Page 1 of 3 123 LastLast
Results 1 to 25 of 59
Like Tree1Likes
Thread: How to fix yellowing headlights
    rch-13z's Avatar
    rch-13z is offline im rick james..... bitch!
    VT Exec
    Jan 2008
    South-West Sydney
    Default How to fix yellowing headlights
    Are you headlights currently hazing over or going yellow? Well I have found a guide/product which fixes this problem.
    For months I wondered how I could fix this problem & actually was about to buy all the individual pieces required to perform this. In comparison my headlights are not as bad as some I have seen but I am very picky with this sort of thing.
    Just to give you an idea, below is what headlights looked like before I started.
    This is the actual kit I purchased, I found it through Autobahn but I am assuming you can pick from most car accessory retailers.
    Permatex - Headlight Lens Restoration Kit which includes:
    - 1 sheet each of the following grit wet/dry sandpaper (1000,1500,2000,2500 - Lower the number, the rougher the grit)
    - Soft Cloth
    - Plastic Polish (doesn't specify exactly what sort of polish)
    - Rubber Gloves
    Steps Required:
    1. You need to decide first of all how bad the damage is on your headlights, in my case the headlights where just yellow but not badly scratched so I didn't need to use the rougher grit paper. So I started with the 2000 grit paper.
    Soak the paper in water for a good 5-10 minutes just to make sure it is completely wet. Failure to do so can mean causing more damage to your headlight, making possibly worse than when you started.... Be sure to also wet the lens of the headlight to keep lubrication at a maximum.
    2. With your roughest sandpaper(lowest # grit, IE 1500) Rub the sandpaper in one direction IE. left --> right until you have a uniform finish and keep dipping the paper into water so you don't clog up the sandpaper.
    3. Re-lubricate the headlight and change the water which you dip your sandpaper into so make sure you don't contaminate the new paper. Then start to rub a higher grit sandpaper IE. 2000 in one direction again, this time top to bottom or visa-versa.
    4. Follow the same process again this time with a higher grit again IE. 2500 and change the direction in which you are rubbing the headlight again IE left ---> right again.
    NB: Make sure that you are regularly dipping the sandpaper into water to clear off any mass attracted by the sandpaper
    Also note, at this stage you will not see the headlight clear up.
    5. Clean the headlight with water and dry off with a clean cloth.
    6. Once dry, use a soft clean cloth + the polish provided & rub whilst applying pressure in a circular motion over the entire headlight. Once applied please allow the polish to dry. Once the polish is set rub the polish off with a clean cloth.
    7. If the lens of the headlight still hasn't cleared up, then re-apply step 6.
    8. If you notice any spots which have not cleared up, then re-polish these particular areas.
    And after all of this, it should look like this.
    All up this process took me between 30-45 minutes to complete and the kit cost about $30. I know it my case I completely happy with this outcome.
    Hope it helps guys, any questions please let me know.
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    good to see it works, sold a few of these at work, but no feedback from anyone to know how well they worked.(i havent tried them because my lights are still ok)
    nice write up aswell
    rch-13z's Avatar
    VT Exec
    Jan 2008
    South-West Sydney
    Quote Originally Posted by hakhawk View Post
    Cheers for that, hope it helps others, Speak to a lot of people who have the same dramas.
    I was just worried about attacking my headlights with sand paper...
    VY, S supercharged 2003
    Dec 2006
    Just use some cutting compound on a piece of cloth and rub it all away. The cutting compound is the same stuff used by the painters to do the buffing once the car has been painted.
    Works like a dream, and very cheap.
    rch-13z's Avatar
    VT Exec
    Jan 2008
    South-West Sydney
    Quote Originally Posted by XXFR View Post
    Thats good to know, and I am assuming be a lot cheaper if you need to re-do it too...
    Where as at the moment, if I need to re-do mine, I would need to buy the kit again...
    Cheers for the info mate...
    GAMBLR's Avatar
    GAMBLR is offline More trouble than u think
    '04 VZ Calais LS1
    Dec 2006
    Whyalla (yawn), South Australia
    a problem i currently dnt need to worry bout... good write up and discovery tho. should suggest it to my mate... or let him work it out lol'
    CC
    CruznCalais
    [GAMBLR]
    The VZ is here! About time!
    calaiscruzer's Avatar
    calaiscruzer is offline I drink beer, and I vote!
    Atlas Grey VN SS
    Sep 2007
    VIC
    Recently i just went down to local wreckers and 2 practically brand new headlight glass for $5, took a whole 10min to install.
    rch-13z's Avatar
    VT Exec
    Jan 2008
    South-West Sydney
    lol yeah that will do the job, unfortunatley with some of the newer models that would require a whole new headlight..
    Thats what I love about the VNs...
    Mar 2008
    always add some dishwashing liquid to the water for lubrication
    same applies when sanding paint
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    and ofcourse this would only work on plastic headlights.....
    cheers
    mat
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    rch-13z's Avatar
    VT Exec
    Jan 2008
    South-West Sydney
    Quote Originally Posted by johnnie5 View Post
    Quote Originally Posted by HoZy View Post
    cheers
    mat
    Cheers lads, it's good to know because I've gotta do my uncle's car soon!
    Mar 2008
    cheers
    mat
    dont think i have ever seen a glass headlight go yellow
    A Toyota?
    Nov 2008
    An easier way is cutting compound on a buffing wheel, metal polishes work well too. If you have neither, you can use toothpaste - it also has the benefit of leaving your headlights smelling minty fresh
    rch-13z's Avatar
    VT Exec
    Jan 2008
    South-West Sydney
    yeah but for dummies with no tools & no idea.... this product worked really well!
  15. #15
    VT Acclaim
    Aug 2008
  16. #16
    rch-13z's Avatar
    VT Exec
    Jan 2008
    South-West Sydney
  17. #17
    svsex is offline big blue
    190 sv6
    Jun 2008
  18. #18
    VS
    Oct 2008
  19. #19
    Vt-sam is offline Banned
    VT Commodore
    Aug 2009
    VT Executive S2
    Jan 2009
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
  22. #22
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Another good one to use is the Meguiars headlight restoration kit. No sandpaper needed and does an awesome job!
  23. #23
    Skidney's Avatar
    Skidney is offline Utes do it better.
    VP UTE
    Sep 2009
    Adelaide CBD
    i thought the headlights went foggy because of moisture on the INSIDE of the lens??
    93 VP Ute, V6 5 Speed
  24. #24
    Nov 2008
    Tullamarine, Vic
    Quote Originally Posted by Skidney View Post
    Yes, you are right, but the OP is not talking about foggyness. It's the yellowing of the headlights.
  25. #25
    99 VT Sedan
    Feb 2010
    Thumbs up
    Quote Originally Posted by rch-13z View Post
    - Soft Cloth
    - Rubber Gloves
    Steps Required:
    Sorry to sound stupit but you were doing all this to the outside of lens????
    If so i have a buffer just sand down with 2000 or 1200 sandpaper than buff it like i was buffing car sould do the trick???
    Thanks for your help
  1. Exec/Acclaim Headlights --> SS Headlights for $80 ...
    By nEb. in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-06-2011, 11:06 PM
  2. VT Headlights
    By James_1020 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-12-2006, 09:12 AM
  3. Headlights
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-06-2006, 11:21 PM
  4. VY Headlights
    By SimonH in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-01-2006, 07:21 PM
  5. Need new headlights
    By tonitrus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2006, 10:58 PM
Tags for this Thread
