Page 1 of 9 12345 ... LastLast
Results 1 to 25 of 203
Like Tree3Likes
Thread: Checking error codes VR/VS (Revised)
    Darren's Avatar
    Darren is offline Site Administrator
    HSV Clubsport R8 E2 M6
    Feb 2003
    Default Checking your Computer for Faults (VR - VS)
    1. Locate the diagnostic connector under the the steering column on the drivers side.
    2. Grab a paper clip and bridge pins number 5 & 6 'black' and 'white with black stripes' respectively on the ALDL (Assembly Line Diagnostic Link) connected which are located on the top row counting from the left.
    3. Jump into the drivers seat and turn the key twice (so lights are up on the instrument cluster).
    4. If you bridged out the correct wires 'Check Engine Lamp' will be flashing.
    5. The flashes are divided into 2 groups with roughly a second between each. You can read the flashes as follows:
      The first series of flashes is tens, so for example lets say the first flash simply flashes once, this means the code is 10. After the pause (~1 second) a second series of flashes will appear, if this number is 2, the code it is spitting out is 12 which means everything is fine.
    6. Another example just so you're sure
      The first series of flashes you count is 4 meaning 40, the second series of flashes is 3. Adding the 40 and the 3 will give you a code of 43 which means the Knock sensor circuit is experiencing problems.
    7. Each code the computer picks up is repeated three times with ~3 second pause between, so its wise to sit there to make sure there isn't any problems it has picked up.
    8. Once you are finished turn off your ignition and remove the paper clip. It is important to note not to drive the car around while have wires are bridged as this will prevent new codes from being logged.
      Any questions or queries please feel to contact me at anytime.
      Checking the computer for codes is used in conjunction with the computer Fault Codes located here
    Last edited by Gobbles; 17-08-2004 at 07:27 PM. Reason: Added word Clip after Paper down the bottom :)
    Holden Captiva (Work Demo)
    Feb 2005
    Yes im dumb but i cant find the diagnostic connector under the steering column. It was prob staring right at me but a photo could be nice showing the bridging.
    I took the cover off udner the steering wheel, saw fuses etc...
    *shrug*
    Some people say less talk more action, i say more torque less traction.
    97 VS Series 2
    Apr 2005
    QLD
    D/w bout taking the cover off under the steering wheel. It sits just under this. Its a black connecter bout 20 pins or so and it jus sits below the plastic cover under your steering wheel round about inline with the brake pedal.
    Hopefully this helps ya out
    Cheers, Jon Z
    Feb 2005
    Thanx for that, did the check and gave me code "12" so all is good.
    blitzem Guest
    wbcaprice Guest
    just wondering if this also applies to me, i have a 5.0l out of a vs senator in my ute, but am wondering about the cpu in my case? any advice would be useful
    VY S3 V8 Monaro
    Jun 2005
    Ok, I'm pretty sure I've found the connector (in line with the brake pedal on my VR).. BUT, how do I know which pins are black and white... and 5 & 6 for that matter? Some seem to have a metal connector others dont. Does anyone have a pic they could post up please?
    MarzVP's Avatar
    MarzVP is offline I now own a TARAGO!!!
    1992 Tarago
    Aug 2005
    Port Bouvard, WA
    VT Executive Wagon
    Sep 2005
    Quote Originally Posted by blitzem
    so does this apply with the a VT?
    I'm wondering this myself. Bugger taking it to Holden to read a code.
    jpflinders Guest
    Default List of Codes
    Is it possible to get a list of all error codes posted for VR ?? I'm having trouble with starting takes a long time to start. I had a faulty Crank Angle sensor and replaced that, what could be wrong?
    Thanks For the Help
    gbug Guest
    Feb 2005
    there is another thread in this section for VN-VP.
    scotty1000 Guest
    Question
    Does anyone know which pins to short out on the ALDL on the VN 5.0 Litre V8 ?
    ANTHONY665 Guest
    Hay mate can ya tel me why my VR is not sending the RPM to my taco that i fitd on the dash. just dont know why and how i can fix it
  15. #15
    Sep 2005
    hey guys, why didnt that gizmo get made with
    a lcd readout, then better than counting flashes.
    anso, why is it that pins have to be shorted out with a bit of wire, it this needs doing, why dont the plug from the unit have pins X & Y (whatever) shorted out in the plug?
