Page 1 of 8 12345 ... LastLast
Results 1 to 25 of 181
Thread: How-to: Make a Diagnostic cable for your VN/VP Commodore
    Sep 2004
    Default How-to: Make a Diagnostic cable for your VN/VP Commodore
    After seeing a few people have trouble making these cables, or getting them to work, I've written up a small tutorial, with a revised edition of the schematic (Thanks Chuff for (parts of) your drawings).
    For this Tutorial you'll need:
    A soldering iron
    Some solder
    Pliers (long nose are especially useful)
    3 x 10kOhm 1/4 watt resistors
    1 x 9 pin RS232 plug plus casing
    1 x ALDL wiring connector, Supercheap part AERPRO Model No. APP0141; Car stereo wiring harness to suit Toyota Camry 87-89, Celica 87-96, Corolla 87-96, Land Cruiser 87-96
    1 x length of cable, can be Cat5 cable, security cable. Must contain at least 3 wires. (1 to 2m is good, maximum 9m).
    Some electrical tape, or if possible, some small heat shrink.
    NB. Tinning is the practice of soldering wires to prepare them to be soldered to another wire.
    Firstly, grab the wiring harness you bought from Supercheap and go match it with your cars ALDL connector. This is the connector you want. Cut of the excess connectors, and try to leave as much cable on the plug as possible. Pull the cables out using long nose pliers on all pins. Re-insert singular wired pins (some of the pins have 2 cables on them) back into pinholes 1 and 3. Cut the cable off 2 of the pins, and insert two of these pins into pinholes 2 and 4 (these help in guiding the connectors together). Strip the insulation off of another pin, then cut it back so some copper remains (about 1 cm). Tin this with solder. Tin one of the resistors with solder, and join the resistor to the pin you stripped. grab another pin, and from the pin end, strip the insulation to reveal some copper. Dont strip it completely! Tin this small segment of copper, attach the other end of the resistor to this segment. Push these pins into pinholes 5 and 6. Onto the Serial end.
    This bit takes some fiddling. Grab the serial connector. If you look closely, you can see the pins are numbered on the back and front (If not, the view in the diagram is from front of the connector). Snip some of the leg of a resistor, and put it into pin 2. Place the transistors collector leg into pin 2 also. Now solder these into the pin. Put the emitter leg of the transistor into pin 5 on the connector. Grab the cable (the cat5, etc.) and strip the sheath back (outer insulation) about 5cm. Cut all but 3 wires off. At this point, note which wires you are going to use as Data, Ground and Voltage. Write them down! Data attaches to the resistor coming off the base of the transistor, Ground to the emitter and Voltage to the resistor in pin 2. Strip one of the wires back about 1 cm. Place it into pin 5 on the connector, and now sodler the wires in pin 5. Now, bend the base of the transistor back on itself (as if it were pointing at the cable). Shorten the resistor, about 1cm of leg at each end is good. Tin both ends of the resistor, and the base leg of the transistor. Solder the resistor to the base of the transistor. Tin the other end of the resistor in pin 2. Attach your Voltage wire to this (remember, you wrote it down!). Solder your DATA wire to the resistor coming off the base of the transistor. Put some tape around the cable, and attach the small metal bit that stops the cable from pulling out of the RS232 connector. Put it all in the case, and screw it up.
    Now, get the other end of your cable. Strip the sheath back about 5cm. Cut out all the wires except the ones your using for DATA, Voltage and Ground. Strip back the 3 wires from the ALDL connector, about 1cm. At this point, if your using heatshrink, its a good idea to cut 3 small pieces off, and put them on the cables. Tin the bare copper on each of the wires. Now strip the insulation off your 3 wires on your cable, and tin them aswell. Now solder your DATA wire to the wire on pin 3 of the ALDL connector. Then solder your Voltage wire to the wire on pin 1, and lastly your ground wire to the wire on pin 6. Put the heatshrink over the soldered joints, and either gently touch it with the soldering iron, or use a hairdryer/hot air gun to srhink it. If your using tape, wrap some around the joints. We definetely don't want them touching. Wrap some tape from the connector, all the way to where the sheath starts on the cable.
    Voila, your done! Now all you need to do is connect it up to your laptop, and start logging with WinALDL; http://winaldl.joby.se/ .
    If anyone has any queries, questions edits or comments, feel free to post, or message me. Enjoy :-)
    VZ SV6
    Jun 2004
    Good work there very well writen... i should have made one for mine.. but i got it from ebay awewell it works so thats the main thing.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    is there one for vr/s commodores?
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Sep 2004
    Quote Originally Posted by markovr
    Yep there is, check out the other ALDL thread. I made this modified one, since some of the info for the VR/VS one was different to the VN/VP one (different connector).
    MaNiac_VP is offline Mr Moderator !
