Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By kopper69
Thread: ABS Error Codes
    VRII Acclaim
    Jul 2005
    Default ABS Error Codes
    Error logs are a great thing. They will help you find intermittent problems and start you off in a general direction of where a problem could be. There is a great level of detail on the justcommodores site on checking error codes logged by the engine management system, but this does not detail anything about the abs system. The abs warning light is not as common as the check engine warning light. Reading through the posts, I haven't found any detail on checking error codes logged by the abs system.
    So here it is. For those of you familiar with checking the engine error codes, this procedure is so simple its not funny.
    Basically, to check the engine error log, you bridge the 5th (ground) and 6th pins in the ODB connector under the steering wheel.
    To check the ABS error log, using the same trusty calibrated paper clip, you simply bridge pins 5 and 12 of the connector.
    To find pins 5 and 12, start at the top left hand corner. That is pin one. Going to the right, you count pin 2,3,4 etc. Once you get to the end, jump back to the start of the bottom left level of pins and keep counting. Pin 5 is about halfway along the top row, pin 12 is a little left of the middle in the bottom row.
    Reading the error codes is the same procedure (counting the flashes), except now, the ABS light flashes (as opposed to the engine light when checking the engine codes).
    The ABS log also uses code 12 firstly, with any errors logged shown after that. If no errors are logged, the 12 will flash again.
    Error codes for the ABS error log (VR/VS) are as follows:
    12 Diagnostic system operational
    21 Right hand front wheel speed sensor fault
    23 Right hand front wheel speed sensor continuity fault
    25 Left hand front wheel speed sensor fault
    27 Left hand front wheel speed sensor continuity fault
    28 Wheel speed sensor frequency error
    31 Right hand rear wheel speed sensor fault
    33 Right hand rear wheel speed sensor continuity fault
    35 Left hand rear wheel speed sensor fault
    37 Left hand rear wheel speed sensor continuity fault
    41 Right hand front inlet solenoid valve circuit fault
    42 Right hand front outlet solenoid valve circuit fault
    45 Left hand front inlet solenoid valve circuit fault
    46 Left hand front outlet solenoid valve circuit fault
    55 Rear inlet solenoid valve circuit fault
    56 Rear outlet solenoid valve circuit fault
    61 Pump motor relay circuit fault
    63 Valve relay circuit fault
    71 ABS control module internal fault
    The above guide has been verified on a VR/VS. Checking the error log on all models prior to VR/VS is the same for the engine log, and I would assume that the same can be said for the ABS log, would be happy if someone could verify this for me.
    Above codes are also for VR/VS. Later model commodores may have different meanings for each error code and/or more error codes. I will try to get a list for as many models as possible. Any help from other members would be most appreciated.
    kopper69
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    Wow hey great work. Id give you some rep but I have to spread it around first :P
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    damn fine work koppers, didnt know about ABS codes..
    wealth of knowledge!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Thats great work Kopper69. The most common problem I've seen with the ABS is when the ignition is turned on whilst the dashboard is removed - then the ABS check system cannot confirm the warning light is working - there doesn't seem to be a code for this?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I must agree with the others, excellent information. Why had this not been discovered earlier?
    MY RIDE
    w427
    Nov 2008
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by joselitotafe View Post
    because you sir are an idiot
    Thats a bit harsh
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Nice work with this thread, i never new how to read the abs codes.
    So now I can read engine faults and ABS faults, what about Body Control Module faults ?
    andjob's Avatar
    andjob is offline GRNVSV6
    vs commodore
    Apr 2008
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Just had a look at the VT/VZ service manual and the codes are all the same as the VR/VS
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Just had a look at my manual for VT and VX and the codes are the same as the VR/VS
    Quote Originally Posted by kopper69 View Post
    kopper69
LinkBacks (?)
  1. VS V6 Error Codes
    By vsiicalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2008, 10:25 AM
  2. Error codes on Vs
    By PorterVs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2008, 08:10 PM
  3. Error codes
    By Jaym in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2006, 09:34 PM
  4. error codes 6 and 8?
    By Juzzy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2005, 07:12 PM
  5. v6 ERROR CODES
    By cuckoo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-07-2005, 05:52 PM
