Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Holden Commodore How-To's
Holden Commodore How-To's Ever wondered how-to replace everyday parts on your Commodore and save hundreds in labour costs? Look inside if your keen.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 25-03-2007, 07:09 PM
Marks-VY's Avatar
I love cars
Ride: VT2 Berlina
Trade Rating: (0)
Marks-VY Executive
Default How to install extractors (ecotec V6)
Well, other than a few scratches on my hands and some aching muscles (I need to exercise more...) I have fitted the extractors (and cat back system) without any real probs.
For those of you thinking about doing it, here are some instructions and photos.
Stock Manifold:
First, I removed the leads (I was replacing them as part of my servicing), engine cover, air intake cover and maf pipe. Also, from under the car I removed the nuts attaching the manifolds to the engine y-pipe and oxy sensors (remember to unplug them first). There is one more nut to undo on the passenger side, which I think is the EGR or similar. At this stage the manifolds are ready to be removed.
Undo the lock nuts first, noting where the clips for the spark plug leads were fastened. Then start loosening the manifold bolts (they look like nuts on studs but the whole stud comes out). The rear driver side bolt was very difficult to access, so best to start with that one, so that you are not stuck with one stubborn bolt. Carefully lift the manifolds up and out of the engine bay without scratching anything. I noticed mine did not have any manifold gasket and I would be interested if this is the same for all models.....
At this point you need to remove the engine pipe/cat from the rest of the system, or else you cannot pass the extractors down through the space between the engine and the inner guard. Only two nuts so it doesn't take long.
Extractors:
I did not receive any instructions with my extractors so I was not sure if I should have installed gaskets. I did not have them with me so I left them out (no leaks so far!!).
Also, if you have them welded to the engine pipe (the y-piece that includes the catalytic converter), you can never remove them as they need to be remove from the top, so I cut a couple of slots in the flange, and used u-bolts to fix them in place. Note there may be a tendancy for the flange to close in on the hacksaw if you do this, but it makes later removal so much easier.
Carefully pass the extractors down into the engine bay and line up the manifold with the cyliner head, having a bolt in one hand ready to screw into place to hold the extractors. Start returning all bolts but leave loose until they are all in, as there seems to be a lot of play until they are all in. Start tightening evenly until ready to torque.
Engine y-pipe modification:
Now the only tricky bit! You need to temporarily bolt the cat back onto the exhaust system, to work out where to cut it. You will notice by the photos that a lot of pipe is removed, including the support posts (note mine is a manual so an auto might be slightly different??). Once bolted loosely into place, lift the y-pipe up so it is level with the extractors, and mark it with a marker texta, sufficient so the pipes will push through the entire flange on the end of the extractor.
Use an angle grinder with a metal cutting blade and wear eye/ear protection. I reckon you would be there a long time with a hacksaw but if you don't have an angle grinder it may need to do. File all the cut ends to ensure there are no sharp edges or burrs that may make installation difficult. Also, make sure you remove any filings that could clog the cat converter.
Final installation:
Under the car, slide the cut ends into the flanges of the extractors. There may be a chance they do not align perfectly, so either find a mate to work on one side while you are on the other, or I wrapped an ocky-strap around the extractor pipes just to pull them in enough to align with the y-pipe. With a bit of convincing they should slide into the flange so that the cat can be bolted back into the exhaust system.
Refit the oxygen sensors into the extractors and screw in the egr pipe. Replace all leads and maf pipe etc, in reverse of the removal.
Start the car up and allow the oils and surface paint to burn off (there may be a lot of smoke...). Then after a final check to see all is tight, you are done!
In my case I fitted the cat back system that I had removed a while ago, which only requires two bolts where it joins the Y-pipe, plus 4 retaining clips that hold the hanger rubbers in place.
I am sure it is not my imagination that it has a little more bottom end, but the best part is the growl from about 2800rpm!
If anyone knows if gaskets should be installed, let me know!!.
