Results 1 to 7 of 7
Thread: Changing The Battery Or Buttons
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Default Changing The Battery, Buttons Or Key Blade On VE-VEII Remotes
    This How-To can be used to change the battery, replace the buttons or replace the key blade for a VE remote. The flip keys should be the same as the only thing that is different is the blade part of the key, the head (button part) is the same.
    Tools Needed
    Small Screwdriver
    Depending on what you are changing you will also need.
    New Battery.
    New Buttons.
    New key Blade Cut To Suit Your Car.
    Step 1
    This is what you'll start with.
    Step 2
    Find the small cut out on the side of the remote. Put the screwdriver into this slot and pry it towards the key blade.
    Step 3
    Keep prying until you can pull it apart with your hand.
    Step 4
    This is what it will look like.
    Step 5
    You'll be left with just the head. This is as far as you need to go to replace the blade. If you are replacing the battery or buttons, read on.
    Step 6
    Stick the screwdriver into the top of the head. Find the gap and push the srewdriver down to lift the buttons away from the backing. Keys that haven't been done before will be hard but once you get it to move and make the gap bigger it will get easier.
    Step 7
    Once it's apart this is what it will look like.
    Step 8
    Changing the battery - Pull the battery out and put your new one in.
    Changing the buttons - Take the board out of the other half and put it into your new buttons.
    Step 9
    Reverse the steps to reassemble. Check that it works and your done.
    Notes:
    The battery can be found at anywhere. It's nothing special, Holden will sell it as a genuine part but it's just a relabelled energizer. Energizer Number is ECR2032BP.
    The buttons can be found on ebay for as little as $5-$6 delivered or at any Holden dealer.
    VZ Executive
    Aug 2004
    Hope I'm not bothering anyone by bringing this post up.
    I appreciate your how-to, even though I actually found it after I spent all afternoon working out how to do it.
    Problem I have now is the key doesn't work. I assume you didn't have this problem??
    I can stand next to my car pushing all the buttons and it's like it isn't even my car. It's frustrating!
    Any suggestions?
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    I haven't had this problem and have done 2 keys. This may sound stupid but check that the battery is in the right way around. You can see in step 7 which way around it should be.
    VZ Executive
    Aug 2004
    Yeah I didn't take the battery out but it might be dead as it hasn't been working too well lately. I'll try a new battery.....
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    VZ Executive
    Aug 2004
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Hmmmmm, that sucks. What was the issue?
LinkBacks (?)
  1. Changing battery in remote now trouble
    By cuckoo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2008, 07:59 AM
  2. Cyclone c-300 Changing Battery Problem
    By TheOne in forum Electrical Wiring / Questions
    Last Post: 23-01-2008, 01:29 PM
  3. Do I need to reset the computer after changing the battery
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-04-2007, 05:34 PM
  4. changing the battery
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2007, 12:33 PM
  5. what to do after changing battery...
    By MY_95_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2005, 09:13 PM
