Hertz Donut
- Sep 9, 2014
- 147
- 11
- 18
- Age
- 51
- Location
- NZ
- Beastmode VS Equipe
First, the disclaimers:
- I am in no way an auto electrician, therefore I don't know the technical terms for some parts, so bear with me.
- I'm not a highly trained mechanic, I'm just a backyard DIY monkey who can hit things until they work again, so...
- I take no responsibility for anyone ending up with two or more destroyed switches and a car engulfed in a fireball.
- Contains small parts, not suitable for children under the age of 3 years old.
This may also work for VR, and maybe VN and VP too but someone else will have to try that to find out.
Time to complete: Under 30 minutes if you have a new VS switch, a little longer if you have to build a hybrid switch.
Part 1: Diagnosis
Right, so the ignition switch spring in the Equipe of Doom let go after only 19 years and 289,000km. You just can't get the quality these days eh. Signs of a broken spring are:
- Key won't return to the "ON" position after the engine starts, instead staying in the "START" position. If you don't turn it back manually you will ruin the starter motor.
- Indicators either work intermittently or don't work at all. This is because without the spring returning the key to the "ON" position you're pretty much guessing where the exact position is, and if you don't align the key properly the switch contacts aren't connected, so it's the same as having the key in the "ACC" position.
Part 2: Removing the faulty switch
Removing the switch is easy:
1. Pop the bonnet and disconnect the negative lead from the battery.
2. Drop the bottom half of the steering column cover, which is held in place by five screws on the underside. It's easier if you drop the fuse panel cover first, which is held in place by 3 pop-out plastic bungs. You'll have to gently massage the column cover over the ignition barrel.
3. Put the key in the ignition.
4. Look under the steering column and you will see the metal ignition barrel. On the left end is a black plug with four wires, connected to another black plastic part that is screwed to the ignition barrel. This second part is the ignition switch.
5. Gently lever the plug off the switch with a small flat blade screwdriver. I say "gently" but as long as you don't damage the wiring, the plug or the switch wgaf, it's just everyone uses emotive words like this so I feel obliged to do the same.
6. There is a wire screwed to the bottom of the barrel below the switch. Unscrew this.
7. There are two tiny retaining screws holding the switch in place, unscrew these. You will immediately drop at least one of them somewhere in the footwell, where it will disappear, but try not to, it saves a lot of time.
8. This is the point at which all the manuals and many people get all hyped up about the position of the key. They'll talk about turning it to the "ON" position and giving hysterical warnings like "DO NOT MOVE THE KEY FROM THIS POSITION OR THE GREENS WILL WIN THE NEXT ELECTION" and so on but really it doesn't matter. The interaction between the ignition barrel and the switch is pretty simple - the barrel has a small "key", which I will call Bob, that slots into a "keyhole" in the switch, which I will call Mary. As you turn the car key in the ignition, Bob rotates accordingly, turning Mary through various positions (oo-err...). Since you've removed all the screws holding the switch onto the barrel, it should just pull off as Mary will just slide off Bob (uh...). You may have to try the key in different positions before Bob and Mary come apart.
9. Congratulations, you now have an ignition switch in your hot little hand.
Stay tuned for more...
Part 1: Diagnosis
