Results 1 to 16 of 16
Thread: [Ecotec] How to install a smooth intake from MAF to the throttle body.
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Default [Ecotec] How to install a smooth intake from MAF to the throttle body.
    This took a lot of searching (although searching was useless) a bit of trial and error. After looking around and asking what size the TB and MAF are and ordering the wring size hoses 2 times the 3rd time I ended up getting the right silicone hoses.
    The idea I has started from reading about the intakes to the carby or a TB as smooth as possible for the best air flow. I don't claim that you will see a increase in power at all, it may be less than 1kw or more and there is no way Ill put it on a dyno to find out.
    At first I looked in places like Autobarn and Super Cheap for silicone hoses, they are around about $50 for the straight one and $70 for the 45 degree bend. I looked online at other places in Australia online but they were still higher in price. I ended up finding a guy on ebay located in China and asked him for his best price for the 2 items I needed, it was $22 AUD delivered for the 2 silicone hoses combined.
    I got some Tridon T-bolt clamps for around $5 each from a local radiator joint and a 3" OD pipe from sprints although Ill probably change that to 3" ID and stretch the silicone hoses around it as I have done for the TB and MAF sensor.
    The guy recomended 75-80mm T-bolt clamps but I said they will be too small so I got some 80-85mm clamps. When the hoses are stretched over the TB and MAF even the 80-85mm don't fit so I would recommend to buy 86-91mm T-bolt clamps. I will be buying some soon when I get some 3" ID tube for the joining section.
    What you will need:
    x2 Silicone hoses: $22
    3" ID straight joiner and a 3" ID 45 degree elbow.
    x2 80-85mm T-bolt clamps: $20
    x2 86-91mm T-bolt clamps: $20
    x1 3" Pipe: $0
    Got this from the exhaust dude for free when I asked for it.
    You could probably find the clamps for cheaper and definently find the joining pipe for cheaper but it was convenient at the time where I was to buy it there although I will have to buy 4 more clamps and another joining pipe anyway.
    Step 1: Remove engine cover.
    Undo the 4 x 10mm bolts then lift the cover up and forward. Notice the corrugated surface of the intake pipe, it is the same on the inside as well, creating resistance to air flow.
    Step 2: Remove the standard intake from the MAF to the TB, undo the clamps with a screwdriver or a 8mm socket/spanner.
    Step 3: Undo the clips to the air filter box and disconnect the wire connected to the top of the lid. You will need this off because its a tight fit and you cant put the joiner in when the 2 ends of the silicone are nearly touching.
    Step 4: Im pretty sure you can work out how to put hoses on the TB and MAF as well as putting the clamps on and tightening them up, once done don't forget to clip your air box lid back down and put the plug back in. Re-install engine cover if required (I will be polishing my plenum and leaving it off)
    Note: As I got the wrong size clamps I had to reused the stock clamps on the TB and MAF, I will put up more pictures another time when I have the right joiner and clamps connected.
    Finished pics: (sort of)
    The reason I want 3" ID pipe is because I want to stretch the silicone wider where it joins. I had thought about going 4" but it turns out to be a waste with dead air sitting in there and no better than stock. Straight thought the same ID and smooth is the way to go.
    Edit: I got a differnt joiner and got the correct 86-91mm clamps for the TB and MAF end today, Ill post up more pics when I put them on.
    With the 86-91mm clamps on TB and MAF, only just noticed they arent straight but I'll fix that up another time.
    Best RPG ever
    vx s2
    Aug 2009
    awsome mate, did you get any gains, better responce etc, and do you think your mod would be better than the 4" intake pipe on v6 performance
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    who's the fella you got the hose off from ebay? got a link?
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    1TUFVS's Avatar
    1TUFVS is offline High Ambitions, Low Funds
    '95 VS Acclaim
    Oct 2010
    SA: The Defect State
    'Tis a good guide.
    "Race car driving is like sex - all men think they're good at it"
    -Jay Leno
    Quote Originally Posted by m1chael1o1 View Post
    i spray painted mine they look good, never been hassled by cops. I think i can feel an increase in power aswell
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    I don't think you're going to get huge gains from this mods. And I don't think thats the OP's objective.
    Four inch pipe work wont make any difference, the smooth pipe work is where the improvement is. Convoluted pipe causes turbulance which essentailly slow the airspeed down. Which in essance is a restriction.
    Smooth pipe doesn't do this. So the engine uses less effort to draw the oxygen into the motor. It won't increase the power at the wheels, but it will make it easier to do, what it already does.
    So you may notice a very smally increase in throttle response and the engine may rev a little smoother through the RPM range.
    vt s pack
    Oct 2010
    brisbane
    Nov 2008
    Smithton, Tasmania.
    2DIE's Avatar
    97 Acclaim
    Feb 2008
    South Aus
    Quote Originally Posted by SPEED View Post
    Gains are un-noticeable to me, I feel its a tiny more responsive but it's possibly the placebo effect. It will allow the air to flow smoother and faster but its not a real performance mod, it will aid other mods if anything.
    The 4" pipe isnt as good for the TB and MAF as they are 3", 4" pipe would just create a chamber and slow down the air inside unless you had a 4" TB and MAF to suit it.
    Quote Originally Posted by MR_VX View Post
    eBay My World - zenaracing
    I asked for his best price on what I needed including shipping, after I agreed he asked for my email and send a invoice through paypal. I didn't actually buy it though ebay.
    Best RPG ever
    Nov 2008
    Smithton, Tasmania.
    Quote Originally Posted by 2DIE View Post
    Same princbile as exhaust pipe dimentions.
    You want air speed. Too small will slow it down and restrict it, to big will slow it down and restrict it. That's why bigger throttle bodies are a little on the waste of time side IMO.
    Especially when the throttle body port on the plenum is as small as it is. I almost doubled the size of the port opening.
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Heres the setup i had on my old v6 ute Black VS ute pics are on first post
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    99 VT Series 1 Wagon
    Nov 2010
    Default Silicon Pipe
    eBay Australia: Buy new & used fashion, electronics & home d
    Just ordered the 2 silicon pipes of $37.50 express delivery out of melbourne , if anyone interrested...
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    Quote Originally Posted by WogBoyz View Post
    Mind PM'ing me where you got all that? Would help me with my stuff alot, all my kinky shit is losing alot of air -.-
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by DevilDRake View Post
    Pm sent mate
    VS GTS & VT XU6
    May 2011
  15. #15
    Jan 2008
    NSW
    Mate, those hose clamps you got are used on FI cars that run decent boost. A little overkill if you ask me lol.
  16. #16
    1999 VT Commodore Acclaim
    Mar 2011
    Echuca
    did this in conjunction with an ss inductions growler CAI
  1. Twin Throttle Body Ecotec intake
    By vs commi in forum V6 Development And Modification
    Last Post: 18-09-2010, 02:34 PM
  2. [VIC] Ecotec Cleaned and Port Matched Intake setup including Throttle Body and Fuel Rail.
    By TrikkBen in forum Parts And Other Items For Sale
    Last Post: 12-02-2010, 11:15 AM
  3. [VIC] Ecotec Cleaned and Port Matched Intake setup including Throttle Body.
    Last Post: 13-11-2009, 04:07 PM
  4. Air Intake / Throttle Body Sound
    By Noel-e in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2009, 10:34 PM
  5. 70mm throttle body install
    By Marchoz769 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2008, 07:17 PM
