Results 1 to 10 of 10
Thread: VR/VS Engine Belt
    VRII Acclaim
    Jul 2005
    Default VR/VS Engine Belt
    The engine belt is surprisingly simple to check and replace. They are fairly reliable, and I have been told they need replacing about every 100,000kms, so not very regularly. But check it everytime you do a service (I normally do one every year-ish). It takes about 2 seconds to check and 60 to fit a new one.
    This is my old belt that I have just replaced. It is showing signs of cracking, and for about $30 I wont have to worry about it for another couple of years.
    This is the belt tensioner. It puts pressure on the belt and takes up the slack when the belt stretches due to age.
    On the tensioner there is a small arrow which indicators the level of force the tensioner is exerting on the belt to keep it operating. If the arrow is pointing outside the normal operating limits, the two purple marks, the belt should be replaced.
    Replacing the belt:
    Using a round spanner grab the bolt on the tensioner and push it up. This will relieve the pressure on the belt enough to pull it off.
    Installation is the reverse of the removal. Take note of how the belt sat before you take your old one off. The gregories manual uses a neat diagram that shows where the belt runs if you get stuck, but for copyright reasons this diagram wont be displayed on this website.
    When the belt is back on make sure it sits in the grooves of the pulleys.
    Thats it. Theres not much too it at all. Oh and I have been told that a new belt may make a bit of a squeek when you start the car. I didnt have this and I dont think many people have but if you do, dont use lubricant on the belt.
    Feel free to ask any questions you might have
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    Isn't there a product called Stop Squeek or something available at Super cheap Auto Autobarn etc ?
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Orange, NSW
    i think he was refering to the first start, while the belt 'beds in' if you like
    VS Berlina
    Feb 2007
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    learn sumfink new each day, i didnt know there was a idicator to show if the belt is within its operating limits.
    ________________________________________
    Not_An_Abba_Fan's Avatar
    Prado
    Aug 2006
    Bunbury, WA
    The marks indicate the tensioner's range. The longer mark in between is the wear indicator. When the pointer reaches this mark the belt should be replaced.
    immortality's Avatar
    immortality is offline Donating Member
    Apr 2006
    Sth Auck, NZ
    it's probably best to take note of where your tensioner position is on the scale and then monitor that when you do a service etc. not all new belts are of identical length. my brand new belt was already halfway on the scale but hasn't changed in the time it's been on so i know it's ok. best to mark it somehow so it's easy to see any wear etc.
    Body by Holden, Soul by Brock
    the Legend will live forever
    Nope - back pressure is a complete fallacy. In short - do you fart any better with a cork up your arse???
    VS commodore executive 1995 v6 station wagon
    Aug 2008
    hello
    I recently bought a 1995 vs commodore executive. When I took into the garage the mechanic said that the engine belt had been installed incorrectly. I have checked this with the handbook and this forum. It seems to be fitted fine. 1) the ridges are in the ridges 2) it has air conditioning and this is covered by the belt
    The mechanic said that it was showing signs of wear that is caused by the fact it is incorrectly fitted. I think I remember them saying it was the wrong way round (there was a few other problems I was concentrating on if I sound vague). I know there is an upside down, but should is there a right way round horizontally? There are threads showing on the edge that is to the front of the car rather than towards the engine.
    Any ideas would be gratefully received as they are looking at charging me $100 for labour.
    Thanks
    Prado
    Aug 2006
    Bunbury, WA
    If the belt is on and the tensioner is within it's range, the belt is on correctly. You can't put it on wrong, it will be either too big or too small if it is not the right way on the pulleys.
    Visit my Facebook page
    Quote Originally Posted by 191kieran191 View Post
    contact Not an abba fan he is the best
    Nuff said really.
    vs ss 5litre
    Nov 2008
    what about a vs ss how do i put that on it has 2 fan belts on it... and im not sure which one the adjuster pulley is on it
  1. EGR Belt VT
    By LAUREN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-05-2010, 09:56 AM
  2. Serpentine belt (Acc Belt)
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2007, 11:12 AM
  3. VS engine belt - how does it go?
    By jimmyd17 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-04-2006, 11:24 AM
  4. How goes the fan belt?
    By Stumped in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-08-2005, 08:48 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
