+ Reply to Thread
Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 25 of 105
Thread: How To: Change Springs/Shock
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ VN_Luke W427 VN_Luke W427 VN_Luke W427
    VT, RB30EST VN
    Mar 2005
    Default How To: Change Springs/Shock
    Okay so i figured i'd do a quick write up on how to change your shocks/springs as i did this the other day and took some pics.
    Things you will need:
    - Socket set
    - Spanners
    - Spring Compressors
    - Big heavy hammer
    - Rattle gun
    - Some way to lift the front of the car up
    - Random items you could find handy.
    Lets get right into it:
    1) Put the front of the car in the air (safely) ... this has been repeated many times but DO NOT WORK ON A CAR ONLY SUPPORTED BY JACKS
    2) Take off the front wheels
    3) Remove the brake calipers (there are two bolts on the inward side of the brake claipers to remove) and support them (hang them up with zip ties or something) so that you don't damage your brake lines
    4) Have a good look under your car and find fascinating things that you never knew were there. This is a good time to spot oil leaks to worry about in the future.
    5) Remove the tie rod end from the thing that it's connected to (not pictured). There will be a castle nut with a pin through it. After this nut is removed, bash the side of where the tie rod end is sitting, and it will pop out.
    6) Remove the sway bar link pin from the strut - 14mm nut and use a spanner on the groove on the pin to stop it from turning.
    7) Remove the ball joint from the strut. This could be a bit of a bitch depending on how firmly it's been sitting there. The trick is to undo the nut, then once again bash the side of where the ball joint sits really hard with a big hammer. If this fails, hit harder, or find abigger hammer.
    8) Now, unless i've forgotten something, you should be able to remove the sway bar link pin from the strut, and the only thing holding the strut in the car shold be the three bolts up in the engine bay
    9) Undo the 3 bolts and hold that strut, they're pretty heavy when you're doing it by yourself. Remove it from the car
    10) Have a beer.
    11) Get out your spring compressors and get them around as much of the spring as you can... then tighten away on both of them until you can feel that the spring is jiggling around inside the strut and there is no load on it.
    12) Rattle gun off the bolt at the top of the strut - i'm sure there are other ways around this, but this is nice and easy and works good!
    13) Remove the bearing blate and spring retainer plate thing and now you can remove the spring.
    14) Remove the rubber dust boot (it just slides off) gently so that you don't damage it.
    15) You can now get to the nut that holds in the shock absorber, and undo it. (if you have a big enough spanner).
    16) Once this nut is off you can take out the old shock absorber.
    17) Have another beer.
    Installation is pretty much reverse of removal - just make sure the springs are lining up right and that kind of stuff.
    Make sure you torque up all bolts that should be torqued and locktite all bolts that should be locktited
    Enjoy the procedure it's really not that hard!
    If i've forgotten anything please let me know! If you want to see more pics let me know also, I'll be doing this procedure again tomorrow.
    p.s. I claim no reponsibility if you manage to blow yourself or your car up, spill your beer, or do any other kind of damages to yourself, property or other persons.
    UPDATE:
    The upper spring retainer has a notch in it - when re-assembled, this should be facing outwards of the car, to the side when the wheels are straight.
    mouce's Avatar
    mouce is offline Physics Geek mouce Executive
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Lucky you even had a hoist to do it on. I've decided when I become rich and famous I'm going to have a garage with a 4-post hoist in it just for working on cars.
    Good write up.
    Gravity is proof that nature keeps getting us down.
    redcedar's Avatar
    redcedar is offline workaholic redcedar Executive
    Alto Grey MY12 SS
    Nov 2005
    coffs harbour
    i don't think having a couple a beers is such a smart thing to do while playing with springs !!!!!!!!!!!!!!!!!!!!!!
    wait till your finished and then get oiled !!!!!!!!!!!!!!!
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    lol couple of beers dont harm us commodore enthusists (however its spelt), if anythign helps us along
    Current: My Ride
    VY Series 2 Berlina, Leather
    Previous: Ride 2
    VR Executive, 5 Speed Manual, Ecotec 3.8
    VN SS
    Jan 2006
    Any advise on what to do if the shock turns when you try to loosen the nut at the top of strut????? How do you hold shock so that you can loosen the nut????
    beefcream's Avatar
    beefcream is offline Lethal LOKKA beefcream Executive
    VS SS 5speed (project) VN exec v6 (daily)
    Sep 2005
    South,Adelaide
    great work mate.. very handy guide
    VS SS - Street/Show Project [BEEFY]
    http://forums.justcommodores.com.au/...-beefy-v2.html
    HID Kits from $100 - Installation available PM FOR DETAILS
    VP Executive R-spec
    Jan 2005
    mouce's Avatar
    Jul 2005
    Anyone else think this should go "Sticky"?
    beefcream's Avatar
    Sep 2005
    South,Adelaide
    yep................
