Results 1 to 17 of 17
Thread: How To: Keep your radio on until you open the drivers door
    VE2 SS Voodoo
    Jul 2005
    Default How To: Keep your radio on until you open the drivers door
    Hey guys, this is my first How To so plz be kind
    Ok, well to start with i wanted to wire up some relays so i can have the radio stay on until i open the drivers door with the key off, exactly like the VZ Commodores, so i did a bit of internet searching and came across the site, http://www.the12volt.com (i think he used to be a member on these forums?) and found exactly what i was looking for, but at first it didnt work and with alot of head scratching and different wiring setups i realised i had the wrong relays! lol, so got the right ones and sure enough it worked... ok so here goes the How To:
    What you will need:
    Wire Stripper/Crimper
    Electrical Wire - dont need heaps but couple of meters to be safe and maybe some different colours to so you know what wires what
    Box of Female blade terminal connectors (6.3mm Tab)
    In-Line fuse Holder + fuse
    Electrical Tape
    2x SPDT relays can get them at autobarn but make sure they are 5-pin with an 87 and 87a terminals (Relays, Single Pole Double Throw (SPDT), Automotive Relays)
    Steps:
    1.First off this was done on a VS so if you have a different model find out what your wiring colours are first, now we need to tap into the Acc wire and a constant +12v wire, i did this at the back of my Headunit. The Acc wire is the Yellow wire and the constant 12V is the Orange/White wire, splice into these with some extra wire(enough to get over to the fuse panel area) and remember which wire is what.
    2. Now we need to get a wire from the drivers door swtich to the fuse panel area, Pull off the kick panel on that side then undo the screw holding the door switch in and pull it out now feed another wire through that hole and into the area where the kick panel went, there are a couple of openings you can use, make sure that you have enough wire there to get it from the switch to the fuse panel area, now with the end that does to the door switch you need to splice it into one of the connectors there, i did this by cutting off the original one there, twisting the two wires together and crimping a new female blade terminal onto it, then just put that all back how it came out and remember which wire you just did, at this stage to we need to make a constant ground wire, i just got a piece of wire and put a ring terminal on one end and blade terminal on the other and secured that ring onto the screw that holds the fuse panel thing with all the fuses in place.
    3. Now with the constant +12v wire, you need to wire in a in-line fuse, pretty simple to do, just hook one end of the in-line fuse to the +12v and keep the other end bare for now....ok so now we have most of the wires we want, this pic is of how we need to wire the relays in:
    So as you can see we need to make two terminal connections for the Acc wire and +12v wire, thats as simple aas crimping the main wire with a secondary wire in to together and then crimp another terminal to the end of the 2nd wire, and also we need to make a loop wire, simple as cut a short length of wire and crimp a blade terminal onto either end
    4. this is what you should have so far
    5. ok now we just need to wire in the relays which is as simple as following the above diag, on Relay 1 connect the Acc wire to terminals 86 and 87 one of the +12v wires to pin 30 and one end of the loop wire to pin 85, Relay 2 connect other end of the loop wire to 87a, other +12v to pin 86, the constant ground to pin 30 and the door trigger to pin 85
    This is what it should look like
    6. A this stage put a 7.5/10 amp fuse in the in-line fuse holder and test the circuit out to make sure it works...hopefully it does
    Once you've made sure all is good and works tape up the wires and stuff to make it look neat and to stop the possibility of any shorting out.
    7. Then replace any parts you have taken off and place the relay's/wiring up inside the fuse panel area, i put mine here.
    8. Now clean up and admire your work!...lol
    Hope this covers everything needed to do this, if not and i remember anything ill add it here or if you feel ive left something out please let me know.
    Nick
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    good to see this is back. was going to use it before the tiwewarp/old host issues
    Body by Holden, Soul by Brock
    the Legend will live forever
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Just like to add that you dont need 2x SPDT relays, only one. You can replace the relay that connects to the accessorys with a SPST relay. which are a bit cheaper and found throughout the car.
    Power is measured in DECIBEL
    VE2 SS Voodoo
    Jul 2005
    yes vn6pwr is correct, you dont need two of the SPDT relays, just one will do fine and a standard relay aswell, i just bought two anyway
    you can also add a diode into the circuit on the ACC wire before where you have tapped into it which will stop the voltage going into the whole ACC wire and just keep it to the radio(i think thats right, either before orr after where youve tapped into it)
    Nick
    VE2 SS Voodoo
    Jul 2005
    also guys, you need to remember that when you have the car on then turn it off, if you start it up again without opening the drivers door the relays will still be latched on so the radio(and entire ACC circuit if no diode installed, but i dont have one in) will be on when starting(power drain), so juz have to open n close door to un latch it and its fine....you could prolly wire something in to stop that but not to sure
    Nick
    2006 VE Commodore Omega V
    Oct 2007
    Default TVS's
    Transcient Voltage Spikes. You have used metal can type relays that are not spike protected and this could cause probs with your electronics.
    The black plastic relays are usually protected with a resistor, diode or capacitor and there is a symbol on the cover of the relay to say as much.
    _/\/\/\_ Resistor
    -| |- Capacitor
    ->|- Diode
    VS III ute ecotec
    Aug 2005
    melbourne, suburbs
    Hi im having trouble with my setup i thought i followed the instructions but it works oposite, it turns off wen i close the door, if any1 knows why and how i can fix it it would help heaps.
    VE2 SS Voodoo
    Jul 2005
    VZ MY06 SS
    Aug 2008
    VE2 SS Voodoo
    Jul 2005
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    Ideally you want to actually use three relays and one diode so stop back feeding into the system. In regards to an earlier post about transient voltage spikes from when the coil in the relays discharges. It's not actually an issue in the acc line. I understand where you are coming from but all later models have this RAP module built into them. Older vehicles do not and are not canbus systems and are not bothered by the voltage spike. Whilst the spike is still there, since it has no current load on it when the coil shuts off it's not enough to do any damage.
    2004 vy exec S2
    Dec 2010
    ballarat
    this is also fitted on the s2 vy's. its one of the better features of the car
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    normally id be like: bah grrrrr THREAD DIG garble herp derp.
    but i have never seen this one b4 and i kinda like it thanks for the dig man
    VX II Calais 3.8 Ecotec HBD
    Feb 2012
    Sorry to post on this thread so late. Ive just completed this on my 2002 Vx calais. Everything works great except for the antenna. when the door is open the antenna comes down, then as soon as the door is closed the antenna goes back up. Also the antenna always stays up even if im using a CD (normally it would come down). I am also using the factory stereo. Any ideas would be appreciated
  15. #15
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Hmm subscribing for now.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
  16. #16
    VS Acclaim
    Oct 2011
    Crystal Brook
    Thanks for digging this thread haha. I might give it a shot this weekend... Always liked it on newer cars
  17. #17
    2004 VZ SV6
    Jan 2011
    Newcastle, NSW
    How would one go about having it setup for when the door is NOT opened before re-starting the car?
  1. Where is this thread? "Keep your radio on until you open the drivers door"
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2007, 04:33 PM
  2. Door will not open.
    By garfa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 09:36 PM
  3. cant open any other door except for drivers side!!! (VP Berlina)
    By brey9186 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2006, 06:24 PM
  4. How To Open Door
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-07-2005, 09:28 PM
  5. Help! Drivers door won't open
    By Boonie in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-06-2005, 09:59 AM
