(-update; half sized pictures, now the collection is only 2MB not 8MB! more 56k friendly!-)
Ok, allow me to start off with some key words for searchers ( this hopefully will help people searching find this thead )
(Keywords: VS VR Parcel Parcal parcell shelf shef shalf sahlf sehlf removal removel strip )
Right.
-Introduction
Welcome to the illistrated guide on a VR and VS parcel shelf removal guide. this guide may also apply to a VN - VP but I am not sure. ( Anyone in perth want me to pull theirs out? ) The main reason someone would want to follow this guide is because they have a new set of speakers and want to fit them.
Because my new speakers were put in some time ago i wont go into there, the car audio forum is the place to ask about that, I'm just showing how I remove my shelf.
My car ( used in guide ) is a Series one VS Executive, I am confident that other levels, Acclaim, Berlina Calais Statesman etc are very similar in their general makeup, the major difference would be the materials used.
-Tools
The tools required for this work are simply,
+A 10MM spanner or socket with small extension
+A 13MM spanner or socket.
+A Pair of hands ( one pair will suffice )
-Before you start!
Be wary I remove my back seat's lower part by lifting it from the back, to unhook it normally is tricky, by removing and replacing the rear seat my way there is a change that the rear of the seat will scrape at the backs of the seat, be careful that you do not tear your fabric or cut your leather!
-Onto the guide!!
Ok first you will need to remove the bottom section of the seat ( the "ass" bit ) This is done by placing your hand down in and under it then simply lifting it up, from there the seat should be able to be pryed from the hooks that retain it
and lift!
Once the seat has been removed, you will see that the "backs" are made up three main parts, the Left and Right sides, and the normal Center "hatch / flip down"
At the bottom of the left and right sides are 10mm bolts with a washer, simply undo these and remove the bolts
Hah! got it out!
Once the bolts have been removed the seat backs are ready to be taken out. To do this, they need to be lifted off their hooks by about one inch. Place your hand underneath the back and lift it up, it may need a little coaxing to come away
Please note, in the above picture, i have lifted the seat far more than Needed, once the seat is about one inch up, you should be able to grasp the top and pull it towards you.
At this point, lower the middle section, there is no need to remove it as we are able to work around it.
In total, accross the face of the shelf is 5 "push lugs", the simplest method to remove these is to twist and push from behind them untill you have enough room to either pull them free or lever them with a spanner, forked item or screwdriver, there are 3 in the shelf itself and two retaining a "Dress face" plastic cover.
Next, ontop of the shelf, there are two more lugs, the removal procedure is the same, twist and push from below, once you have enough, pry it out.
Next we have the "Baby Bolt" ( Baby capsule/seat anchor point ) This is a 13mm bolt which is quite easy to remove. Note: some people have this upside down for use as a earthing point for their audio system.
Now finally the shelf is ready for removal. to do so, simply pull it towards yourself but be wary that it may get caught on the edges where the seat belts are, you may also need to flex the shelf a little ( push the outer edges together and allow the middle to raise ) to aid the removal.
you may either remove the centre seat belt assembly or simply place the shelf to one side allowing you access to the rear speakers.
the re-installiation is pretty much reversed removal. of note, be sure that you do not get the seatbelts caught with the shelf as you put it back, and the shelf may again need flexing to ensure it "drops" below the C-pillar rear quarter glass.
When replacing the seat backs, the outer side hook ( closest to seat belt ) is the one that normally has troblve clipping in, the best method is to align it and apply pressure to the seat as you tap it down. if the seat still freely pulls toward you, pop it up and try it again.
When putting the bottom section of the seat back in, place the seat so that its wire part is over the opening of the spiral clip, retieve the seat belt connecters and push the back down. from here applying presure to the front of the seat ( I.E. sitting on it ) should make it pop back into normal position.
-Conclusion
Well I hope that this guide has helped some people with troubles in removing their rear seats. If you find any errors in my descriptions, please let me know. If you find any spelling or punctuation errors, don't let me know. If you would like more information pertaining to this guide, please do not hesitate to PM Me.
-Bonus Material!-
Ok well one of the fun things about removing the rear seat is finding the little treasures that got under there that you dont know how they have.
Such an example is $1.60 and a lighter. now the money i can acocun for, my sister normally rides in my back seat with a friend so they could of eaisly lost the money, the lighter, i have NO idea how that got there, however incidently i know it was one of mine.
Also I made mention of my speakers already being installed, they are nothing special but i have a pioneer 3-way 6.5" which had the three-screw mounting holes so i could install the speakers without making any modifaction
Thankyou for taking the time to read my guide and I hope it was informitive and enjoyable!
attn Über geeks, i play Second life. Patrio Graysmark.