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    yay!
    Are you using a rattle gun? if not, start...
    if that's impossible and you're going to chuck the shocks anyway, try grip then with vice grips and a towel or something? But if you don't want to butcher them you'll need to get creative.
    try 'rattle gunning' the ratchet, if you're using one... just give it quick sharp hits to break the nut loose....?
    mmmm beeer.
    VP Executive R-spec
    Jan 2005
    jack.mc's Avatar
    jack.mc is offline Nothing witty to say :( jack.mc Berlina
    VN Vacationer
    May 2005
    Sydney, NSW
    you are awesome. STICKY
    I'm even adding this thread to my favourites, the first time a JC thread has ever been added... You should be proud
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    Doctor Sodways's Avatar
    Doctor Sodways is offline Legendary Baby! Doctor Sodways Calais
    Slammed VeeDub Rat and a Brunette...
    Sep 2005
    Behind a Camera...
    Yeah, agreed sticky, this thread will come in handy when i decide to change my front springs to match the lowered rear, if i ever get around to it.
    And mouce, agreed, everyone needs a hoist, i prefer the 2 posters but each to their own, all i have to do now, is talk mum into raising the roof on the garage that my folks are looking at so i can get one, im crossing my fingers they agree
  15. #15
    VX HSV Clubsport
    Jun 2005
    Sydney, eastern suburbs
  16. #16
    chromic's Avatar
    chromic is offline Donating Member chromic Executive
    VT V6 Sedan, VY SS sedan
    Nov 2005
  17. #17
    Vs_sharlene's Avatar
    Vs_sharlene is offline Beats a Kick in the Face! Vs_sharlene Executive
    VSII Executive
    Dec 2005
  18. #18
    jack.mc's Avatar
    VN Vacationer
    May 2005
    Sydney, NSW
    Quote Originally Posted by Vs_sharlene
    OMG!! That was so good even I understood it!!
    Whats a "sticky"?
    It means It will always be at the top in the VN-VP section.
  19. #19
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    Quote Originally Posted by VP_Luke
    what do u mean by torque up
    sticky!!!!!
    i always wanted to no how to do this. and what do u mean
    Adam
  20. #20
    MarzVP's Avatar
    MarzVP is offline I now own a TARAGO!!! MarzVP Monaro MarzVP Monaro
    1992 Tarago
    Aug 2005
    Port Bouvard, WA
    umm who defouled this topic and made it STICKY ohh yeah that would be me !!!! hahahaha
  21. #21
    VP Executive R-spec
    Jan 2005
  22. #22
    cacaman's Avatar
    cacaman is offline Red is Faster cacaman Executive
    Vr Acclaim
    Mar 2006
    Just a question
    When changing springs to make the car lower is it really necesary to change the shocks other than the fact that they might fall out if the car if raised agian?
  23. #23
    mistaken's Avatar
    mistaken is offline ... pimpin it VT stylez mistaken Executive
    VT
    Jun 2005
    Quote Originally Posted by cacaman
    Just a question
    Not if you're putting FE2 or equivalent height springs in. Anything lower and you may need to replace shocks.
    However saying that - if the car is >10yrs old and still has originaly shocks, it would be worth splashing out ~$70 for a pair of new standard shockies front n back. Or a little more for performance shocks.
    I'm looking at putting FE2 springs into my VT S1 soon - I'm considering replacing shocks all round (standard tho, not perfoemance shocks).
  24. #24
    Jan 2006
    stanthorpe, qld
    which bolts need locktite put on them?
    Adam
  25. #25
    Shounak's Avatar
    Shounak is offline The Kicking Horse Shounak GTS Shounak GTS
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    Quote Originally Posted by _A_D_A_M_
    sticky!!!!!
    It means tighten them to the correct tightness.. Usually done by an adjustable torque wrench..
    Shounak
    Always Right
    My Ride
+ Reply to Thread
  1. dobinsons springs and kyb excel tube gas shock
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2007, 07:31 PM
  2. FE2 Shock IRS to non-IRS
    By tastycustoms in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2007, 11:06 PM
  3. Shock Absorbers
    By wes_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2006, 09:09 AM
  4. Minor lowering: Only change springs?
    By DavidPartay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2006, 08:04 AM
  5. Shock Absorbers
    Last Post: 04-02-2006, 03:47 PM
