Results 1 to 24 of 24
Like Tree3Likes
  • 3 Post By AirStrike
Thread: Checking error codes VT/VX
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Default Checking fault codes for VT/VX L36 and 304
    Here is something I put together (with some assistance from Garth with some of the codes)
    AirStrike
    Attached Files Attached Files
    2009 FG G6ET
    395rwkw
    11.76 @ 117 MPH (350rwkw)
    Tuned by
    Sep 2004
    Default not working
    hey guys great job on this thread...but i have sat down on the floor of my drivers seat for hours today with paper clips, copper wire you name it, and i cant seem to get the codes to come up. im having problems with my abs module. all my dash lights come on and my air con wont get cold, my cruise control wont work and my temp guage wont work while these lights are on.
    i have changed the module...it worked for about 10 minutes now they are on again.. it is really starting to bug me. its hot and i want my air con to work
    someone please help me.
    vx commodore
    Apr 2009
    Default vx faults
    I've checked the faults on the compter for my vx an found fault code 13 and 61 i've worked out what 13 is but i can't find a referance for fault 61 can anyone help.
    BIG-EV's Avatar
    BIG-EV is offline Project VT (In Progress)
    2000 VTII Executive 3.8L Supercharged V6 Wagon
    Oct 2008
    Mango Hill QLD
    vt acclaim gen 3
    Jul 2009
    vic
    can this be used on vehicles with the gen 3 aswell? because the heading says v6 and 5 litre?
    PietroChocko is offline Nurses do it better.
    Was a VN Executive 5.0, but now a Ford Laser Auto.
    Sep 2009
    VT V8 Calais
    Mar 2007
    Quote Originally Posted by sly_gen3 View Post
    I am not sure if the codes are the same, but that gen3 is a 5.7, not a 5 litre.
    50LTRv8
    BrAdAsS is offline Banned
    VX Executive A4
    Dec 2005
    Brisbane Northside
    What code do you call this flash sequence:
    2, 10, 1, 2, 10, 10, 1, 2 long-pause 10,10,1,2 long-pause 10,10,1,2 long pause, 10,10,1,2 ?
    link to video
    I gather the 1,2 is code 12, but what are the others?
    Vt Berlina 1998 Not my dp
    Jun 2009
    Frankston
    can anyone post a pic of the connections that need to be bridged? please
    Quote Originally Posted by Cobez View Post
    You sir, are as gay as aids and as camp as a row of tents. You also fail..
    VX Executive A4
    Dec 2005
    Brisbane Northside
    the pins in the plug are counted from Left to Right Top to Bottom.
    Just count 5 and 6 along the top row of pins and thats them.
    Jun 2009
    Frankston
    thanks much appreciated
    3.8L 1997 VT S Pack; 5 Spd Man
    May 2009
    Sale, Vic 3850
    I cant find the thing to bridge, picture be appreciated
    It's worth as much as someone is willing to pay!
    2007 WM Caprice
    Aug 2008
    its just above your pedals, not under the steering column cover(where the fuses are) look further down.
    best way to explain where it is, is to put your head on the floor, face upwards and its there.
    VH SS
    Dec 2006
    Quote Originally Posted by BrAdAsS View Post
    link to video
    Apparently VX II and VY have four digit error codes (see this thread vx fault codes)
    If can't find a list to see if there is any difference between VT/VX to VXII/VY error codes so should I assume they are the same?
  15. #15
    VX HBD
    Feb 2010
    Default vx berlina Problem please help!!
    I have a vx berlina and i have started getting starting issues, and last night i had the heater going on and off by itself anf the check engine light coming on then off head light dimming airbag light coming on and off etc. Is this a ECU error ot what could it be and is it easy fixed can i just replace the ecu with a 2nd hand one or does things need to be reset can anyone help thanks
  16. #16
    ratz26's Avatar
    ratz26 is offline worlds oldest noob
    2001 VT equipe
    Sep 2007
    tweed heads
    for those that asked this is where u bridge.
    on my 99 VT its on the bottom of the fuse box door thingy right above the brake pedal
    Attached Thumbnails Attached Thumbnails Checking error codes VT/VX-car-pics-.jpg
    Last edited by ratz26; 06-03-2010 at 10:16 PM. Reason: added arrows to photo to correct ports to bridge
  17. #17
    GSXR1000
    Apr 2010
    WA
    Thanks for this!
    Just checked mine after seeing my check engine light coming on twice this evening just as I got in the car to come home.
    Started the car, engine light on, turn it off, started again, engine light on, then eventually went.
    Seems Mine's gone to code 15 which is coolant temp sensor voltage too high.
    Random...
    Was only flashing that code and the standard 12 code.
  18. #18
    99 5.0L V8 VT Berlina (Modified)
    Sep 2010
    Ohope Beach New Zealand
    Dont forget that the engine light can come on for simple things that mean nothing. For example when driving slowly with a big-bore exhaust, the headders are too cold for the oxygen sensors to work correctly and will return an error.
  19. #19
    VT Acclaim
    Nov 2010
    Thanks for that I will try them out tomorrow morning. Is there any way I can check the ABS module?
  20. #20
    vx/ 2001
    Oct 2010
    iraq
    Mine got 10 flashes then 1 repeatedly that's all, what does it mean Please.
  21. #21
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by FalconTop View Post
    The VX error codes are now represented by groups of four flashes instead of two flashes like the older commys. Example- code 12 is now represented by 10 flashes, 10 flashes, 1 flash, 2 flashes.The 10 flashes stands for 0. The older commys just had one flash followed by 2 slightly quicker flashes, to represent tens and units to make code 12. After the 10 flashes, how many of the "1's" is it giving you before it starts over.?
  22. #22
    1991 Subaru Liberty LX
    Aug 2010
    Ultimo
    dont mean to dig up on old thread but i couldnt find anything on my problem in other threads, im bridging the right pins 5 and 6 and it worked once but came up with code 83 so i checked and there isnt an 83 so i went back to check it again and bridged it the same way but the engine light wouldnt flash at all... any ideas ive tried unhooking the battery to reset it, bridging every other way but nothing works, any help at all would be mad cheers
    HX Kingswood Ute (Project)
    VN Berlina (Now a Donor)
    "91 Subaru Liberty (Blown Motor Ex-Daily)
    VS Commodore (Daily)
  23. #23
    greasemonkey24 is offline Donating Member
    vt s pac 3.8
    Jan 2012
    armadale
    WHAT A AWESOME THREAD!!!!!! i didnt even know u could do this after 1st time installing stage 2 cam and basically rebuilding half my engine (8.5hrs later) i checked for faults using ur method and to my amazement nothing wrong everything is spot on thanks heaps for the tip[
  24. #24
    VX V6
    Apr 2012
    Moreton Bay Council
    Default Holden Fault Codes Link
    To find codes related to your specific version follow the link below:
    obd-obdii.com - Free OBD/OBDII Help - Diagnostic Data Sheets
  1. Checking error codes VR/VS (Revised)
    By Darren in forum Holden Commodore How-To's
    Last Post: 11-04-2013, 05:59 PM
  2. Checking Fault Codes
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-03-2009, 07:15 PM
  3. Error codes on Vs
    By PorterVs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2008, 07:10 PM
  4. Error Codes on my VS SS V8 Help!
    By Ravager in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2004, 10:15 PM
  5. Checking For Fault Codes?
    By arty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2004, 12:56 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