Hi dude, excellent write up. The pictures help people out so much more than words sometimes. I was considering doing a write up for this myself once my holidays started, but you've saved me the time and effort! I might be doing a write up on a few other things over the coming weeks. Keep up the good work hey![]()
thanks, in all honesty i was bored that morning, remembered that BeastVS was having troubles so i thought ah heck why not
if anything i should re-do the photos to somewhere as atm they are hosted on my in house ftp so loading speeds and uptimes are a little worrysome
dont know what i might do for future writeups, though admittably i have two days off and my roof lining could do with fixing up....
Hey mate,
nice write up, very useful.
is it the same if your putting in 6x9s?
i gota vr and was havin a squiz today, looking into puttin 6x9s in it i got layin round.
Just wondering if its jus as easy, with the exception of cutting the 6" hole bigger to fit a 6x9.
Would it still fit in underneath when putting the shelf back in, like wood it hit on the braces n brackets that r under the parcel shelf in the boot?
Thanks, any replies will be appreciated.
you might to get some spacers to fit 6x9's, theyre only about $30 from a supercheap or strathfield...
Loudness - the intensity of sound!
www.globalhardstyle.com
check it...
if your going to go spacers, get carpeted MDF ones, plastic spacers make little puppies cry and they will eventually melt.
you can flush mount your 6x9's by hammering out the speaker bracket but many people are sayign that even though its not structural it still can be defectable. i personally dont think removing the bracket is defectable but i like the idea of keeping it should you decide to switch back to 6"ers
heh i found $6.80 in my stato when i pulled the back seat out and i found like $2 and some green pencils in the commodore and a hollow point live bullet in my uteawesome what you find in second hand cars
better check for blood in the back, might of gone roo hunting lol
or people... dont take notice of those fingers and human hair.
Cant bullets go off under extreme heat? ... if so lol good thing you got it out.
yeah wow thats a great guide thanks heaps
Planned Install for VS
HU:JVC KD-AVX2 Getting Soon
Screen: in dash 7"widescreen
Front Stage:165v2 might have to rethink thanks to defty's advise
Rear:165v1 owned
Sub:33 V2 maybe? have no idea really
Amps: Jaycar 200wrms, 300wrms owend .to be upgraded later plus Fans, maybe Monoblock
Sound Deadening:Dynamat front doors and Boot
Hardrive: new plans hardrive possible a ipod
If You See Any Gd VS Please contact me really want one so install can begin
I just had the best idea.
Armed with some thick work gloves (To avoid needles) me and a mate might go to pick a part and lift some back seats, never know for the cost of the one doller entry might find something worth while.
:P
I found $12 in total (6x $2 coins) bonza!![]()
VS Berlina Series II
how easy do 6.5" fit?
Rear:165v1 owned
hey nice going with the search keywords! helped me out! i've been trying to find this info out for a while, very usefull
are you able to reupload the pics or is it my pc that isnt veiwing them
it should just fit in, guy at harveys told me so but i can't guarantee that. also, i think vr/vs have the middle seat belt coming through the parcel shelf, and you don't want that so it will leave a hole in the parcel shelf...
how come you want one? if you just want it for stock look, grab a vn calais parcel shelf which includes the stock grilles to hide your speakers. that's what i ended up doing. although it doesn't have the centre brake light so you have to cut off the piece of metal under the parcel shelf that mounts the light. perhaps vr/vs parcel is built so that it will interfere with the brake light mount too? that's the only problem i can think of, and it's easy to remove anyway.
Last edited by levymetal; 22-01-2008 at 11:01 PM. Reason: spelling of the word 'brake'. stupid me!
Whilst i would love a VN Calais parcel shelf with the grills, the issue is i cant find one, but have found tons of the VR and VS parcel shelves.
hmm, well call up your local wreckers (harveys) and ask them if it will fit. if they say yes, ask how much they charge and if they are cheaper than the ones you've seen then go ahead and buy one, and if it doesn't fit you can take it back and tell them off for lying
i paid $15 for mine and i think the guy said it was the same price for vr/vs parcel shelves..
if you are indeed on the peninsula then:
Harvey Wreckers
400 Warrandyte Road, Baxter, Victoria 3911.
Ph: 03 59711132
Oh and if you need the pictures that came with this article I can make up some more today. I think I might do it anyway, only takes a few minutes and heaps of people have probably crossed this article and got confused because there are no images. I find that I am much more confident when I have seen pictures.
as i type this i'm throwing the pics your way levy, sorry all for loosing the pic hosting, my little toy server bit the bullet and i just havent bothered to patch it up ^^;;
as for the pic levy, you have my permission to do as you wish with 'em, change resize tag scribble on crop reupload, all yours![]()
ALL RE-UPLOADED, I TAKE NO CREDIT THESE ARE THE ORIGINAL PICTURES! ENJOY!
-Introduction
-Tools
-Before you start!
-Onto the guide!!
and lift!
Hah! got it out!
-Conclusion
-Bonus Material!-
Cheers for posting this, will come in very handy tomorrow when I recover mine![]()
