Results 1 to 25 of 25
Like Tree1Likes
  • 1 Post By walesy
Thread: How To Install AU Thermo Fans Into VN-VS V8
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Default How To Install AU Thermo Fans Into VN-VS V8
    Tools Required/Recommended
    Nice Clean Work Bench (To Fit Shroud And Radiator Would Be Ideal)
    Hole Saw (A Collection Of These Is Best)
    Hack Saw
    Dremel Or Similar File
    Small Drill (See Step #16 Otherwise A Cutting disc On The Dremel Is Fine)
    Chalk Or White Marker (Chalk Is Easier To Clean Off)
    Auto Electrician (For the Wiring)
    Patience And Half A Day
    Firstly this is the radiator that the fans will be attached to. Find the centre of the radiator and the shroud. Make sure to line these up when test fitting after every cut. Lay the fans over the radiator and you’ll see where most of the cuts need to be made. If you have an Auto, you will need to remove the Trans cooler fittings (cut off) or they can be left on. Mine were left on but the bottom one was bent out the way to avoid the fan possibly hitting it when under full load. Once all these steps have been followed, there may be some trimming needed with a Dremel or file.
    Pic #1
    Cut off the two end supports on the top edge of the radiator.
    Pic #2
    Pic #3
    How it looks without the supports
    Pic #4
    Cut hole for Top Hose outlet.
    Pic #5
    Pic #6
    Cut the filler neck hole. Start with a hole saw, then cut straight down the edge with a hacksaw.
    Pic #7
    Pic #8
    It should look like this. More filing may be needed after test fitting.
    Pic #9
    Cut off Driver side and Passenger side lower supports. These foul on the chassis rails.
    With Support Passenger Side
    Pic #10
    Without Support Passenger Side
    Pic #11
    With Support Drivers Side
    Pic #12
    Without support Drivers Side
    Pic #13
    Now cut the radiator hole out. Find a hole saw about 5mm bigger than the inlet (or 2-3mm bigger than the hose) and drill it out. Make sure to lay the shroud over the radiator and measure as good a possible the centre of the inlet. Again it may need filing to touch it up if you’re not 100% accurate.
    Hole Started.
    Pic #14
    Hole finished.
    Pic #15
    These to slits need to be cut to hold the bottom of the radiator in. The brackets on the bottom of the radiator will slot into them. See First pic for the clips and pic #18 with them fitted.
    Pic #16
    Now to mount the top. I used Nutserts to srew into but a normal nut and bolt can be used also. Pic below is of the nutserts installed just measure and drill the holes for the shroud accordingly. The holes on the radiator are elongated so if your off by a little it won’t matter too much.
    Pic #17
    Now test fit everything file more where needed or you think may need more room then fit to radiator. This is how mine fitted up in the end, the bottom hoes could of done with a little more filing as it was a bit tight but fitted up ok as pictured.
    Overall Fitment
    Pic #18
    Pic #19
    Top Hose
    Pic #20
    Filler Neck
    Pic #21
    Bottom Hose (Note: The cooler outlet bent down to clear the fan, this needed to be bent up slightly as it was hard to get the clamp on the bottom hose. Adjust as needed.)
    Pic #22
    Now turn on the fans while on the bench to see fit they foul on anything. Turn by hand initially then once your satisfied that it is clear then power up the fans as they will flex at high speed which could cause them to hit.
    If everything is fine fit back to the car and either get them up wired to the ECU or use a Davies Craig Thermo Fan Switch. Either way consult an Auto Electrician about this as you will need decent wiring for these because they draw big once at full speed.
    Fitment to the car. The A/C hose may need to be bent away a little and the Charcoal canister will need to be moved or bent to make room. Other than these two things it should slot in without any issue.
    Pic #23
    Pic #25
    Pic #26
    Notes:
    You will need shorter bolts for the water pump pulley. Any fastener shop or auto store can match the bolts you have, just make sure the ones you get are slightly shorter (thickness of clutch fan hub).
    From what I have found the fans flow around 3000cfm. I only have one working at the moment off the V6 thermo fan plug and that is turning on at about half way on the gauge (Factory 106 ecu setting) for the other fan I will get a temp sender put in that turns on at about 90 degrees.
    The sender will turn on the first fan for low speed (90 degrees) and the ecu turns on the second for high speed(106 degrees).
    VS SS
    Jan 2009
    WA
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    No worries, I was the same looking for decent pics of how this was done. That is why I chucked a thread up on it.
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    How do you go with the bit that the clutch fan was attached to,im told you need shorter bolts otherwise they hit the water pump or something
    WTB:VR/S HSV 250km/h speedo cluster
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    You can use v6 water pump pulley bolts and they work fine.
    But yes need shorter bolts just buy some from bolt joint or repco or the like
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    I just replaced them with shorter bolts. Take out the original ones and take them to your local fastener shop and ask for the same ones but slightly shorter. Only the thickness of the clutch fan hub needs to be taken off the bolt.
    vs caprice
    Dec 2010
    brisbane
    do u no how much cfm the au fans give m8 looking at doing mine saw ur post when im looking at doing a single 16 inch atm with 2800 cfm
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    From what I have found they flow around 3000cfm. Twins are probably a better option because you can have one to come on at about 90 degrees then the other at around 106 (the factory computer is set at). I only have one working at the moment off the V6 thermo fan plug and that is turning on at about half way on the gauge (Factory 106 ecu setting) the other I will get a temp sender put in that turns on at about 90 degrees for the first fan. Then the ecu turns on the second if the temp gets any higher. Added this info to the first post now too.