Good luck!
how-install-extractors-ecotec-v6-imgp4641.jpg  how-install-extractors-ecotec-v6-imgp4644.jpg  how-install-extractors-ecotec-v6-imgp4646.jpg  how-install-extractors-ecotec-v6-imgp4647.jpg  how-install-extractors-ecotec-v6-imgp4648.jpg  how-install-extractors-ecotec-v6-imgp2755.jpg  how-install-extractors-ecotec-v6-imgp2761.jpg
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 26-03-2007, 12:00 PM
Spaced's Avatar
Ride: 1997 VS Commodore Exec
Trade Rating: (0)
Spaced Statesman
Admins please make this is a sticky and move to how to section. Very good write up mate.
__________________
<davy> remember when braveheart came out and everyone said you can't have mel gibson playing a scottish guy cuz it wont be realistic?
<davy> well look at him now
<davy> an alcoholic racist
  #3
Old 15-04-2007, 09:12 AM
Raptorsc's Avatar
RAPTR6
Ride: VY V6 EXEC II 208rwkw
Trade Rating: (0)
Raptorsc Executive
Yep a good write up for sure
__________________
Raptor Superchargers - Where blow means 3800's, Ecotec's and Alloytec's GO
Click link below for buildup of Supercharged VY V6 .....now showing 208RWKW with Raptor ProStreet Intercooled system
http://forums.justcommodores.com.au/...ad.php?t=42803
  #4
Old 15-04-2007, 03:32 PM
Jesse-James's Avatar
Jesse-James
Ride: VS seriesII commodore S
Trade Rating: (0)
Jesse-James Executive
thats going to be VERY handy. thanks mate.
  #5
Old 17-04-2007, 08:51 AM
Marks-VY's Avatar
I love cars
Ride: VT2 Berlina
Trade Rating: (0)
Marks-VY Executive
Quote:
Thanks for the comments guys! Can anyone let me know if gaskets should be installed? So far there has been no sign of leaking and I have been giving the car some hard work (sounds better that way.....)
  #6
Old 17-04-2007, 10:09 AM
Not_An_Abba_Fan's Avatar
Ride: MY08 Outlander XLS
Trade Rating: (0)
Not_An_Abba_Fan GrangeNot_An_Abba_Fan GrangeNot_An_Abba_Fan Grange
As far as I know, HM headers are the only ones to recommend not fitting gaskets. As long as you used an O2 sensor safe sealant on them. I would be going to get some gaskets anyway so you have them on hand when they do leak.
  #7
Old 25-04-2007, 12:28 PM
[MR SS]'s Avatar
Ride: VN SS 5 Speed
Trade Rating: (0)
[MR SS] Hitchhiker
why have u got a resi at the back, doesent that make it quiter?
__________________
=Brock=
The Undead, As He Lives In All Holdens Forever!
My Ride
VN SS 5 SPEED
  #8
Old 27-04-2007, 10:08 PM
Marks-VY's Avatar
I love cars
Ride: VT2 Berlina
Trade Rating: (0)
Marks-VY Executive
That is the resinator that comes with the Redback system. If you hold it up to the light it is actually a straight-through muffler with a serated bore. Yes, it is quieter although in my "old age" I don't want to harass the neighbours and I don't want cops to harass me!
  #9
Old 12-10-2008, 05:10 PM
fuzzy2308's Avatar
Ride: 95-3.8ltr-5sp-vs-ute ☠☠☠
fuzzy2308 Berlina
ood wright up buddd
  #10
Old 18-10-2008, 06:22 PM
terry1991's Avatar
Ride: 1994 VR Berlina Commodore & 1979 landcruiser
terry1991 Executive
nice right up can u list like all the tools and stuff please would be a great help!
__________________
Im Nooby With Cars So I Ask Alot Of Question lolol.... all help is good help
Check out my ride
http://forums.justcommodores.com.au/...a-1st-car.html
  #11
Old 03-11-2008, 07:23 PM
Ride: A Toyota?
the_random_hero Executive
Quote:
If you want to do it properly, you'll need a decent set of spanners, sockers and a big screwdriver, plus some sort of welder. Most exhausts I've seen attached by U clamps have had leaks, no matter how tight the clamps are.
Always use a gasket, even if it's just the original one with a good coating of sealant over it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
ecotec install!!! vt_on_20s V6 Development And Modification 0 13-11-2007 05:31 PM
extractors install Philthy V6 Development And Modification 14 27-03-2007 06:45 PM
Ecotec Extractors hendrickavic Parts For Sale 4 21-06-2005 08:00 PM
V6 Ecotec Extractors
