Results 1 to 16 of 16
Thread: How to change the oil in your auto transmission VN-VS
    VS Executive 3.8
    Jan 2011
    cairns
    Default How to change the oil in your auto transmission VN-VS
    Ok so i thought i should show people how to change their auto transmission oil the good way in ten easy steps lol
    seing as every post about it i see people are hoo haring and saying its a really bad job to do but its not its easy if u just follow these easy steps
    ok so first ur gunna need some things like
    Tools:
    1) 13 mill socket (maybe a 12mill too mine had one 12 mill but it might just be mine lol)
    2)socket extension
    3)ratchet
    4) a torque wrench but u can do it by feel with a ratchet
    5)not required but i recommend u have a tarp or something the oil wont go through(for under your car when u start getting dirty) and some old towels for (u can get old towels at lifeline )
    6)razor for removing gaskets
    7) a good shower and some good hand cleaner to clean ur hands and possibly hair lol ;P
    Parts:
    1)dextron III oil (dosent mater what brand what ever floats your boat)
    2) a auto transmission filter kit (comes with new filter and gasket, could be cork or paper or ruber depends on what you buy)
    3) and some lucas stop slip if you want (its good stuff makes ur oil last longer and helps shifting and stops slipping(duhhh )
    4) and some brake cleaner (its a solvent) its really good to clean the pan out with out leaving residue like degreaser
    PROCEDURE:
    1)Ok start with getting some oil out before u take off the pan to do that you will need to take off the out put line from the transmission to the oil cooler inside the radiator and that will be on the bottom of the radiator above the bottom radiator hose
    2) once that is off u might need some one to direct the oil cooler hose( so the black one) into a bucket while u start the car and let it run while it pours into the bucket and when it starts to bubble or spray like crazy turn off the car
    3) then chock the rear wheels and jack the car up and place jack stands in the appropriate positions(front side probably better) (or use ramps but u will have to do step one and two while it is on the ramps )
    4) then get under the car and start undoing the (16) 13 mill bolts holding the pan on (they wont be on very tight just a little nip and they should be lose and u can undo them with your fingers with or with out the socket and extension )
    5) when u are undoing the bolts u will have to hold the pan up pushing it against the transmission while u undo the last few and when they are undone try keep it level and put it on the ground (its a good idea to undo the bolts on the opposite side to u are first so its easier when u hare holding the pan in one hand and undoing the bolts with the other )
    6) once the pan is off take the old filter off and remove the rubber seal(this is stuck in reall good so it may take some time ) empty the oil into the bucket u used before and use a razor blade to remove the gasket and any old sealant that may be there as-well and wipe the magnet on the pan and then use the Brake cleaner to clean the pan( and if u want grab the shifter and move it up n down from 1st to park and it will loosen some oil too)
    7)then once all finished there get under the car with the new filter and rubber seal tap the new seal in with a hammer and put the filter in and then u put the pan on with a new gasket
    8) the bolts should be torqued at 11nm but u can just do it by feel ...like me
    9) once all back together degrease and gerni (if u got one ) and fill up with and aditives u gunna put in then oil should take 4.8l but if u got any aditives in there start with 4 liters and top up till its at full cold
    10)and then run till TRANSMISSION OIL IS HOT not the engine (u may need to go for a drive ) and then re check and ad if required and check for leaks when u add and in a weeks time check the level again
    NOW ! all done it should take you about an 2 hours took me an hour and a half (but im an apprentice and know my way around a bit more ) could take you guys longer maybe not best of luck guys... and maybe girls haha
    VS Executive 3.8
    Jan 2011
    cairns
    if there is anything i left out just tell me and ill add it into the post and ill upload some more photos if needed just gimmie time
    vs commodore
    Oct 2009
    Tamworth NSW
    Well done mate.A lot of people change their engine oil and filter,and forget about the auto trans filter which is just as important I think,and its not hard to do. If you can change the engine oil,you can change the trans filter.The only thing I do differently to you is the way I fit the new filter seal.I push the new seal onto the filter,put some clean transmission fluid on the new seal to help it go into the filter locating hole,then push the filter and seal together up into the filter locating hole.Ive done quite a few of these now,and Ive never had a problem doing it this way,but as long as she works,then thats the main thing.Good stuff mate.Cheers.