  16. #16
    VS Exec SII 3.8 V6
    Nov 2005
    had the battery disconected a few days ago.. so dont know if this is accurate but its showing 12- ok.
    ill try it ina few weeks times, thx.
  17. #17
    VY S3 V8 Monaro
    Jun 2005
  18. #18
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by scotty1000
    v6/v8 same pin 5/6
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
  19. #19
    Z()LTAN Guest
    12 is all i get do u have to do anything else to check other codes becides 12?
  20. #20
    VRII Acclaim
    Jul 2005
    Code 12 will always show up first. It will show itself 3 times before any other codes are found. I will put a pic of the connector on soon. Codes will be cleared when the battery is removed or the engine fuse under the bonnet is disconnected. In responce to stewarts question, yes you could theoretically make an lcd readout but the flash system costs nothing. You can also buy a cable to connect that lists the codes, but this system is free and incredibly simple.
  21. #21
    VRII Acclaim
    Jul 2005
    Default Checking error codes VR/VS (Revised)
    This is a revised version of Darren's How-to. This just has pics added for those of you who get stuck.
    Grab a paper clip and bend it like this:
    Bridge pins number 5 & 6 which are located on the top row counting from the left.
    It should now look like this:
    If you bridged out the correct wires 'Check Engine Lamp' will be flashing (the engine fan will also run - this is normal).
  22. #22
    Notorious's Avatar
    Notorious is offline Notoriou$
    VS Acclaim S2 3.8L
    Dec 2005
  23. #23
    VRII Acclaim
    Jul 2005
    Follow the link darren provided in the first post. If its a vs the site says :
    Crank Angle Reference Signal
    If its a VR:
    18x Reference Signal Missing
    This may have to do with a fault with the crank angle sensor, although i wouldnt worry about it until the car struggles to start when its warm. I would reset the codes and check them after a week to see if the fault was just a once off that has sat in the error log.
    To clear the error log remove the engine fuse, 20A, under the bonnet near the battery for a few seconds.
  24. #24
    VR V6 Ute Manual
    Dec 2005
  25. #25
    VRII Acclaim
    Jul 2005
    Everyone will get a 12 first. If you get a 12, 3 times, then it repeats the 12 again 3 times that is indicating that there have been no logged faults. If you only checked the 12 and didnt wait 2 seconds after the 3rd 12 flash than there may possibly be more fault codes. But if 12 is the only log than there are no recorded problems. This does not mean there are no faults, just none that have been read by the computer.
LinkBacks (?)
  1. 25-03-2012, 08:08 PM
  2. 22-02-2012, 08:37 PM
  3. 23-12-2011, 01:18 PM
  4. 09-12-2011, 05:45 AM
  5. 04-12-2011, 07:51 PM
  6. 25-11-2011, 05:10 PM
  7. 11-10-2011, 11:17 PM
  8. 27-09-2011, 10:14 PM
  9. 23-09-2011, 06:48 PM
  10. 20-07-2011, 11:41 AM
  11. 05-06-2011, 06:04 PM
  12. 30-05-2011, 10:11 PM
  13. 28-05-2011, 10:51 PM
  14. 17-05-2011, 02:05 PM
  15. 27-03-2011, 03:42 PM
  16. 16-02-2011, 05:23 PM
  17. 24-01-2011, 09:38 AM
  18. 03-01-2011, 05:37 PM
  19. 24-12-2010, 03:44 PM
  20. 15-11-2010, 07:24 AM
  21. 08-11-2010, 03:54 PM
  22. 16-09-2010, 06:34 PM
  23. 10-09-2010, 07:01 PM
  24. 25-07-2010, 04:38 PM
  25. 12-07-2010, 06:26 PM
  26. 11-02-2010, 08:41 PM
  27. 30-01-2010, 05:03 PM
  28. 13-12-2009, 07:25 PM
  29. 01-11-2009, 09:48 AM
  30. 04-09-2009, 09:59 PM
  31. 16-11-2008, 05:14 PM
  32. 31-10-2008, 01:40 PM
  33. 23-06-2008, 10:30 PM
  1. Checking error codes VT/VX
    By AirStrike in forum Holden Commodore How-To's
    Last Post: 11-04-2012, 08:22 PM
  2. Where are the error codes?
    By BowTieGQ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2012, 10:46 PM
  3. Checking Fault Codes
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-03-2009, 08:15 PM
  4. Error codes on Vs
    By PorterVs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2008, 08:10 PM
  5. Checking For Fault Codes?
    By arty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2004, 01:56 PM
