Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: Removing VY/VZ door trim
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    Default Removing VY/VZ door trim
    Ok, i've been asked a couple of times and since i was doing mine today i thought i'd post up some pics and a rough guide to help people along.
    Tools required: small flat blade screwdriver
    Medium phillips head screwdriver
    Stubby phillips screwdriver
    1. Using your small flat blade, gently prise the red part of your doorlock towards you.At the same time pull up on the lock with your free hand until the lock slides free.Once it's out undo the screw and remove the lock trim.
    2.Still with your flat blade, pop out the screw cover on your door handle and unscrew the handle.Remove the handle, it's attatched to the rod so pull on the handle like you were opening the door and it will come free.Undo the screw behind the handle.This one is commonly missed so make sure you get it!
    3. Take the air vent off the top of the trim in the corner.It's held in by a plastic clip so gently free it by pulling it towards you. (If you break the clip don't panic, your local holden will more than likely give you one for free!)
    4. Unscrew the trim, there are 7 screws to take off.4 along the bottom, 2 on the outside and 1 on the inside, this one you'll need your stubby screwdriver to do.
    5.Your trim is almost off! Grabbing the bottom of the trim with your hand, pull it towards you so it comes away from the door.Then carefully lift the trim straight up towards the window, it should now be free.
    6. Rest the trim on something and use your flat blade to gently prise the mirror switch out of the trim.Unplug the switch and your trim is now completely free from the car!
    It should now look like this, ready to play!
    This is a guide and i take no responsibility for damage done if you're too rough or don't follow the instructions.Just take your time and you'll find it's quite easy.The guide i have supplied is based on the front drivers door with power windows.Anything that i may have missed please add it into this thread.Hope it helps.....
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Great thread Juzo! Sure to be a big assist to anyone who needs to do this. (done it myself more than I can count, but....)
    (Seeing as nobody else has replied, I thought I would....)
    As a side note, it's a very similar - if not identical - procedure for VT and VX as well, with the possible exception that you might have window winders to contend with.....
    (gotta lurve power windows!!)
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    Nov 2005
    Warrnambool
    Quote Originally Posted by Phreddy View Post
    Cheers phreddy, done it heaps myself now but a bit of a pain for the first timers so just hope it helps a few out.
    vy executive s2
    Jul 2008
    what about doors that have window winders not eletric windows how do you remove the winder?
    Nov 2005
    Warrnambool
    Quote Originally Posted by paynetrainvy View Post
    If they're like the older models there will be a clip that you need to remove. Use a flat blade screwdriver to pop it out by sliding the screwdriver between the winder and the trim, you should be able to see it.
    vy executive s2
    Jul 2008
    98 VT Executive
    Aug 2008
    Sunshine Coast
    thankyou very much for this thread
    I tried doing it and i coulnd't get it all off but i missed the screw in the black metal piece behind the door handle, so im pretty sure she'll fully come off now
    thanks again, you did a great job explaining, much appreciated
    POYTA's Avatar
    POYTA is offline Weresz me dog gone
    2006 VZ UTE my06 s
    Feb 2009
    Sunshine Coast QLD
    VY Equipe S2
    Mar 2009
    Great job mate. Just spent 2 hours fixing my power window thanks to you showing us how to actually take off the door trim. Always never knew there was the door handle and then behind that the clip for the door. Oh yer and i fixed my window lol. So thanks again mate for the help.
    VT SS 5.0 L
    May 2009
    great thread.....electric window models are always the easiest to pull out my VT SS has winding windows and those circlips can be a prick if you dont have the right tool
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by ikon5643 View Post
    Not really, I use a small old flat head with a slight bend in it, push the door trim in as you slide the screwdriver in behind the winder. Just take care to hold your free hand ready to catch the clip as it can FLY off!!!
    To put the winder back on slip the curclip back onto the winder first then push it in to the spline and give the winder a decent but gentle thump. All done!
    BANKS's Avatar
    BANKS is offline DW I'm a Spray Painter!
    VZ SSZ Ute
    Aug 2007
    Gold Coast QLD
    VY 5.7 S Ute
    Jul 2009
    Very helpfull!
    Quickest door panel removal I've done, thanks to this thread.
    Nov 2005
    Warrnambool
    Quote Originally Posted by BANKS View Post
    Juzo = legand!!
    This should be a sticky
    Cheers mate, sticky that bad boy
    Quote Originally Posted by lethalduck View Post
    Very helpfull!
    No worries, glad it helped you
  15. #15
    VZ SV6 SA5
    Feb 2009
    Renmark SA
    thanks a heap mate my first door panel removal went without a hitch! LEGEND!!!
  16. #16
    VY Exec
    May 2007
    real helpful tips, was able to use this today.
    One question, everything has gone back on, but i cant get the doorlock to clip back on. Any tips?
  17. #17
    VZ Berlina
    Dec 2009
    Dude thank you for the instructions.. i was able to install my leather door cards into my door trims with it
  18. #18
    Nov 2005
    Warrnambool
  19. #19
    VZ SV6
    Dec 2009
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by charliebrown069 View Post
    what size speakers are in the doors?
    What, stock? 6 inch, but 6 1/2s can be fitted with some minor alteration to the pods.
  21. #21
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    Quote Originally Posted by ADEM View Post
    I too am interested to know how to clip the door lock back on. Mine just slides up and down the threaded metal shaft and won't grip. I've put a small amount of kwik-grip on it to hopefully hold it on but not to be too strong so that it wont come off again.
    A Commodore is a passion. Anything else is just a car
  22. #22
    Nov 2005
    Warrnambool
    The red clip is buggered, that's what makes it grip to the thread. Drop into holden and pick up another one, $2 from memory and then you're set.
  23. #23
    DUK13Y's Avatar
    Nov 2007
    Sydney, Australia
  24. #24
    Nov 2005
    Warrnambool
  25. #25
    Vz Sv6 04
    Nov 2009
    Bundaberg
    thanks for this! will help when i decide the replace the front speakers and put leather into the door trim
  1. Removing VT/VX door trim
    By Julie in forum Holden Commodore How-To's
    Last Post: 13-10-2011, 09:35 PM
  2. Removing Door Trim
    By funnyfarmer in forum Car Audio
    Last Post: 21-08-2008, 04:12 PM
  3. Removing the door trim
    By f1tzy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-09-2007, 05:04 PM
  4. Removing door trim
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-12-2006, 03:01 PM
  5. Removing door trim
    By smyth in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-02-2006, 12:55 PM
