Results 1 to 7 of 7
Thread: HOW TO - VT-VY S1 Foglight install
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    Default HOW TO - VT-VY S1 Foglight install
    I just completed setting up my fog lights properly. So made a little write up on how to get it done properly. Enjoy
    As the title says this is a DIY foglight install, BUT only certain models will have the loom already in the car.
    Tools Required
    - #2 phillips head screw driver (long and a stubby one)
    - Soldering iron/solder
    - electrical tape/heat shrink
    - Drill with a 15mm or so drill bit
    - File (round and a flat one)
    - Side cutters
    - Holden T5 dash cluster bulb
    - Foglight relay (aircon relay is the same)
    - Factory foglight switch
    - Fog lights (genuine or aftermarket)
    - Multi meter
    Step 1
    - In the engine bay fuse holder, flip the lid over and hunt down the "Fog light relay" as seen in the pictures below. Once located, fit your relay straight into the plug
    (NOTE - To make sure your car has the fog light loom check if there is metal pins in the fog light relay posision, if not, ignore the rest of this DIY as its useless for aftermarket foglight looms)
    Step 2
    - Remove Dash facia (2 screws directly below drop down pocket under rubber matt and remove. Then 2 screws at bottom of the top dash section, drop the fuse cover below steering wheel and remove another 3 screws, finally vertical to the speedo cluster there is 2 more screws (stubby screw driver needed)
    - Once dash is removed, locate headlight switch plug, taped to this will be the foglight switch plug, untape and pull out.
    - Now grab your drill and drill out a 10mm~ hole directly below headlight switch hole in the dash fasia.
    - File out slowly untill the foglight switch clips in neatly and plug in the foglight switch plug ( i traced the outside of the plug onto the dash and used cut/polish to remove the lines once complete)
    Step 3
    - Remove the front bar ( Open bonnet, 3 screws across the top, 1 screw in each wheel arch, turn the wheel to full lock each way for easy access to each side)
    - On each side below the headlights will be a plug with 2 wires connected taped to the factory loom (as pictured below) remove tape and pull it down. My picture doesnt show the factory plug as i had to cut it off to fit aftermarket foglights, genuine and SOME aftermarket fog lights use the factory plug.
    - Either plug your fog lights in (genuine) or cut off the plug and wire up your fog lights. (Test for positive/negative via multi meter on the wires, turn the switch on you mounted in the dash to test
    - Mount the foglights into the front bar and aim the beams correctly
    Step 4
    - Remove Dash cluster (2 screws, one in each corner) Locate globe holder that lines up to the fog light symbol (Seen in photo below) and insert globe in position and refit cluster
    - Test out the foglight switch, flick them on and off, check cluster globe, fog lights is all working
    - When all confirmed working throw the front bar and dash facia back on and enjoy your 100% factory looking foglight install.
    VY SS S2 Utility 2004
    Dec 2009
    Melbourne, Inner.
    cheers for this write up! i have a vy s 1 ute so it was all plug and play for me, but because my aircon isn't working i've saved a trip to holden by you saying that the aircon and foglight relay are the same! cheers!
    livin' the low life.
    Parabola's Avatar
    Parabola is offline California Dreaming
    XR6T
    Sep 2010
    Hervey Bay QLD
    awesome write up, thanks mate
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    VZ Crewman L76 M6 & Calais V L76 S/Wagon
    Aug 2007
    NSW
    1999 VT Commodore Acclaim
    Mar 2011
    Echuca
    vx commodre series 2
    Dec 2011
    barossa valley
    hey just a quick hint to save some time all the vx commodores i have done this too you dont have to remove cluster to insert thhe globe as they have been fitted at factory
    VX Exec Wagon
    Jan 2012
    Katoomba
    Default Vx fogs
    Hi all, my first post!
    Great lesson btw, very informative.
    I have pretty much followed it, except the part with the dash light, as per a reply saying not needed on the VX. Anyway, I'm not getting a close on the control circuit of the relay. When I bridge the load terminals the lights energize, so that side is good. I've checked continuity of the switch, and I've bridged the terminals of the socket. I've also changed a few relays around so I'm starting to assume that the globe might not be in there, and that it is in series with the switch to energize the relay???
    I'd pull the cluster out except there's a phone base thats in the way, but if I have to...
    All advice much appreciated.
    Dronno.
  1. Foglight Help VT
    By filthgrinder in forum Electrical Wiring / Questions
    Last Post: 02-06-2009, 02:01 PM
  2. Foglight help :(
    By filthgrinder in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-05-2009, 09:12 AM
  3. VS foglight
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2008, 07:10 PM
  4. VY Foglight indicator
    By andtan in forum Electrical Wiring / Questions
    Last Post: 14-10-2007, 06:49 AM
  5. WTB vt hsv foglight (brisbane)
    By 180sc in forum Swap / Wanted to Buy / Trade
    Last Post: 22-01-2007, 01:43 PM
