Okay so here is how I did it.
Firstly I would like to say that if you do this I cannot promise it is legal, will work, wont stuff things, blah blah.
Tools needed.
Drill
Socket Set (Cant remember sizes)
Knife
Hack Saw
File/rasp
screw driver set
alan keys
Materials
1 X Extra Panel Filter Box $30 from wreckers
1 X CAI $60 from Holden
1 X CAI to Filter box joiner $15 from Holden
1 X CAI mount screws $5 from Holden
1 X 90 degree air inlet pipe $10 Autobarn
1 X fiber glass repair kit $24 Autobarn
1 X pod filter $35 (Depends on what you want, I Bought a cheapy)
Step one
Remove the old air box, the whole thing, leave the plenum pipe though, no need to change this
unless you have a fully sick one you REALLY want in there.
all you need to do to do this is undo the hose clamp on the plenum pipe, then undo the clips on
the airbox, open it, remove the filter adn undo the three nuts on the bottom on this inside.
oh and remember to unplug the wires connected to the airbox if there are any, we will worry about retrieving that part later.
Step two
keep the removed airbox and filter just incase and grab your newer one, rip off the dicky little
snorkal thing from the front on the bottom half of the airbox and drop kick it, now you will need
to cut the hole a bit to fit the airbox to CAI joiner, match it up, mark it and cut it, do this
bit by bit if you want and you have less chances of making a mistake.
Step three
Grab the top half of the new airbox and start making that hole a bit bigger, remember to remove
the old plenum pipe joiner first, from the inside and the out, you will need the alan keys here.
Fit the 90 degree pipe, keep working at it slowly untill you can get the pipe in on an angle
that allows the pod filter to be fitted, remember you will need to remove and reinstall the pod
filter at times.
I actually had to cut my pipe a bit shorter because the plenum pipe wouldnt quite fit otherwise, just wouldnt squash the way I wanted it too.
Step four
Line everything up on the top half of the airbox, fibre glass it shut, once the fibre glas has
set you can spray it black too if you like, I sprayed mine and the pipe and even my engine cover.
Step five
Remove the air temp sensor from the old airbox IF ONE WAS ATTACHED.
it will have been on the back of the top half, remeber those wires? if not then you dont need to
do this, if so well then this is easy anyway.
grab a flathead screwdriver, look inside the airbox, push the flat head under the little metal
ring holding the sensor and turn slightly, do this a afew times and it will pop off.
Step six
Grab the new airbox top half and drill a hole for the air temp sensor, push it in so the plug is
on the outside, take the metal ring and push it on from the inside of the box, walla its fitted.
Step Seven
screw the new airbox bottom half down, remember those three nuts?
drop the top half down and snap it on there, then connect the plenum pipe and tighten up that
hose clamp.
fit the airbox to CAI joiner to the front, atm it will look kind of useless aye :P
grab the CAI and sit it on top of the radiator housing, I lined mine up perfectly square with it
as best I could by eye, and never had any dramas.
Drill three holes, being sure nto to drill too far, just the housing will suffice, push your holden screws in.
I cant remember the drill bit size either, im fairly useless tbh.
oh nice :P oh rice
P.S remove the 20 amp engine fuse for a few moments to reset the computer. will allow it to adjust to its new air intake a little better, or so im led to believe.
Image Index
Image 1 - I had to cut the bloody pipe
Image 2 - Expand the hole
Image 3 - Air temp sensor
Image 4 - CAI
Image 5 - The Pod in the box
Image 6 - The only usefull pic
Last edited by DannyboyDS; 09-03-2007 at 08:39 AM. Reason: Last version looked like a childrens story, written by a child
any pics? ??
just remember VP / VN owners.........only problem with fitting holden CAI's to your VN / VP is the fact that alot of the time the manifold you mount to your radiator plastic cover sometimes blocks your bonnet from closing and u may need to heat the very ends of the manifold and squash them flat so u can close your bonnet properley
Okay pics added enjoy, any feedback, mistakes whatever, let me know.
I'd like to add something here, having a pod filter inside the airbox is no different that having a panel filter. The size of the CAI is what restricts your air flow. The principle of the pod is to have as much surface area in contact with the atmosphere as possible. The CAI can only allow so much volume and it isn't enough for the capacity of a pod. A better thing to do would be to mount the pod down behind the bumper with the piping going back up into the airbox and getting rid of the CAI if you want to retain the original look. But that is just my opinion. Another thing you can do is to cut the sides out of the front and the passenger side of the lower half of the box to expose as much of the pod as possible. The CAI will bring enough cool air in to keep it below the engine temp.
