Results 1 to 11 of 11
Thread: Removing srs/airbag
    S1 VR V6 BT1
    Mar 2008
    telarah
    Default Removing srs/airbag
    Removal of SRS system driver side only.
    DISCLAIMER.
    Removing the airbag or srs from a vehicle so fitted from the factory is ILLEGAL in nsw according to the RTA it will not pass blue slips, pink slips and may earn you a large red sticker.
    Ok, that's out of the way....
    I had a look at the compliance plates and rego papers, no where does it state that the car has srs except for the piddly little plate under the radio( that's on a BT1 anyway)
    SAFETY.
    PLEASE READ.
    The srs MUST be deactivated before any work is carried out.
    The airbag needs a radius if ONE METRE clearance all the way around incase of sudden inflation.
    Airbags are fitted to cars for your safety.
    THE AIRBAG CAN STILL INFLATE AFTER THE ELECTRICAL SYSTEM HAS BEEN DISCONNECTED CAUSING SERIOUS INJURY AND/OR DEATH, PLEASE BE ADVISED USE EXTREME CAUTION AND BE WARY OF AIRBAG AT ALL TIMES.
    I DO NOT CONDONE OR RECOMMEND THIS TO ANYBODY.
    DEACTIVATING THE ELECTRICAL SYSTEM
    PLEASE READ SAFETY SECTION FIRST
    1. Turn ignition off and lock steering wheel, remove key.
    2.remove beaver panel from underneath steering column, there is a small lug on the left hand side at the back, use a flat blade screwdriver and/or a pair of pliers.
    3.remove fuse number 18 (for VR/VR may be different in other models)
    4.disconnect airbag wiring loom connector, its under the steering column and is yellow in colour.
    REMOVAL OF AIRBAG
    1. Remove the 4 torx head screws that attach the horn pad and airbag.
    2.VERY CAREFULLY remove horn pad and air bag assembly away from the steering wheel, disconnect the airbag wiring harness. BE EXTREMELY CAREFUL THE AIRBAG CAN STILL DEPLOY WHILE ELECTRICAL SYSTEM IS DISCONNECTED, I RECCOMMEND HAVING THE DRIVERS DOOR OPEN AND ANGLING THE AIRBAG OUT TOWARDS THE DRIVERS DOOR AND STAYING AS FAR AWAY FROM IT AS POSSIBLE.
    3.Gently lift airbag and horn assembly away from steering wheel and out of vehicle.DO NOT THROW INTO THE BIN PLEASE DISPOSE OF PROPERLY IT IS STILL DANGEROUS.
    SENSOR REMOVAL
    1.Remove the front seat by removing the bolts attahing it to the floor.
    2.remove the 2 screw in the sensor cover.
    3. Disconnect wiring loom from sensor unit.
    4.remove sensor unit from floor pan.
    REMOVING SRS STICKER.
    1, use a screwdriver or something.
    Residual glue can be removed using goo off or something similar.
    This is normally done to add a sports or aftermarket steering wheel, usually people just remove the airbag and cover the airbag light with black tape.
    Using the method I have described here should fix this problem. Although please remember it is ILLEGAL but that doesn't make it any less cool.
    My Ride:
    '94 VR V6 BT1. 15" roh with 225's, stocky with bellmouth removed, OTRCAI, homemade airfilter, B&M Stage1 shiftkit, .490 boost valve. Corvette servo.
    Lappy runnin EFILive in a semi stock interior.
    WANTED: VN/VP/VR/VS Standard
    Memcals.
    WANTED: Standard front bar from VR/VS. Prefer alaskan white but will take anything.
    Newcastle/Maitland/Central Coast.
    Email me
    hyp3r4l3rt@hiptop.com.au
    vs executive II
    May 2009
    BRISVEGAS
    any1 kno where 2 get torx bits to undo the bolts at the back of the steering wheel when removing the airbag? i looked in supercheap but couldnt find them any help is needed
    vs executive II
    May 2009
    BRISVEGAS
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I wonder how long this will stay here considering it is ILLEGAL.
    Visit my Facebook page
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Didn't look at the dat of the original post. I wonder why it's still here?
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    This is very good info. If you are at the wreckers and you want to take the wheel off which has the airbag on it, now you'll know how.
    vs executive II
    May 2009
    BRISVEGAS
    and its actually not illegal.. checked up with queensland transport and since the drivers airbag was optional in the vs it is legit 2 take it off
    GAMBLR's Avatar
    GAMBLR is offline More trouble than u think
    '04 VZ Calais LS1
    Dec 2006
    Whyalla (yawn), South Australia
    dunno why you would've been told it's ok mate. I'm fairly sure the VS was the first model to introduce the driver's airbag standard on the Exec (although i might be wrong). In any case, if the car rolled off the factory floor with airbags, it is ILLEGAL to remove them. same as all other safety features
    which is what the OP has said
    CC
    CruznCalais
    [GAMBLR]
    The VZ is here! About time!
    DeiCide's Avatar
    DeiCide is offline DeiCide
    VT
    Jan 2006
    nah my series 2 VS executive didnt have any airbags, and was a 1997 model.
    VT onwards had to have airbags
    GAMBLR's Avatar
    '04 VZ Calais LS1
    Dec 2006
    i knew it was one of them. thanks for clearing that up DeiCide
    CruznCalais
    [GAMBLR]
  1. removing srs/airbag
    By VRV6BT1 in forum Holden Commodore How-To's
    Last Post: 17-10-2008, 08:57 AM
  2. Removing Unused Airbag Cover
    By Bundy_Wal in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-08-2006, 09:57 PM
  3. Removing VS steering wheel wit airbag??
    By Holdenboy_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2006, 06:02 PM
  4. Removing steering wheel with an airbag?
    By aa23 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2005, 04:26 AM
