:32 AM
  3. Post on how to wire up headlight off switch to interior light door switch
    By Bookanun in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2010, 12:19 PM
  4. door courtesy light cover
    By jafo in forum General
    Last Post: 09-06-2009, 08:33 PM
  5. Adding 3rd Brake Light
    By ssmate in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2007, 10:10 PM
