FXST01
The Grey Man
- Jun 3, 2005
- 1,109
- 52
- 48
- Location
- Perth, WA
- VP V6 Exec
Cool Climate Control Self Test VN->? Written by GSMRobinson
This should work on VN and VP Might also work on later models, I'll look into it
1. Turn the ignition from OFF to ON (start car)
2. PUSH and HOLD DOWN the OFF button on the Climate Control Unit
(MUST be done within 10 seconds of turning ignition to ON)
3. Liquid Crystal Display (LCD) should now display the TOP part of the .8 if not there is a fault (or you took too long)
4. PUSH the HOT button
5. A number between 20 and 27 should now appear, 20 is GOOD anything else is a fault. (LOOK at fault codes at #5 end of article)
6. PUSH the HOT button again
7. LCD should display 31 and should be blowing out at the face on recirc mode, low fan speed and compressor on, heater tap off.
8. Push DEF button
9. LCD should display 32 and should be blowing out at the face and floor on recirc mode, med high fan speed and compressor on, heater tap off.
10. Push DEF button
11. LCD should display 33 and should be blowing out at floor only on freash air, medium blower fan and compressor off, heater tap on.
12. Push DEF button
13. LCD should display 34 and should be blowing on windscreen and floor, high fan speed, compressor on and heater tap on.
14. Push DEF button again.
15. LCD should display 35 and should be blowing on windscreen only, high fan speed, compressor on and heater tap on.
16. Push the HOT button.
17. LCD should display 4.
18. Push DEF Button again.
19. LCD displays outside air temp.
20. Push DEF button
21. LCD displays interior temp.
22. Push DEF button
23. LCD displays evaporator air Inlet temp.
24. Push DEF button
25. LCD displays evaporator temp.
26. Press FAN button
27. LCD should be at 0 IF not use HOT and COLD buttons to get it to 0.
28. Turn Ignition OFF.
#5 codes
20. OK
21. Outside sensor (ambient)
22. Interior sensor
23. Water temp sensor problem
24. Air sensor
25. Sun sensor
26. Air temp mix motor
27. Evaporator Thermistor Problem
Hope this helps...came from some old notes I made...let me know what models it works on and if its right.
Regards GUY
P.S. I found this on the VN-VP sub-forum, thought it may be more useful here. All credit to GSMRobinson.
8. Push DEF button
10. Push DEF button
12. Push DEF button
20. Push DEF button
22. Push DEF button
24. Push DEF button
#5 codes
20. OK
22. Interior sensor
24. Air sensor
25. Sun sensor
Regards GUY
