Page 1 of 3 123 LastLast
Results 1 to 25 of 51
Like Tree10Likes
Thread: How To Paint your Engine Cover
    Drawnnite's Avatar
    Drawnnite is offline Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    Default How To Paint your Engine Cover
    now before i start this was done well is being done on an Ecotec engine cover.
    this process is transferable to other engine covers and other coverings such as rocker covers, air and fuse boxes etc.
    TOOLS and MATERIALS
    1. Paint. - Primer, for Base coat
    - Main Colour and any other colours you may want to use.
    - Clear Coat
    - Tinned Paint for those pesky areas
    2. Sandpaper. Wet and Dry 240,320 and 800+ grits
    3. Masking Tape
    4. Stanley Knife (sharp)
    5. Dust Mask
    6. Degreaser or Wax and Grease remover
    7. Paintbrush
    8. Patience
    How To Paint your Engine Cover-degreaser.jpg How To Paint your Engine Cover-more-paint-tape.jpg How To Paint your Engine Cover-paint.jpg
    PROCESS
    1) take your engine cover off your car if not already done so, or not using a spare one.
    2) CLEANING
    - Clean the Cover with Wax and Grease remover, or simply use Degreaser like i did.
    - Follow the instructions on the pack. making sure the cover is pretty much spotless upon completion.
    - Wipe down afterwards if required.
    How To Paint your Engine Cover-cleaning.jpg How To Paint your Engine Cover-wiping-clean.jpg
    3) SANDING
    - Using your 240grit Paper sand the whole cover. i chose 240 grit to start with as it cleared off most of the old paint
    - after using the 240, use the 320 Grit paper to smooth it out a little bit.
    - you can use finer grit papers here if you wish.
    -an electric sander as seen on page 2 is your best friend
    4) PRIMING
    - The next step is the Base Coat, whereby you Prime the Surface. wearing a dustmask is highly recommended
    - Make sure the surface is clear of all dust and bugs, leaves etc with a rag or duster.
    - in a Well Ventialated area and using a stand (i turned over a box) place the engine cover.
    - spray 3-4 light to medium coats of your primer, leaving about 10 minutes between coats
    - More coats can be applied, and a very light sanding inbetween is highly recommended.
    5) PAINTING
    - Now the Fun begins. If you are painting just the solid colour. follow along from (a)
    - Lightly Sand the Surface first
    - Paint the areas you want as a different colour first. a few coats, 2-4 should be plenty. leave 10 minutes between coats, sand between coats if required.
    - once dry, Tape up the areas you want to be Kept this colour. such as works, symbols and other areas (like the "pipes" and writing on my cover)
    - Cut these to shape with the stanley knife. take your time to get it correct.
    - (a) once you are all happy with that, sand back the rest of the cover lightly with 320 grit.
    - now paint with your desired colour. 3-4 light-medium coats should be plenty, sand inbetween if required.
    - if you are unhappy with the colour sand and recoat in a different colour if required
    How To Paint your Engine Cover-chromed.jpg How To Paint your Engine Cover-taping-1.jpg How To Paint your Engine Cover-taping-2.jpg How To Paint your Engine Cover-black-painted.jpg
    6) UNTAPING
    - for those that have done multi colours, take your tape off after the paint has dried, this should peel off easily.
    - if the lines are not 100% perfect just touch them up with some hobby paint, or spray paint into a little tub and use with a fine paintbrush.
    - also use this paintbrush for wordings such as that of "sequential injection" which it is impracticle to tape up.
    - you can repeat the taping and paint process multiple times for different lines if required (pics of this will be up soon)
    7) CLEAR COATING
    - once you are happy with the results of your painting it is time for a clear coating.
    - this is done the same way as the painting, in a well ventilated areas, multiple coats (3-4) leaving time to dry between coats.
    - if required you can sand very lightly inbetween coats with some 800+ grit paper
    8) FINISHING
    - now stand back and admire your work.
