Described here is the way I changed over a 2009 VE Commodore external mirror assembly, so its definitely the unofficial version.
In February 2011 I purchased a GM Genuine mirror assembly (including motors and wiring) for about $AU120 from my local Holden dealer. A grey colour-coded inset was supplied, but I re-used the colour-coded one from my damaged mirror.
Tools required: Small Torx set, small Flat and Philips Screwdrivers.
Method:
Open the door and window.
Remove all screws from the door trim, including two hidden under the door arm-rest.
With a flat screwdriver, remove the small plastic cover near door handle.
Remove the revealed Torx screw.
Carefully lift up the door trim from the top plastic clips on the window edge.
Prise the whole door trim out at the vent end, near the hinge.
Carefully remove the plastic plate behind the mirror by pulling it down and out.
Remove the wiring connector. Unlock it by pressing in the plastic tag on the connector.
Remove the two Torx screws that secure the mirror assembly.
On the door seal rubber moulding, remove the plastic clip near the door hinge.
Pull back the seal, unclipping two clips on the door frame.
Remove the third Torx screw that is under the rubber door seal.
Carefully remove the broken mirror assembly by pulling it out and downward.
Insert new mirror assembly into the top of the door frame rubber.
From the inside, the two plastic lugs on the assembly should align with holes in the metal.
On the outside, ensure the mirror assembly fits snugly in place.
Replace all screws and reverse the above procedure.
To put the plastic colour-coded inset in the mirror assembly:
Place the bottom edge of the colour inset against the lower edge of the assembly.
Line up the inset hooks on the bottom with the holes in the mirror assembly.
Rotate the insert toward the top edge.
Flex the inset and push in the pointy end into the assembly.
Carefully push down the top edge into the groves around the assembly.
Thanks
I smacked my mirroe the otherday.
i now need to do this.
Good writeup. I learnt what you desccribed the hard way...
HIDs.....LEDs..... DRLs..... CHEV Badges..... ->