    VPII Calais
    Oct 2003
    Sep 2004
    If anyone wants a cable made up for their VN/VP for just the cost of parts + shipping, message me. Its currently at $35 per cable (inc. shipping to any state), but could become lower if I manage to contact AERPRO about getting either the harness' or connectors seperately. If I can just purchase the connectors seperately, the price could drop to around $10 for the cable.
    Im also in contact with the author of WinALDL about whether he's interested in developing it further, or if I/someone else could take over (limited programming skills here).
    Lastly, Im hoping to find some individuals with up-to-scratch cars who have cables, or who live in Perth so I can gather some data on different types of cars, and go down the track of diagnosing problems via ALDL rather than us spending hundreds at Holden dealers. I know the older models are getting long in the tooth, but it seems a lot of owners are hanging on to the cars. Even if we can start the same sort of thing with VR/VS all the way through to the VY (No idea about their ALDL characteristics) it might prove a good hobby for most.
    If anyones got any ideas or suggestions, feel free to message me.
    VP 93 BT1
    Aug 2004
    Hi guys, is anyone having trouble getting everything working correctly?
    I built a cable up and in winaldl I get 3 or 4 streams coming up when the car is in acc, but as soon as I switch the engine on the stream of data stops.
    I built the cable using a bc559b and then tried a bc548. I later realised that there is a recommended list of transitors that I was meant to use. Anyhow I bought some 2n2222 today and chucked one in. I still get the same problem. This time at first I had a few more bits of data coming through, all the way to 'tps' but again as soon as I switched the engine on the data just stopped.
    Also particulary when I used the other transistors and started the engine, I started to get a very rough idle.
    Originally I was taking the 12v supply from the the car, but since have connected it directly from the serial port.
    Anyone have any idea what's going on?
    Pete
    I'm driving a 93 VP BT1
    As for laptop I was using a 233 with win2000, and have also tried a 133 with w98
    abzy Guest
    VP 93 BT1
    Aug 2004
    abzy ...google is your friend
    Anyhow I managed to get it working by modifying the circuit on techedge:http://www.techedge.com.au/vehicle/aldl160/aldl_hw.htm
    I had to remove R4 to get it to work though.
    Also take note that the 'colour codes' for the resistors are messed up so don't go by them if you choose to build this circuit. ie black brown orange should read brown black orange and so on.
    I'm still a little dissapointed as the rate at which the data is read is really slow, approx a sample per second at 2400 baud. This is pretty crap if you don't mind me saying. You can set the programme (winaldl) to 4800 but you end up loosing 3/4 of the data and the dash and sensor data don't show anything.
    I mainly wanted to know 02 info, but my figures are jumping all over the place from extremes such as 0.05V to 0.8 Also with the cable connected the car idles really badly and I think it's making the car run rich.
    Without the cable connected the car idles fine.
    So yeah I don't know what the deal is, I just realise there is lot of stuffing around and I've got lots to learn interpretting all the data
    Fellas let us know what your experiences are :b:
    Sep 2004
    Firstly, my cable doesn't affect my cars idle. I think your problem may be the wiring of your circuit. If your running in open loop mode (running the car with the diagnostic pins short circuited) you will experience reduced idle, as it disregards any fuel trim data. This could happen because you have a short where the 10k resistor is supposed to be. If your having serious troubles, try building the whole thing on some project board where you won't have problems shorting wires squeezing it into the DB9 connector.
    Secondly, your O2 values will jump. They should be jumping from high to low constantly. The computer only detects an O2 fault if a low or high reading (or open circuit) is detected for a specified amount of time. This time increases when cruising. So don't stress, your O2 values are reading correctly. If you graph these over a long enough time, you should be able to get an average, and create a straight line, if the O2 sensor is dodgey, you'll have dips in the 'average' line.
    Thirdly, you can't read data any faster. 160 baud is the rate at which data is sampled. This is a restriction of the cars computer, not of the cable or computer/laptop. Theres no way you can sample the data any faster, unless you own a VR/VS which have a different ALDL baud rate, and thats a whole new cable setup. If you take data over an extended period of time (30 minutes gives good results) then you can actually find some good information. The design I've used works perfectly on VN/VPs. Now Im just working on a 'standard' set of data, so people can compare.
    VP 93 BT1
    Aug 2004
    Quote Originally Posted by richie83
    Yeah I think I might try some more circuits on a breadboard. I did double check everything twice but i still got nothing when I switched the engine on. I'm thinking that maybe the cable I'm using could be causing problems?, it's 3 meters of standard 240v extension cable stuff.
    I've been looking on the net the last few hours and have noticed quite a few different variations. I reckon I'll try them all and see which one is best.
    I thought that might had been the case with the rapid flactuations. i got my self a new O2 sensor so i should be right
    Yep I just came across some info on the data stream, basically yeah 1.5-2 seconds per sample max.
    I started typing in some data that I collected into a spread sheet (was hoping to cut/paste).
