Replacing the Tensioner Pulley - V6
FXST01
The Grey Man
Perth, WA
VP V6 Exec
Tools needed:
18mm socket and bar or 18mm spanner
Locktite
1. Remove fan belt by using the 18mm spanner and rotating the pulley assembly anti clock wise.
2. Undo the bolt holding the tensioner pulley on, use the 18mm spanner and turn the bolt clockwise to undo the bolt (the bolt is actually right hand threaded.)
3. Place new pulley onto shaft, drop some loctite onto bolt and screw in (anti clockwise) Manual states 40 - 60 Nm is the torque setting.
4. Rotate pulley anti clock wise again and replace fanbelt.
5. Picture of comprehensive instructions that came with new pulley.
deathsminion
Chrgd,Coold,Twinthrot'in
GT42R forced JZA80 Supra and VT Wagon
Thanks man, this will be useful in a few days time. Damn that is one clean motor. :)
J
jahbull
Guest
thread
thread rest assured u r a good bloke thanks :thumbsup: :thumbsup:
vpete
North Qld
VQ Statesman 5.0 litre
Do you know you don't have to replace the whole pulley if it's only the bearing buggered? I replaced mine a couple of weeks ago for the price of a $6 bearing! Holden would have you believe that the whole thing comes as a complete assembly.
Cheers..................Pete! ;)
krypt0n
89 VN Commodore
Damn! this could have saved me $50 a while ago lol
vxcalais_01
VX V6 Calais 3.8 2001
Did use any thread locker on this one ? (Sorry mate, early in morning and i didnt read your mention of loctite, sorry). Would you place any grease on the thread ?
Also are the part No.s the same for the VX series 1 ? Good write up.
boomnvn
SOLDER, NO CRIMP.
39
Croydon
www.KungFuKustoms.com
VT Exec S1 V6
vx will be differant as it is an ecotech motor.
