Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Like Tree2Likes
Thread: HOW TO: change a serpentine belt (vs)
    VS dream is offline Lets go cruising!
    VS Executvie SeriesII
    Oct 2010
    Frankston, Victoria
    Default HOW TO: change a serpentine belt (vs)
    The serpentine belt is the main belt on the front of the engine which runs around a set of pulleys.
    Its actually very simple to change despite how complicated it can look.
    I did this on a vs ecotec not sure if its the exact same with other models (vn, vp vr, vt).
    What you need:
    - Replacement belt
    - Spanner or equivalent
    - Pen & paper
    - 10 minutes
    1. Buy the right belt - you can pick these up from supercheap or autobahn for around 30 - $50. make sure you dont just pick one unless you know exactly which suits your car, speak to someone.
    2. Draw yourself a diagram of the way your belt loops around the pulleys.
    3. Take out a spanner or socket wrench set and locate the tensioner pulley. In order to loosen the belt you have to rotate the tensioner pulley ANTI-clockwise. As the tensioner is pushed down it gives the belt some slack. After taking it off the top left pulley you can remove this is any old fashion.
    TENSIONER PULLEY:
    4. Get out your new belt and diagram and feed/loop the new belt in, making sure the threads and teeth on the belt line up and everything sits nice and smick, leaving the belt off the very top pulley.
    5. Loosen the tension on the tensioner pulley again (rotate the tensioner pulley) and put the belt over the last pulley (top left).
    6. Check back to your diagram and make sure the belt is on correctly at each pulley, to make adjustments just loosen tension.
    9. Start your car and idle just watching the belt to check everythings running nice and smoothly. Then run it through the rev range up to 5k, there shouldnt be any problems but its just a precaution.
    If you have any problems feel free to PM me
    NOTE: any damage or injuries caused are in no way my fault. i take no responsibility, this is just a guide.
    Ps. Taking/posting pictures tomorrow its too dark now
    Originally Posted by crewsy
    Non turbo, normal POS lancer.. although he has a G-reddy sticker on the back so it must go hell fast
    FstStig's Avatar
    FstStig is offline Diagnostician
    03 VY Acclaim / 93 VR Calais 5L
    Sep 2008
    Newcastle/Central Coast, NSW
    Wow you must be a mechanic thinking 30mins... Takes about 5mins and that is with a new belt.... New Belts can be harder to put on because they have not stretched. If people are having trouble getting it over the Alternator Pulley, try and get a little bit of the belt onto the Alternator Pulley, then with another spanner or socket, put it on the Harmonic Balancer and turn the the balancer Clockwise, while still holding down on the tensioner.
    Thanks for the Guide either way
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    drewVHSS's Avatar
    drewVHSS is offline Donating Member
    '83 VH SS, '79 Green VB SL '92 S2 VQ Caprice
    Apr 2010
    Gosford Central Coast
    HA! Best time i've managed is at 2am at east gosford shops in the pouring rain.
    My neighbour at the time Stevo had a VS that kept spitting the belt, problem that night is his bonnet cable snapped.
    3 mins 13 seconds using torch light, a pissy shifter and doing it from underneath on wet gravel road after being dragged out of bed with the "help me mate" call with the promise of $50 to get him up and running so he could complete his shift.
    Mind you i'd had heaps of practice on his car after having to fit new belts and refit existing belts for 3 weeks cause he wouldn't fork out for a new idler pulley so it kept throwing belts before that night.
    Oct 2010
    Frankston, Victoria
    gee sorry mate, just put 30 because some people might like to draw a really nice picture
    EDIT: just got the mechanic joke hahaha
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    What I like to do is get the belt all around the right way etc.., except for the water pump, and then flex the tensioner and get the belt onto the water pump.. Always used that method and found it the best..
    Commodore, LOLWUT, My Car Has A Dirty 4A..
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    djdomohudson's Avatar
    djdomohudson is offline Mad frogs
    VT Executive 3.8 v6
    Aug 2012
    Werribee, VIC
    AWESOME!!! I was struggling there for a minute...
    *takes laptop outside to follow steps again and do it in like 2 seconds as I've been scratching my head over this for over an hour now *
    Dropjeslover is offline Shit happens
    VS V6 Executive
    Jan 2013
    Emerald
    Might want to add somewhere that the tensioner pully bolt is left threaded. To undo the bolt, turn it clockwise!
    I didn't and ####ed up the thread in the tensioner arm
    Put the bolt back in with locktite on it, now trying to figure out how to get the tensioner arm to lower...
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by VKCOMMO View Post
    Ive also found that this is by far easiest way to get them back on.
    VS_Pete's Avatar
    VS_Pete is offline Donating Member
    Dec 2007
    Me too....................................
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    Quote Originally Posted by c2105026 View Post
    "when you find a mosquito has landed on your balls, you will realise not all situations require violence"
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VS V6 Executive
    Jan 2013
    Emerald
    I've solved my little problem too, thread sealant in the remaining thread, let it cure for 15+ hours. Belt all the way around, except the water pump as it doesn't have an edge on the pully. Use the bolt to get the arm moving the first part, last bit with a crowbar and then slide the belt on the water pump
  1. serpentine belt change
    By te_rarawa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-08-2011, 04:12 PM
  2. vt serpentine belt on my vs?
    By mynameisearl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2009, 04:59 PM
  3. v6 Serpentine Belt
    By bradson in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-06-2006, 09:40 AM
  4. VT serpentine belt change
    By MXBM in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-05-2006, 06:44 PM
  5. serpentine belt
    By drd180 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-03-2006, 11:20 AM
Tags for this Thread
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