    Have you found an easier way of transfering the data?
    Thanks,
    pete
    VP V8 Calais
    Nov 2004
    Quote Originally Posted by pete_pumpkin
    Thanks,
    pete
    If you use WinALDL, then the data is saved into a standard TXT file which can be imported directly into Excel.
    CATCH!
    VP 93 BT1
    Aug 2004
    Cheers, yeah that works well . .just need to work out how to do graphs etc.
    Cheers again
    VP V8 Calais
    Nov 2004
    Talking
    Cheers again
    Select the columns you want to graph, and click the Chart button or select Chart from the Insert menu.
    From there, just follow your nose. It's easy.
    PS: I prefer line graphs as they are the easiest to read.
    CATCH!
  15. #15
    Sep 2004
    For the data, all I do is name the columns, then cut and paste all the data into Excel. From there, I delete what columns I don't need, such as PromID, then clean it up, ready to be converted to graphs.
    Also, it won't matter what cable you use, 240V 1.5mm^2 cable is able to carry 16A @ 240V, that equates to around 320A @ 12V, so you have no problems with resitance there.
  16. #16
    Aug 2004
    Okay today tried to make the cable with no succusses. I got the ecu plug and wired that all up and it is sound. I got a 2n3904 402 transistor and a 9-pin plug. so I either think the transistor is no good or the pin is wired wrong I have tried it on both m vn and vp but with no luck. any ideas on what to do? and is there a procedure to make it work ie start car plug in open program or what
  17. #17
    Sep 2004
    Double check your transistor, that will be your main problem, also check you have the components on the correct pins (they should have tiny numbers on the plastic backing). Turn your car onto Accessory, you should see the check engine light flickering randomly, this means its at least in ALDL mode and receiving data. You should just be able to plug it in, then open WinALDL and start reading. Also, check your COM port setting in WinALDL, and that it is set to 2400 baud.
  18. #18
    cyan_eyed Guest
    Hi, thanks for the info, I'm building the connector/setting up a laptop at the moment. Just to confirm, though, the picture with the ALDL pin 1 at the bottom left shows the plug as if you're looking at the pins, right?
    Again, thanks for this info, I'm gonna find out at last why I'm only getting 14 litres to the hundred!!
  19. #19
    Sep 2004
  20. #20
    cyan_eyed Guest
    Default Has anyone else smoked their car trying this?
    Ok, so I turned the car on, booted up the laptop, plugged in the ALDL and the car died and won't start again. No instrumentation in the dash but other electrics work (wipers, interior light, starter motor cranks). Have checked certain fuses, but all look ok. Also, the fusible links look OK to my eye, but I've never seen a blown/fused/etc one. is it possible that I've smoked my chip? I'm confident that I wired the cable right, and the laptop is fine (why couldn't it be the other way around? the laptop was old and cruddy!). Any suggestions? Where should I start looking for the problem?
  21. #21
    Sep 2004
    It could be possible, Definitely check your fuses again. If its blown, it will be black inside, and the little wire in it wont be continuous. Try unplugging your battery and leaving the car for 10 minutes, and try starting it again.
  22. #22
    Slooth's Avatar
    Slooth is offline Driver
    VH EFI V8
    Oct 2004
    Thumbs up
    I'll be keen to get one. I have the laptop but don't have the time to build a cable (and my soldering iron is stuffed at the moment). It would be cool to see what is actually going on in the brains.
    Let me know how you go.
  23. #23
    Sep 2004
    Slooth,
    I've made about 15 so far, all working like a charm :-) The only problem at the moment is the cost of the connectors, about $20 a piece from Supercheap, and I can't source the connectors anywhere else, as of yet.
  24. #24
    cyan_eyed Guest
    Finally got mine working, and just in case anyone makes the same mistake as me, the pins on the ALDL plug are numbered as you look at the pin end of the CAR connector, not the cable you're building! +12 volts is the pink wire on a VN, but if I'd only checked with a multimeter beforehand...
    Does anyone know what BLM and INT are?
  25. #25
    Sep 2004
    Im quite sure INT is injector timing, as the same values appear in EFILive under injectors. As for BLM, Im not too sure what it is, as Im still discovering the program ;-) But I do know that both these values are in closed loop mode, ie. The car is operating off data coming straight from the ECM, and just adjusting the trim. This is usually when your oxygen sensor plays a big part in economy.
  1. diagnostic cable
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2006, 07:57 PM
  2. Replies: 7
    Last Post: 12-02-2006, 01:58 PM
  3. VR/VS Diagnostic cable
    By kopper69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2005, 03:23 PM
  4. diagnostic cable trouble
    By dougie tas in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2005, 10:35 PM
  5. Vn-vp Holden Commodore Aldl Diagnostic Cable. V6 ,v8.
    By dcherry in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2005, 08:33 PM
