Results 1 to 2 of 2
Thread: How to fix that struggling vl calais pop up lights!
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Default How to fix that struggling vl calais pop up lights!
    Well hey guys.
    Been working on the car today, and the calais front has been playing up a fair bit and not lifting and shutting properly. It seemed a little tight.
    So here we go on How to fix it.
    Remove just the middle section from the car.
    Remove the motor and linkages from the front itself.
    Now when you were removing the linkages you proberly realised that some of the little pieces were hard to move. (NOTE: there are 6 pieces that are fixed, 3 on either side that hold the eyelids. DONT force them to move because you will break these.)
    Ok now for the ones that are ment to move but are tight or stuck. Grab some carby/throttle body cleaner, give them a spray and move them from side to side. Once you are happy with how free it is, Spray a bit of CRC on the rod and move it back into position. Your done on that one! Move to the next. Once you have done all of them, put it back together and bingo. You fixed it.
    Now your pop up lights should be easy to lift up and down when you turn your lights on and dont struggle as much.
    Hope this helps some of you out. I will take some photos and post them up. Also I take no responsibility for your mistakes, breakages, or any of the like! You do this at your own risk!
    VZ Crewman L76 M6 & Calais V L76 S/Wagon
    Aug 2007
    NSW
    I had one of those Babies back in the 90's & mine partially seized up as well.
    I basically dismantled the whole assembly, drilled & tapped the pivot bushes to allow small nipples to be screwed in to grease them occasionally.
    Be amazed how much accumulated road grime gets caught in them & stops them working.
  1. Vl struggling when i accelerarte
    By sam515 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-03-2010, 08:53 PM
  2. VS struggling
    By Shtato in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2009, 04:45 PM
  3. [SA] vt/vx centre lights with map light and.... calais courtesy lights wiring/set up
    By callum_88 in forum Parts And Other Items For Sale
    Last Post: 11-05-2009, 07:58 PM
  4. struggling VR
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-04-2006, 05:12 PM
  5. Help, My Vs Is Struggling!
    By jerome_boy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-03-2004, 06:16 PM
