Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Holden Commodore How-To's
Holden Commodore How-To's Ever wondered how-to replace everyday parts on your Commodore and save hundreds in labour costs? Look inside if your keen.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 22-02-2007, 04:43 PM
Ride: VSII L67 Statesman
Trade Rating: (0)
quiksilv3r Executive
Default Removing Rear Rotors - VS Statesman
Well I needed to get my rear rotors machined the other day, so I thought I'd throw up a basic DIY on removing them to take them in to get machined. Saves a big lump of cash by doing it this way ($22 per rotor for machining, compared to $200+).
Tools needed:
Trolley Jack
Axle Stands
Wheel Brace
15mm Spanner
17mm Spanner
18/19mm Spanner
Zip Ties
G-clamp/piston tool
Step 1.
Park car on an even surface and slightly undo wheel nuts for the rear wheels.
Step 2.
Jack the rear of the car up (I used a trolley jack under the diff) and place axle stands under each side for extra support. Also, go inside the cabin and release the handbrake (important for later).
Step 3.
Remove wheels. Undo nuts in a diagonal pattern and put wheels somewhere out of the way.
Step 4.
Removing the caliper. If you look to the inside of the caliper you will see two bolts holding it in place. A 15mm Spanner and a 17mm spanner were used here - the 15mm for the most inside, and the 17mm to hold the inside nut in place. I removed the bottom bolt first, then the top.
This is what it will look like now
Step 5.
The caliper is now completely loose - with the only thing holding it to the car being the brake line. Making sure not to pull or kink the line, zip tie the caliper to part of the suspension so it is not hanging by the brake line (I used the coil). Also, remove the brake pads and place them somewhere safe.
Step 6.
Next part to remove from the hub is the anchor plate (the part that holds the caliper in place). THis was either an 18 or 19mm bolt so grab the 18 or 19mm spanner and undo the two bolts from here (can't remember which one it was, was a while ago now). Once removed, place the anchor plate somewhere safe.
Step 7.
Now the only part left on the hub is the rotor itself. Giving it a slight pull will loosen it and it will slide off the wheel studs. One side was a bit harder than the other, but some moderate force got it off. This is where taking the handbrake off is important - as the rotor will be near impossible to remove with the handbrake locked on.
Step 8.
Reassembly is the same in reverse order. Refer to other guides to installing brake pads to get the piston in and what not ((Here).
My wheel brace - complete with spark plug socket to fit into the holes for the wheel nuts, and lock nut bit.
Dodgy uneven sticker h34r:
Beer also helps
I'm no expert so there is probably some bits that I have missed. Feel free to add anything if you see fit.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 18-10-2007, 08:30 PM
big m's Avatar
FIGJAM
Ride: vslll v6 2000 olympic series ute, vp v6 sedan
Trade Rating: (0)
big m Executive
hey, good post but i am having trouble with mine ive got the callipers off no worrys but the roter wont come off and someone said there is some little star nut or something found that and i have turned t both ways as much as t would go and tried pulling it off but still no luck any tips
cheers
__________________
Homer: "for once in my life someone is calling me sir without (your making a scene)"
  #3
Old 18-10-2007, 08:34 PM
Peanuts Inc.'s Avatar
Ride: 355 VG :)
Trade Rating: (2)
Peanuts Inc. Caprice
block of wood, big f*ckin hammer hit the block of wodd into the rotor and keep turning the disc so it hits in a different spot and it works its way off once the handbrake has been slackened off
  #4
Old 18-10-2007, 10:43 PM
big m's Avatar
FIGJAM
Trade Rating: (0)
big m Executive
cheers thanks for that peanuts will give t a go
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
need help asap, removing VP live axle rear brake rotors. cruzncommo General 6 10-09-2007 09:00 AM
REAR brake upgrade to VT calipers and rotors Peanuts Inc. General Discussion 2 30-12-2006 08:44 PM
removing rear garnish on vs statesman??? jerzey1234555 VR - VS Holden Commodore (1993 - 1997) 0 11-10-2006 09:51 PM
Removing rear pacel shelf on Statesman??? Anyone? HIROLLA VR - VS Holden Commodore (1993 - 1997) 12 15-03-2006 10:01 PM
removing rotors 2DOGS VR - VS Holden Commodore (1993 - 1997) 9 26-09-2005 08:21 AM
Loan | Recreation 2007 | Property Search | Car Loans | Credit Cards | Car Reviews
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
