Results 1 to 16 of 16
Thread: VR/VS - Dash/Instrument Cluster Removal & Replacement
    Dec 2003
    Default VR/VS - Dash/Instrument Cluster Removal & Replacement
    I was asked to put this in the how-to section by some poeple on the site... apparently its useful. You can see the post from which it originated at:
    Post #40029.
    Here are the instructions; These can be used to help you:
    a) not break the plastic when removing the dash,
    b) replace the instrument cluster with an after market one, or
    c) replace/check for blown globes in the instrument cluster.
    1. Remove screws Orange 1 & Orange 2; these two screws are visable at the top of the instrument panel before removing anything. Dropping the steering wheel to its lowest position before starting helps.
    2. At this point you can remove the headligh selector if you wish, or else start removing the tabs holding the dash insert in. These are numbered Red 1 through Red 5. I personally like to remove the headlight/illumination switch and use that short side to start pulling the dash insert out.
      NOTE: It has been mentioned that some people with ABS equipped cars, or thos intending to leave the dash out for some time, have had issues with warning codes and flat batteries. If you think this will affect you - please disconnect the battery before getting started here.
    3. Using a flat-head screwdriver insert it to where the Red X numbers are and lift gently. The tabs should just pop out. I may have missed a tab location on the far right side near the headlight selector - I can't remember... see if it gives.
    4. After getting the insert loose, disconnect the Hazard light / Air Con / Demister plugs from the rear of the insert (and the headlight selector too if you haven't already done this). I find it useful to label everything here as I go - so grab a marker pen if you too intend to do this.
    5. Remove the now visable Orange 3 and Orange 4 screws. At this point the whole dash insert will just pull out. As you can see from the photo it is held in and made working by the Orange, Blue, Orange multi-pin connecters.
    All Done for the first part. You can now reverse the process after you have done what is needed and/or when your interior looks as cool as mine:
    Hope you all find this useful.... more howtos on the way - as I have pretty much removed every bit of my car at some point or another lately.
    VS Acclaim SII
    Nov 2006
    Do the small cloth trim inserts in a VS just pop out, want to recloth them, thanks for any help
    Being Insane Keeps You Sane
    VS Commodore Equipe V6
    Jul 2008
    Thanks for the article. All the info was spot on. Love the diagram. It's made life a lot easier for me. So much for the Gregory's car manual which proved to be total crap!
    Thanks again!
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    perfect write up, one thing I noted was that the level three cluster has a wire loom near the headlight switch on the actual cluster that is easiest to remove by dropping the panel covering the fuse box and looking/reaching up.
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    *This Post Was Removed By The Author*
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    social's Avatar
    social is offline Commodore Enthusiast
    2006 6.0L VZ Thunder
    Nov 2008
    South Aus
    +1 for sticky, was very hard finiding this thread others may find it helpful.
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    doms3 is offline Banned
    Vz
    Sep 2007
    Vz
    Sep 2007
    vs executive II
    May 2009
    BRISVEGAS
    vs executive II
    May 2009
    BRISVEGAS
    yer im glad no1 has answered my quiestion fort i was looking at instructions on removing the actual dash
    VS Berlina + LX Captiva
    Jun 2009
    Quote Originally Posted by NKX View Post
    Good stuff. Will check out the other "howtos".
    VQ 5.0Ltr Statesman
    Feb 2010
    Can you replace a VQ Dash/Cluster with a VR/VS one? If so, how much would it be?
    VS Executive S1
    Feb 2010
    hey just wondering if there was a picture to go along with this, the picture attached doesnt work....able to upload another?
    VS V6 T5 & VY V6 M35 UTE
    Oct 2004
    Jurien Bay WA
    This "how to" would be better if its pics worked still ?
    Deek
    Aussie Aussie Aussie, Oi Oi Oi .
  15. #15
    VS Series II Supercharged Statesman
    Nov 2010
    will need to give this a go, transducer already replaced and speedo still in a coma.
    does anyone have pics or where the screws/tabs are (if not i will use the always proven guess-a-metrics method)
  16. #16
    VS SS 5.0 Manual
    Dec 2009
    Yay. I likes my car. Does you?
  1. VB-Vh SL\E Dash Instrument Cluster Conversion
    By Pub247 in forum Holden Commodore How-To's
    Last Post: 13-03-2011, 08:47 AM
  2. Dash Guages & Instrument Cluster
    By breast69au in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-07-2009, 10:46 PM
  3. VS Berlina Instrument cluster LCD lighting - replacement
    By 6h84eva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2006, 12:57 AM
  4. Fs: White Instrument Cluster Face Place (Dash Speedo etc)
    By vy sammy in forum Parts And Other Items For Sale
    Last Post: 16-12-2005, 06:41 PM
  5. instrument panel removal/new dash lights?
    By vh-holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-07-2005, 11:51 PM
