Fitting Gas bonnet lifters to a VN
Shortstuff
Random
2016 Golf GTI PP
I did this to my car today, and it's very worthwhile! So much better than the standard stay you get on the VN's. The only thing I would say is to be careful of the yellow part of the sound deadening under the bonnet as it can cause irritation of the skin if touched.
1. You will need :-
-A wire coathanger
-A pair of sidecutters
-A flat headed screwdriver
-A philips headed screwdriver
-A 10mm ring spanner
-An adjustable spanner
-VP - VS gas struts and fittings to attatch them to the car
-Two 8mm nuts (if you can find another pair, the ones that hold the bottom mounts for the gas struts on to the car are ideal)
-Lots of patience
2.First of all you will need to cut the coathanger so you can straighten it out. You then need to bend one end round so it fits very tightly around the 8mm nuts. I found it easiest to get the basic shape I needed by bending it round the nut, then taking the nut out and closing up the coathanger a bit more.
3. Then remove the fuse box cover from the fuse box in the engine bay. If you have an S1 VN, you will need to disconnect the coolant return hose from the surge tank to make a bit more room.
4. Along the inside of the top of the guards there are a series of screws that hold the guards on. You need to remove the one that is 3 back from the front of the car and loosen the ones either side of it so you can then remove the metal plate that the screw fastened in to. Once the small metal plate is out, tighten up the bolts you only loosened.
You can then put the bottom mount into the hole that is freed up and bolt it up.
5. Now comes the difficult bit. Putting the mounts into the bonnet. If you don't have holes in the bonnet already,you will need to drill some. The centres should be 185mm forwards of where the plate holding the bonnet hinges ends. If you do have holes, then it's all good.
Get an 8mm nut and put it into the end of your coathanger, then slide it into a hole in the bonnet that is a little way forward of the mounting holes. See pic below.
Push it down towards the rear of the bonnet until you can see it through the mounting hole. Line it up well, then very carefully screw your top mount into it by hand. Tighten the mount with a spanner then shake the coathanger loose of the nut and remove it from the bonnet.
6. Now you can attatch the gas strut to the bottom mount.
7. To attatch the gas strut to the top mount you will have to compress it slightly as it will be a little too long.
8. Repeat steps 4-7 on the other side of the car, then unscrew your original bonnet stay and take out the clip that held the other end. Throw away. Re-connect the coolant return hose if you disconnected it and replace the fuse box cover.
9. Be very pleased as your bonnet now goes 'Tsssssssssshh' when you lift it with minimum effort. You will wonder why you didn't do this cheap effective mod a long time ago!!
CSL
37
missus (in more ways than one)
nice how to, with mine instead or wrapping the coathanger around the bolt i just looped it on it self then wedged the bolt onto the hanger loop,
but yeah vn how to
timmy_tam
VN calais 91
how do you tackle the issue of the bonnet being raised slightly higher around the area of the strut, even after the bolts in teh area have been removed?
also, see leigh8695 on ebay if ur after a complete set, brand new including all bolts AT A GREAT PRICE!
Busselton W/A
2003 vy v6 manual ute
Mine isn't raised at all. Just cant get the bloody thing open:bang:
savage1987
Donating Member
www.facebook.com
I think I can recall reading somewhere that the bolts used in the VR-VS Commodores were flatter (less chunky . . . you know what I mean . . .)
Maybe replacing some of the bolts with these flatter items will fix this problem. If it does, please let me know so I can fit gas struts to mine!
Sam
edit: FAIL. no gas struts for me, I love my bonnet stand too much. At least it won't drop on me :)
Shortstuff
Random
2016 Golf GTI PP
I can't see why it wouldn't work. They make gas bonnet lifter kits for most cars now. You will probably have to work out the length of the struts when they are fully compressed to get the holes in the bonnet in the right place (so the bonnet shuts ok), but it should be basically the same as on a vn. I think the bottom mounts will still bolt onto a VK guard.
88GreenVN
Next Exit Left
60
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
This How to worked a treat. 1/2 hours work all done. Many thanks.
