Results 1 to 14 of 14
Thread: Changing your brake pads
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    Arrow Changing your brake pads
    Tools- scissor jack
    wheel brace
    15 and 16mm spanner
    G-clamp
    Step1-jack up the car, remove brake master cylinder cap and remove wheel
    step2-use the 16 and 16mm spanners to undo the bottom half of the brake caliper, lift up the caliper and remove brake pads
    step3-using a g-clamp and one of the old pads, compress the piston on the caliper back in and lube if required
    step4-insert pads so the meat is facing the brake rotor and re-position the slide(this is the part that the bolt connects to), position the clips that are on the brake pads are correctly fitted in place.
    step5-do up the bolt firmly and let the car down (double check your work to be safe) and do up the wheel nuts........
    Its important to know that when applying pressure to the pedal first off NOT to go flat stick otherwise theres a good chance of blowing the master cylinder, press the pedal half way until it goes hard.
    Also when driving the car for the first time be aware the brake sare not going to pull you up very good until there bedded in, accelerate to around 60 and brake heavily, but smothly not coming to a complete stop, do this about 10 times and your brakes should be ready to go!
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Cheers for the walkthrough, I was going to get mine done professionally, but might have a shot of it myself
    I was only going to do my rears to start with, because I was told they've almost had it (I know the fronts do most of the work) but I had a coupleof questions
    is there any problem with doing rears separate to fronts, and what brand pad would you suggest for something not heaps expensive for my drilled slotted rear rotors?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Quote Originally Posted by pow3rslave View Post
    Silverline brake pads do a fine job at the back. Since the rears only provide such a small percentage of your stopping power, you don't have to feel bad using a set of $30 pads.
    Nothing wrong in doing the backs separate either. Not if you ask me, anyway.
    Just one note for people: When you've unbolted the brake caliper, and remove it from the rotor - PLEASE don't let it hang down by the brake line. It can cause the brake line to stress and split. Either use a folded coathanger to hold the caliper up, or balance it ontop of the rotor. I never leave my calipers unattended when they're off the car, just incase they fall and stress the brake line.
    Also, you may not want to leave your master cylinder cap off for the entire job. The less time you leave your brake fluid exposed to air, the less moisture gets into it, and the less often you have to bleed the system. I find I don't even have to remove the master cylinder cap to retract the caliper pistons.
    Nice writeup VNV8
    The 1972 HQ Kingswood
    VX Executive
    Aug 2008
    sorry guys i only know a little about cars but have a lot of tools and really need to save $$.
    How do u know where to repositions the slides to and what is the correct place for the clips on the brake pads?
    VZ AWD One Tonner
    Jul 2006
    If you're just after a standard pad, QFM Super X, or if you're after a bit of performance, QFM HPX. $40 and $79 respectively, and both low dust and low rotor wear.
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    VX Executive
    Aug 2008
    also another thing... i will probably sound really stupid but where is the brake master cylinder cap?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by boots_lacey View Post
    The correct place for the slides is where the pads go back over the rotors. As long as the piston is all the way in and the pads are seated, move the slide until the pads go over the rotor.
    For the clips, look at them as you take it apart, they are fairly straight forward. Keep one side assembled for reference.
    Visit my Facebook page
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Make sure you don't put one of your brake pads in the wrong way, or you might incur a slight braking noise and damage to the rotor...
    -The best way to learn not to do this
    LightningVP is offline Donating Member
    None
    Sep 2008
    ARGH I'm glad mine are done...should've used this How To....My way involved 2 broken ratchets :| lol
    304 Calais
    Aug 2007
    Up your mum
    None
    Sep 2008
    Quote Originally Posted by vnv8driver View Post
    as long as it worked mate thats all that matters
    lol yeah, after 2 trips to the shop advice for everyone: Unless you have a spare car, make sure you have EVERYTHING you need before you start...
    Morton's Avatar
    May 2006
    Next time use a breaker bar instead of your ratchet to loosen the bolts Grab a cheapie from Supercheap. My $15 breaker bar has saved me a lot of time and effort
    None
    Sep 2008
    All have brand new pads so will be a while lol (They have been there for ages, the stickers on them were starting to crack and go all weird from the pressure)
    VT
    Apr 2005
    QLD
    Quote Originally Posted by Morton View Post
    Newbies should be banned from using ratchets. I wasn't allowed to use a socket set until I was a 3rd Year Apprentice (that was a while ago now lol)
    Hand spanners all the way. I should mention too, use chassis stands when working on your car!! They will save you from being an amputee if the car moves with your legs under it.
    As for the guy who put the brake pad in backwards......................wow.
  1. QFM Brake Pads
    By gslrallysport in forum GSL RallySport
    Last Post: 08-05-2012, 09:10 PM
  2. changing rear brake pads
    By lizard199 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-11-2007, 06:48 PM
  3. Changing Brake Pads
    By COINERS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-10-2006, 11:53 PM
  4. Changing brake pads
    By me_011 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-06-2006, 03:56 PM
  5. Brake Pads
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-10-2005, 08:53 AM