    VS Executive 3.8
    Jan 2011
    cairns
    yeah mate it is easy lol thanks for the extra add there probbly makes it easyer to do
    VR Senator
    Nov 2010
    never EVER let the gearbox run out of oil whilst its running, thats including in park.... so avoid the first step at all costs, just take the lines off and blow them out id say
    VS Calais S1
    Jul 2006
    Kadina, SA
    How often should this be done? I have never done mine but up until not long ago my car was serviced at the local holden dealer so I assume they would have done it at every big service.
    vr statesman 5.0 + vs exec s2 auto
    Mar 2006
    central coast, nsw
    Quote Originally Posted by RoboticCherry-Coke View Post
    i was once told by an auto transmission shop that is best to service trans every 2 years or 20 thousand kms .
    two-bit's Avatar
    two-bit is offline Hiding between the posts
    vs S pac series II
    Sep 2010
    Altona
    cheers man hoping to do my tranny this weekend god knows when it was last done, is it worth putting the stop slip stuff in? does it help with clunking?
    VS Executive 3.8
    Jan 2011
    cairns
    well stop slip made it a lil better i guess but im not sure about clunking lol but servicing it should make it better and stop slips like 18 buks a bottle so wouldent hurt btw dont take out the old filter seal its a bitch to get out and back in lol just leave it if u havent got alot of tools it will be fine if u leave it
    VS Executive 3.8
    Jan 2011
    cairns
    and i ran mu car whil it was running with the lines off it dident do anything so its fine to do not liek ur pingin it just idling n it takes like 4 sec lol
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    Quote Originally Posted by mwemy View Post
    I have been told putting the car in neutral will prevent any issues from doing the first step, infact it'll pump it straight out into a bucket or whatever and won't damage anything as no gear is engaged?
    VS Executive 3.8
    Jan 2011
    cairns
    well i had mine in park and nutral would be the same as and when it drains out the oil from the pan it dosent drain all the oil just a bit of it to make it easyer later on when you take the pann off so there isent so much oil in there and the car runs for max 10 sec and then the oild starts spraying so then you turn off the car
    '98 VT HSV XU6
    Sep 2011
    Tarneit, Melbourne
    Just to let u know if your doing a full refill the tranny will take 7.9 litres as a lot of the fluid is in the converter the 4.8l is the fluid in the pan only
    VS Executive S2
    Jun 2011
    Frankston
  15. #15
    Jaymz's Avatar
    Jaymz is offline Donating Member
    VS Exec 1996
    May 2005
    Hamilton, NZ
    Quote Originally Posted by SuperXU6 View Post
    True, but unless you have brought a brand new torque converter for the job (unlikely) there will still be oil in it.
    When i have done it i always dump in about 4 litres in and wait for it to settle then top it up. You never want to overfill or underfill the system.
    ProTip - If you do overfill the trans, get hold of a length of pipe that can fit down the filler tube and a syringe and use it to suck out the excess fluid. It is a bit of a pain in the ass, but better than stuffing the trans.
    I will try find some pics tonight of what the colour of the oil should and shouldn't look like for you all to see too.
    You won't like me when I'm angry. Because I always back up my rage with facts and documented sources. - The Credible Hulk
  16. #16
    VR Executive 3.8
    May 2011
    Great write up, will give me something to do tonight
  1. Auto Transmission Thump In Gear Change
    By B3NKobe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2011, 01:45 AM
  2. 92 VP Transmission Won't Change Into 3rd
    By jaarze in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2011, 09:32 AM
  3. VE SV6 200 H0 Motor Auto 2008 Transmission Change of Auto oil
    By markholland in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-01-2011, 05:24 PM
  4. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  5. Transmission oil change
    By satos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-05-2005, 09:08 PM
