Results 1 to 10 of 10
Thread: Home made Suspension Bush remover
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    Default Home made Suspension Bush remover
    Tired of taking suspension arms to Pedders & the local garage to have bushes pushed out I knocked this up.Now i realise it ain't exactly a thing of beauty but it works a treat.Works on all suspension arm bushes including the diff bushes for which i originaly made it but the added bonus is it fits all.I chopped a 50mm piece of steel pipe off her gate post, she weren't real happy about.The diamater of the pipe is 53mm.I welded a plate on 1 end & drilled an 11mm hole in.Then i used a 160mmx11mm bolt, sum large flat steel washers, i used sum washers from an old VK old Raduis Rod.Put it on 1 side of the bush, the side which is tapered, start winding the nut & the bush extrudes out inside the pipe.Works every time.Hope it may help sumbody else as it saves lots of time & $$.For the 15mins it took me to knock it up it's already payed for itself...
    Attached Thumbnails Attached Thumbnails Home made Suspension Bush remover-suspension-bush-remover.jpg
    Tony 308vkcalais:
    VL gold 5 Speed manual RB30 1 Owner since NEW
    Sep 2008
    melbourne australia
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    yeh we have one of those. (not that particular one though haha)..was mad buy my grandfather when he worked at holden 25 years ago....works good
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    The idea has been around for a long time yes, but now it is in the HOWTO section where it belongs, heck if you look at my "HOWTO VR/VS radius rod bushes" thread I have a simple version of this there too (With credit given to who I got the idea off)
    I like that now anyone who browses this section (as it is a small section) is likely to find it.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    agree. Its about time someone made a how to for it, as its such a popular question on how to make a tool or, how to remove the bushes etc......now we can lead them to this thread
    Vp series 2
    Jun 2008
    ok 1 very important thing to remember you need something between the metal plates to stop them coming in and enlarging the holes.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by centy View Post
    that is very true....i found it out the hard way (when doing the lower control arms lol)
    Nov 2005
    yup 4got 2 mention i have a collection of diffrent lenghts RHS to use as spacers to hold the bush housings in position under the strain.I soak them in a bucket of old engine oil 4 a day or 2 b4hand.I have so many suspension parts & arms here i just remove the worn stuff & wack on arms I've reconditioned previously with new bushes in instead of fixing the one i've just taken off, but i have the room to store all this snot & sum ppl don't..
    Tony 308vkcalais:
    1993 VP Commodore Executive sudan
    Oct 2010
    Ingham N.Q.
    Quote Originally Posted by 308vkcalais View Post
    Hi, is that 53mm inside or outside diamater of pipe? and isit exactly 50mm long?
  1. What do you think of my home made pod box cai?
    By vnv8driver in forum V8 Development and Modification
    Last Post: 20-05-2008, 05:20 PM
  2. home made caravan
    By shonky12 in forum The Pub
    Last Post: 19-03-2008, 06:25 PM
  3. Home made cai
    By SKNOT9 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-01-2008, 04:10 PM
  4. home made bullbar vs
    By ringfeder3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2006, 10:04 PM
  5. Home Made intake
    By Phantom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2005, 06:41 PM
