Results 1 to 3 of 3
Thread: How to remove VX grille
    t1mm3hh's Avatar
    t1mm3hh is offline VX S PAC
    2001 VX Commodore S PAC
    Apr 2011
    Caloundra
    Default How to remove VX grille
    Over the last couple of days I have figured out a way to remove the VX grille from the front bumper.
    I am demonstrating on a vx s pac.
    WHAT YOU WILL NEED:
    - A grinder off some sort, with a wheel to cut through plastic
    - Sand paper
    - Bastard file
    - Screw Driver
    Step 1: Removing the front bumper
    I found it easiest to take off the bumper. There are 7 screws that you will need to remove.
    The 3 on top of the bumper when you open the bonnet, and there is 2 on each front wheel arch (one down the very bottom and one in the middle)
    Once they are removed, simply pull off the bumper with a bit of force as there are a series of clips to hold the bumper in place.
    Step 2: Cutting out the fins
    The fins I am talking about are these ones:
    To cut them out, get your grinder and cut out each fin as close as you can to the outer edging without cutting into the bumper. WARNING: BE CAREFUL NOT TO CUT INTO YOUR PAINT WORK!
    Once you are done, it should look something like this:
    Step 3: Sanding
    For this I used an orbital sander and a bastard file.
    Simply sand and file down the left over of the fins until it is flush.
    You will end up with something like this: (I have not completely sanded and filed down the left over fins as I am putting mesh infront of them, but the front of the grille is what it should look like all over)
    Step 4: Finishing up
    You can rather leave the black plastic as is, you can paint over it by using masking tape to cover your paintwork, or you can put some mesh in as I will be doing.
    Once finished, put the bumper back on and you're done!
    Good luck!
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    nice work lad, when you put the mesh and please chuck up some over all finished pictures. Im keen to see what it looks like before i give it ago
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    t1mm3hh's Avatar
    Apr 2011
    Caloundra
    Pics are up at - MY VX SexPac
  1. HELP! How to remove VX grille!
    By t1mm3hh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-08-2011, 09:01 PM
  2. To remove rear muffler or not to remove?
    By 1FATVZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-11-2010, 02:57 PM
  3. Grille mod
    By CANYONERO in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-07-2008, 11:09 PM
  4. Replies: 25
    Last Post: 21-02-2008, 05:42 PM
  5. aftermarket grille?? or good grille?
    By vt_on_20s in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2007, 09:38 PM