    VQ STATESMAN
    May 2006
    Nice work Nick will be using this in the coming weeks
    Its standard height i swear officer get your tape and check :-)......... pump up faster god dam you!!!
    Check out my Stato
    http://forums.justcommodores.com.au/...ad.php?t=32773
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    VR Senator
    Nov 2010
    what if u wanted to do this to an auto?, is there any room for the cooler hoses at all ?
    HSV VS Senator LS1
    Feb 2009
    Adelaide,South
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Quote Originally Posted by mwemy View Post
    Just. It would be very close. I have run an external cooler anyway. More efficient than the one in the radiator.
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Quote Originally Posted by TUFF ST8 View Post
    like my setup better :P
    So do I, it looks shinier lol. But with out spending good money on the fans to get the same CFM, I like this option better. Plus it looks factory, just what I wanted.
  15. #15
    VQ STATESMAN
    May 2006
    Fitted it up today Nick good thread easy to follow and pics are good too.
    Check out my Stato
  16. #16
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
  17. #17
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    good write up man this will b my next project over the weekend.
    tho just wondering wen u say uve used the V6 thermo plug where is it in the bay? also ive been told u need 2 enable it in the memcal 4 the thermos 2 work through the ECU, does that mean both fans will work using the ECU or do i still need 2 get a temp sender so the 1st fan turns on at 90*? how did u go about this?
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  18. #18
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Not sure if a factory 5ltr will have this plug but it should be along the rad support if there. I converted mine to a V8 so it had the plug there. If you plug the fans in to that they will turn on at 106 (I think, or what ever the ecu is set at). I have only got one fan wired into that one and will get the other fan wired up. I'll put a sender (90degree) in it and the low speed will be that one and the ECU will turn on the second one for high speed. So basically the ECU is already set to turn on the thermo fans. Hope this answers your questions.
  19. #19
    wrx884's Avatar
    Mar 2006
    i dont think the plug is there that i can see i mayb wrong but there r wires that run along the radiator support that i assume could b them. do u know the wiring colours u used? also do u have some more info on the sender (90degrees) on how 2 hook that up, cost and where u get them from? assuming it has 2 b put inline with the ECU wires also?
  20. #20
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Quote Originally Posted by wrx884 View Post
    I'll check the colours, it's just a 2 pin plug. As I said, mine was a V6 that's why mine had it there ready to go not sure if Factory V8's have them. No info on the sender yet as I am yet to fit it. When I do it I'll add it to the write up with part numbers. I am getting a local mechanic to do it as he has done a couple and said something about putting the temp sender where the knock sensor usually goes. Not sure if I heard him right though. So what ever thread that is and go to your local parts store and ask for a Tridon book, find one that has the same thread and turns on at 90 and off and what ever degrees below that.
    Some people wire both the fans to the one signal from the ECU then get that adjusted to 90degrees turn on. The mechanic that is going to wire up mine said that having both come on all the time puts a strain on the charging system (alternator) and from what I have read people have had this issue. So this is why he suggested/I want them to come on independently so that the second fan only comes on when really needed.
  21. #21
    wrx884's Avatar
    Mar 2006
    i had a play with mine and hooked them up 2 12V and yeah i see wat u mean both fans seem 2 draw a shit load of current on start up so im thinkin i may wire them both up but have a 5-10sec delay so the strain isnt so bad.
  22. #22
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    a VT 5litre uses a 120amp altenator due to the massive load of the thermo's
    VN - VS 5L uses 85amp
    unsure about the V6 amp but I'm pretty sure its nowhere over 100amp thats why its straining
  23. #23
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Yeah they do. Not a bad idea about the delay timer. Let us know how you go with that and even how you wire it up too. I'll add it to this thread.
    Quote Originally Posted by Munz View Post
    A small alternator on the early V8's is the main reason for the strain, you right. But when it comes time to replace the alternator I'll go to a 120amp one. But for now I'll stick to this one though. The V6's only ran the one fan so there was probably no need to go bigger than 100amp. Running 2 is a different story, lol.
  24. #24
    wrx884's Avatar
    Mar 2006
    the 85 amp should b more than enough, ive read up so far and found the fans draw around 25-30amps each so 50-60amps in total (thats if both fans running at the same time) and its only on start up that they need this amount of amps.
    Bit like ur audio just make sure u do "the Big 3" gound upgrade it'll help out a massive amount.
  25. #25
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    cheers for the write up! i just bought a set of AU thermos for my blown SS :-)
    Going where no late model stato/caprice has gone before.... GAME ON!!
  1. EF thermo fans onto VN V6
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2009, 04:35 AM
  2. WTB EL to AU Thermo Fans
    By Holmez in forum Swap / Wanted to Buy / Trade
    Last Post: 13-11-2008, 05:40 PM
  3. Thermo fans
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2007, 03:19 PM
  4. thermo fans
    By urmyho in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2006, 10:44 AM
