i found the best way of removing the clip for the window winder is to use a fork make sure its a thin metal fork not a thick one and they come out easy as pie used this method on a vn vr vs and a vt
also you know theres a special tool you can get thats like a u shape that ive seen a couple mechanics use and you just push it in and it takes the clip off with zero effort
Cheers, gregories is ok, but who has those tools to remove the little clips?Originally Posted by wal
I have since removed my trims like 5 times, yeh takes about 5 mins per door to remove now if that, just trying to remove those airvents without scratching vynal is the trickiest, clips come off easy enough now, still havent broken one, laughing...![]()
yeah killuminati i know those air vents sh*t me to tears as well. With alot of agrravation taking them out each time i've taken the door trim off though i've think i've gotten down a good method for it that doesn't involve having to pry away painfully with a screwdriver - you can get them out with your hands. If people are interested in the next couple of days i'll try and take a few pics, cause it's a little hard to explain, i just wish i did it this way the first time so my doors weren't all scratched up. By the way, i want one of those damn o-rings! lol. what section are they found in at supercheap???
P.S. if you break the little red lock inserts, you can pick them up for $2.30 down at your local holden parts dealer. This price was current as of about a week ago as i've managed to break one so i know.
The old saying goes "if all else fails, read the instructions". I wish I had seen this thread before I gave time, blood sweat and tears trying to get the door trim off. Thank you to everyone who added instructions and pics. They are brilliant. Thanks for the help. In future, I will always check for instructions on this site FIRST!
Yeh, its too late for my trim, pretty scratched now, but im probably gonna paint it, so it will all be sanded back anywayOriginally Posted by Brycestro
those O rings around the window winders are a bitch to get back on, i cant get them back on, on a VR or VT "havent tried other models" another thing you can use that i know works perfectly in a VT for window winders is the tool that you use to take the disc of your grinder "average size grinder" i think its a 4;5 inch grinder? they work like the proper tool, but didnt work so well with the VR
the other day i was taking my rear door trims off my VR to put 6 inch speakers in the doors, i have only done one side, cause it took me about 4 hours from start to finish, it is simple but just very annoying.
hope the info on the VT helped. and could any1 tell me how to get them O rings back on? when i did my VR i cut it off cause it pissed me off so much! lol
for removing window winders, use a crochet hook, commonly used for sewing and cheaply available at sewing/linen stores in most big shopping centers.
Last edited by jimmy_jd_25; 26-09-2006 at 04:26 PM. Reason: edited so that it actually made sense
lol i used a ruler, a hard plastic one on its long side just pushed upwards and it popped it off easy plus because the ruler has a slant on it, makes it easy toget inside the tiny gap.
yer becareful when u pull the trim off u dont snap the whole thing cause as i was levering it off the whole trim was slightly snapping
LOOKING TO BUY A NICE BODY VR SS MANUAL!!, CHEAP!!!
ENGINE DOESN'T NEED TO BE THE BEST
PROJECT CAR!!
hey i know this thread is a bit old but i need some help. im trying to remove the front door trim on a vr to replace the speakers but i cant get the air vents off. the vinyl is scratching a bit and i dont wanna break them. ive tried prying them off with a flathead but only one side comes off (the side closest to the car) the outer side wont budge.
any help would be much appreciated![]()
the flat head should do the trick bud...use it on the outer side of the vent and push on the back of it with your hand...should work...
great little write up thanks, helped me last week when i installed power windows into my vs ute using the power window install guide!
Supercheap or Repco usually keep the window winder remover tools.
But I find a rag is just as easy. I just slide the straight edge of a rag behind the window winder, slide the rag side to side a few times and the clip usually pops up.
No risk of damaging door trims with this method either
No one has pictures?
<<<< The information went data way! >>>>
Was just reading over this as I am thinking of re-trimming the carpet on my door trims.
I'll take some photos while I'm doing it since all of these ones are dead.
Woo Hoo!!!
the o rings suck bigtime but sum get it easier than others.. a test of patience haha
i found the best way to remove the vents was with a flat head screwdriver just ease out the edge closest to the door trim about 1cm the pop the other side and it slides right out
Originally Posted by crewsy
Non turbo, normal POS lancer.. although he has a G-reddy sticker on the back so it must go hell fast
The red clip is fairy easy to take out you just gotta improvise I found using a flat head screwdriver it popped out in a breeze.. I just bought a vr exec wagon and I have to say its the easiest car I've done so far in terms of installing headunit and front speakers. I tried the shirt behind the clip on the handle just for kicks can't believe it actually works lol