    - put back onto the engine of your car. use new grommets if you wish (about a $1 each from Holden)
    pretty much how it can look. i just need to clean it up a bit more and then it is 100% done.
    how it looked in car:
    NOTES
    i grabbed a 2nd engine cover from the wreckers ($15 =P) for this project.
    took me about 7 weeks all up. i did about 1 stage per weekend, and had a few mistakes. single colouring should take 2 weekends. 1 to sand/prime/colour 1 to clearcoat.
    i was unhappy with the intial dark grey paint as it looked blue, thus i sanded it back and repainted as black, to match the car
    A Texta of the Same Colour is your Best Friend for hiding mistakes. (im my case, black texta)
    if doing rocker covers i would highly suggest changing the rocker cover gaskets. and put them in the correct bloody way! =P
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
    Vs Commodore Executive
    Sep 2011
    Gold Coast
    calais06's Avatar
    calais06 is offline Donating Member
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    VS UTE, HT MONARO REBUILD
    Dec 2010
    it's best if you buy heat resistant paint because it wont flake off. just get some engine paint thats all it used.
    Heres mine, i deleted the text and also filled in the strips and then painted it with black and tried out my air brushing skills on it. what do you guys think?
    I dont even run it on my car though. dont really like the look of engine covers lol.
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Quote Originally Posted by Shooter 88 View Post
    Oh thats pretty cool!
    Reason I was asking is cos my friend wants it colour-matched coded to his bright yellow car, and can only get a different shade of yellow in engine paint.
    Thanks
    Dec 2010
    you can use other paints, but if you do get a heat resistant clear to go over the top that way it will protect it.
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Painted 2 Engine Covers with Just a couple of layers of normal Flat black and seems to hold up well! even did rocker covers with a couple of layers..
    1 engine travels 2000+ weekly and is holding up well..
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    you dont require heat resistant paint. just what i had at the time =P
    the chrome on there is just that aus export stuff. came up awesome.
    and that dark blue/grey is also aus export paint. i just didnt like the colour.
    hoping to paint the stripes on it this weekend. clean it up and get the near finish pictures up.
    then just get a paintbrush, some paint and "perfect" it and then be done with it
    probably get a set of rocker covers from pick a part and do them next.
    and that airbrushing looks awesome.
    how did you fill the lines etc in?
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    I painted my cover with acrylic while I was touching up the front spoiler. Simply rubbed back, undercoat, rubbed back then acrylic colour and clear. No probs with paint peeling -v the plastic cover doesn't get hot enough. Details were just hand painted.
    It would look a lot better if the rocker covers matched but I don't have a spare pair laying around.
    Attached Thumbnails Attached Thumbnails How To Paint your Engine Cover-014.jpg   How To Paint your Engine Cover-013.jpg
    Dec 2010
    Quote Originally Posted by Drawnnite View Post
    and that airbrushing looks awesome. how did you fill the lines etc in?
    to fill in the lines i just used some standard 2 part body filler, El cheapo brand from autobarns, sanded the lines first with 40 grit to get rid of old paint and give the filler something to hold on to then just filled it in.
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    Slight thread dig, but I thought I would offer some advice for painting engine covers. If you want to leave parts unpainted (like taping them up) and its a rather complex shape you can use grease to 'paint' the area you want unpainted in grease, personally I used ear cleaners for the fine detail.
    I did it for my VZ Alloytec covers. I wanted all of the V6 Alloytec left black, and some other parts black while painting the rest Impulse Blue.
    I just left the paint to dry, grabbed a rag and wiped off the grease. Left the area paint free.
    My rides
    VZ Crewman S Pack 6 speed
    HJ/HQ One Tonner with a worked 253 and 3speed auto
    VZ
    Oct 2010
    Quote Originally Posted by azazeldeath View Post
    What was the edge of the paint line like? I suppose it would depend on how carefully the grease was applied and how soon after drying it was removed.
