"How To" Remove Door Card & Speaker Grill on VT-VX *Detailed*
Ozzie
JCCC Warrnambool
Warrnambool
Ozzie'z Supercharged VY Calais
How To Remove Door Card & Speaker Grill VT-VX Commodore *Detailed*
For those of you who can't seem to get to the speaker grill in a VT or VX, I have writen up this detailed guide for you.
Alot of people search for detailed descriptions on this "how to" with no luck and they end up starting a new thread asking how its done.
Ok lets get streight into it shall we.
First of all you will need a few things.
* 2 x Philips Head Screwdrivers. (1 long and 1 stubby)
* 1 x Flat precision screwdriver. (can be anything similar like a knife)
* 1 Rag or cloth of some kind.
* 1 x pair needle-nose pliars.
Step 1.
First open the door that you wish to work on.
In this case I have used the drivers door as an example. Reason for this is that it has the electric mirror switch.
_____________________________________________________________
Step 2.
Grab your precision screwdriver and unclip the door lock like so...
It will then be able to pull out easily.
Step 3.
You will notice the screw is highlighted below. Undo it using your philips screwdriver.
The lock casing should easily lift out like so....
Step 4.
Grab your precision screwdriver again, and unclip the plug inside the door handle as seen below.
You will then notice the screw behind the plug.
Using your philips head screwdriver, unscrew the door handle.
As you pull the door handle you will notice that it is attached to a metal rod. A gentle twist will un-snag it.
Where the door handle was, You will see a screw behind it.
Unscrew it using your philips screwdriver.
Step 5.
Time to remove the window winder.
Grab your rag or cloth and slide it behind the winder like so...
Move the cloth side to side to get a grip of the pin behind the handle.
The clip will pop out like so..... And you can then pull on the winder to remove it.
Step 6.
Now its time to un-screw the outer screws on the door card. The detailed pics below highlight the screws where necessary.
Step 7.
Now we need to remove the vent cover as pictured below.
A slight pull from the back outward will un-clip it.
Step 8.
Pull the bottom of the door card out (all the way round) and then slide it up until its free.
Before you can totaly remove the card, you will need to unclip the mirror switch.
Ok so now the door cards off. Remember this bracket as pictured below because you will need to match it up with the door card clip when re-installing.
Step 9. - Removing the Speaker Grill.
On the back of the door card, you will notice a few clips and a screw as highlighted below.
Grab your flat screwdriver and pry the clips off carefully.
You will end up with 6 clips and a screw at the end (Back doors have no screws) The grill will then slide out.
Most important thing is that yu remember how it all came apart. Basically reverse all procedures to re-install the grill & door card.
Dayvo
Because i can
67
South East,Victoria
VE SV6 Series 2
Nice write up Ozzie . Just like to add one thing, when puting it all back together. Make sure that you clip the door trim up under this bracket first before fitting trim to the top of the door .If you don't do this you can end up with a window that rattles when fully wound up .
nicko
Carbon Positive - DO IT!!
sa
75 cruiser ute
Cheers ozzie, just about to rip mine off big help mate :D
HVXII
AWI11
brisbane upper kedron
2002 VXII Acclaim storm grey
so do u put the door cards back on with out the speaker cover on it??? any pics of that??
HVXII
AWI11
No, this is a guide on how to remove them.
If you have cracked covers that need replacing then this thread should help.
I just did it to paint mine.
ahhhh ok awesome
Blocka111
VT Commodore Wagon V6
Nice 'How to' Ozzie. I have to fix/replace my window mechinism in my VT.
Thanks for taking the time.
tbrown89
VS Executive
does any one know how to get the door locks back in? cant seem to get mine working properly