Keeping in mind evena cheap pod filter will allow more air flow than a standard panel filter, the only panel filter that matches up is a K&N high flow and they are like $100.
My set up cost a little at first, but whenever I do a filter its about $30 to $40
With that said I could put the air flow piping and a cone mounted down low at the opening on the front of my VS bumper, which would have the same effect without the risk of the car inhaling a puddle.
I see your point, but I have to disagree in part.
The filter does the job of filtering out water, if it was an issue then you wouldn't be able to drive the car in the rain. The CAI would suck the water right in.
YOu are entitled to your opinion mate, prehaps you should start your OWN thread in the general section, this is a how to.
I can promise a high flow filter will not catch any water either, well maybe a 10th of each drop, the CAI is located under the bonnet remember and is at little risk of sucking in any water, numerous threads related to CAI discuss the risks of water entering the system, I too believe it is a valid cause for caution, a standard filter will stop more water, but lets less flow of air.
Also I have never once found water in my airbox, have you ?
Even if you did, due to the position of the pannel filter and in this case the pod it would most likey drain out the bottom, having an exposed filter would be insane however, not to mention the amount of crud that would stick to it.
A setup like what you are talking about with a pod is for racing. not street driving, you still havn't addressed the origional issue, which is boxing a POD filter, like I said a cheap high flow Pod filter is better then paying $100 for a high flow panel filter, some people prefer a POD, I like my POD and I like it getting Cool Air.
Lastly, this is not a Panel Vs Pod Thread it is a how too.
after a bit of poking around I have to agree with Not an Abba fan, if the high intake filters with a CAI are for you, just use a K&N panel Filter. thats what im gonna do.
I have seen dyno tests that showed a pod filter is no better than a standard paper panel filter.
Wouldnt that depend on the car and its other mods?
in either case a high flow filter should always make some improvement even if it can be measured in fractions.
Im changing my Pod for a high flow panel filter, with the CAI on my VS that should be nice, ill do the exhaust when I can afford it a 2.5 inch cat back as well.
Might even get some more economy under light footed driving.
sure you have....prove it, post up the dyno graphs.
oh. but thats right, it was a friend of a mate of a monkey that did the dyno run and his printer wasnt working that day so i didnt get a copy of the dyno graph...
what a rediculous thing to say man. how on earth could you come to that conclusion - its all relative. if the car in question is a stock charade then the difference between both types of filters would be minimal. however if you were to chuck a turbo or two on the charade then the increase in airflow from a pod would be benifitial and show relative hp gains.
Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
lol I cant stop laughing Pete![]()
208rwkw 13.5 @ 102MPHSTROKED AND BLOWN
can everyone F^&(*# off to there own thread to fight and argue......
I'll say it once more ^@&*()^@*)& ^&()@^Y)(@ ()@^&*(&*(^&@^!^&!)(!^%@#!$#!%$#!%@!# @!#%^&@%$#&@#
OFF!
THIS IS NOT A FRUIT TINGLEING DEBATE.
START THE DEBATE IN ANOTHER THREAD.
Infact, i'll go start that thread for you, then i'll post a link.
here is the Link
http://forums.justcommodores.com.au/...204#post564204
seems the thread was deleted... unfair![]()
i'd just like to know where you bought a pod that small the only ones ive been able to find are huge.
cheers
ummm... its only slightly smaller then the K&N and I found it at Autobarn :P
I have a pod for sale if anyone's interested PM me. Only Perth area enquiries please, it'll be easier for all of us lol
WTB: mulberry VN interior parts
thats an awesome mod!!!!! very good way of makin aa pod filter cheap and legal
Holden VS Commdore Wagon, No1 Cruising Machine!!! On The Hunt For A New Beast...Its Time 4 Me 2 Get Uted!!!!
not exactly legal, just hidden.
Should be legal I think, pod filters themselves aren't illegal as far as I understand . . . just that most people don't mount them properly. A sealed pod should be fine I'm fairly sure...
Sam
thats right, most people get busted because they dont clamp the pod down to the man body, if u do that- or as this tut shows 'hide' it, u'll b fine
yep, the unsupported pod is what'll run you into trouble. Perhaps they're at a risk of falling off under cornering or something... don't know, just that if you use an appropriate bracket for support you'll generally be OK.