    Glenn
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    so anyway. i should have had this finished but ran into a problem.
    painting the top stripes i messed up, and trying to correct ruined the whole job. have sanded back and have started to respray.
    however i went to the paintshop and asked if they do chrome paint in tins, so the same problem wouldnt happen.
    the closest they had was this. and it came up exactly the same as chrome.
    only bought a sampler tin (shown is 4L tin), but there is plenty in there, plus i have some other project planned for it.
    so if your ever looking for chrome paint in a tin. there it is =P
    needs to be the "aluminium" colour though
    Mk2
    Mk2 is offline
    VX Calais S2
    Oct 2010
  15. #15
    Oct 2010
    Darwin, NT
    Quote Originally Posted by bloomers View Post
    The edges were perfect. It was almost as good as taping, except saved alot of time for the fine detail (I think for the curves tape would have made the finish bad).
    My rides
  16. #16
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    Quote Originally Posted by Mk2 View Post
    Can you post a couple of photos of your cover in this chrome-like paint?
    probably will not have the pic of the chrome on the cover, but i have tested it elsewhere next to the spray chrome.
    ill get a pic of it by the weekend and post it up.
  17. #17
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    ok so finally got the pics off my phones.
    first one is a bit average because of flash but shows the 3 main colours.
    the chrome from the rustkill paint is on the left, but is made brighter by the flash.
    right is the from a spray can. it comes out exactly the same.
    this second pic shows how the chrome will look on the black. as you can see i made a mistake and it didnt go as i had planned. thus sanded it all back and am repainting it now. hope to have it all done by next weekend
    but hopefully gives a rough idea of how it will look near the end.
    also the V6 part is still taped. if your wondering why it looks wierd.
  18. #18
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    just been spraying and did some runs too thick. bloody spray can kept cutting out halfway through and so forth. definately wish i had a proper spray kit.
    made it half presentable and i am not going to redo for a 3rd time =P
    will get pics up once dry and youll see why it is best to prime before painting.
    its a bit of a shame but i guess it is going in an average engine bay, youll never see it anyway =P
  19. #19
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    so anyway. update on how it looks.
    just requires a bit of fancy texta work. clear coat and im done with it.
    the chrome does hide some of the imperfections.
    (click for bigger view)
    also planning on doing this to some rocker covers. might have to go search for these next weekend at pickapart or so on.
    should look all good after that.
  20. #20
    BuckeTs's Avatar
    BuckeTs is offline Filthy Beast
    vs wagon
    Oct 2011
    nice work mate! I've laid 3 coats of satin black on mine so far... but ive been a slackarse since and haven't done anything for a couple of weeks. Might get into it this weekend again.
    When in doubt, use FORCE
  21. #21
    VX Executive
    Jun 2011
    Not quite as good as two colours like the guy above, but whatever, i was hungover.
    Not like im packing serious shit under the hood so.
  22. #22
    95' VS Acclaim
    Nov 2011
    Thanks for the write up.. Might have a go at painting mine soon.
    Just starting to collect things to mod my VS, this will be a nice fun job to start off with I reckon
  23. #23
    vk berlina
    Mar 2008
    thanks for the write up as about to put a ecotec in a vk and was wondering how to neaten them up.
    [/COLOR]i once was lost but now am found (in a commodore)
  24. #24
    VS Berlina
    Mar 2011
    Woodford QLD
    Quote Originally Posted by Calaber View Post
    First time I've seen under your bonnet mate, very tasteful and tidy.
  25. #25
    Oct 2010
    Darwin, NT
    Forgot to post what mine looks like.
    Need to fix up the air intake pipe. I tried chrome paint on it ages ago and it just flaked off within 2 days.
    My rides
  1. Paint Engine Cover
    By Exceler8r in forum VE Holden Commodore (2006 - ?)
    Last Post: 19-07-2010, 11:55 PM
  2. VT V6 Engine cover paint
    By mitchoVR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-05-2010, 07:41 AM
  3. paint code for ecotec engine cover
    By rocco555 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2010, 10:04 AM
  4. Engine Cover Paint
    By RacerVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2009, 04:56 PM
  5. Engine cover re-paint $$$ QLD brisbane
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-01-2008, 02:24 PM
