Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: "How To" Remove Door Card & Speaker Grill on VT-VX *Detailed*
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Thumbs up "How To" Remove Door Card & Speaker Grill on VT-VX *Detailed*
    How To Remove Door Card & Speaker Grill VT-VX Commodore *Detailed*
    For those of you who can't seem to get to the speaker grill in a VT or VX, I have writen up this detailed guide for you.
    Alot of people search for detailed descriptions on this "how to" with no luck and they end up starting a new thread asking how its done.
    Ok lets get streight into it shall we.
    First of all you will need a few things.
    * 2 x Philips Head Screwdrivers. (1 long and 1 stubby)
    * 1 x Flat precision screwdriver. (can be anything similar like a knife)
    * 1 Rag or cloth of some kind.
    * 1 x pair needle-nose pliars.
    Step 1.
    First open the door that you wish to work on.
    In this case I have used the drivers door as an example. Reason for this is that it has the electric mirror switch.
    __________________________________________________ ___________
    Step 2.
    Grab your precision screwdriver and unclip the door lock like so...
    It will then be able to pull out easily.
    Step 3.
    You will notice the screw is highlighted below. Undo it using your philips screwdriver.
    The lock casing should easily lift out like so....
    Step 4.
    Grab your precision screwdriver again, and unclip the plug inside the door handle as seen below.
    You will then notice the screw behind the plug.
    Using your philips head screwdriver, unscrew the door handle.
    As you pull the door handle you will notice that it is attached to a metal rod. A gentle twist will un-snag it.
    Where the door handle was, You will see a screw behind it.
    Unscrew it using your philips screwdriver.
    Step 5.
    Time to remove the window winder.
    Grab your rag or cloth and slide it behind the winder like so...
    Move the cloth side to side to get a grip of the pin behind the handle.
    The clip will pop out like so..... And you can then pull on the winder to remove it.
    Step 6.
    Now its time to un-screw the outer screws on the door card. The detailed pics below highlight the screws where necessary.
    Step 7.
    Now we need to remove the vent cover as pictured below.
    A slight pull from the back outward will un-clip it.
    Step 8.
    Pull the bottom of the door card out (all the way round) and then slide it up until its free.
    Before you can totaly remove the card, you will need to unclip the mirror switch.
    Ok so now the door cards off. Remember this bracket as pictured below because you will need to match it up with the door card clip when re-installing.
    Step 9. - Removing the Speaker Grill.
    On the back of the door card, you will notice a few clips and a screw as highlighted below.
    Grab your flat screwdriver and pry the clips off carefully.
    You will end up with 6 clips and a screw at the end (Back doors have no screws) The grill will then slide out.
    Most important thing is that yu remember how it all came apart. Basically reverse all procedures to re-install the grill & door card.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Nice write up Ozzie . Just like to add one thing, when puting it all back together. Make sure that you clip the door trim up under this bracket first before fitting trim to the top of the door .If you don't do this you can end up with a window that rattles when fully wound up .
    Attached Thumbnails Attached Thumbnails "How To" Remove Door Card & Speaker Grill on VT-VX *Detailed*-step14.jpg
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    LOL thanks Dayvo. I added the bracket pic to give that impression but I missed that part
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    Cheers ozzie, just about to rip mine off big help mate
    no longer a hoon by association - the commodore is gone
    HVXII's Avatar
    HVXII is offline AWI11
    2002 VXII Acclaim storm grey
    Jan 2006
    brisbane upper kedron
    so do u put the door cards back on with out the speaker cover on it??? any pics of that??
    Ford Escort me to a Holden dealer.
    GO drive on australia
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    No, this is a guide on how to remove them.
    If you have cracked covers that need replacing then this thread should help.
    I just did it to paint mine.
    HVXII's Avatar
    Jan 2006
    Quote Originally Posted by Ozzie View Post
    ahhhh ok awesome
    VT Commodore Wagon V6
    Aug 2009
    Nice 'How to' Ozzie. I have to fix/replace my window mechinism in my VT.
    Thanks for taking the time.
    rch-13z's Avatar
    rch-13z is offline im rick james..... bitch!
    VT Exec
    Jan 2008
    South-West Sydney
    Nice one, need to do my father-in-laws one.. was just afraid to break those tabs....
    Assuming the material part on the door card has the same sort of tabs?
    VS Executive
    Aug 2008
    does any one know how to get the door locks back in? cant seem to get mine working properly
    LthlThrt's Avatar
    LthlThrt is offline Chef Jay in Port Douglas
    02 VU II SS
    Mar 2009
    Port Douglas
    Quote Originally Posted by tbrown89 View Post
    there is a little metallic rod that comes up through the opening where the locks belong just sloowly slide your lock over the rod and you should feel it slide down then when it is as far as it can go just pust in the red bit and badda bing badda boom. sounds complicated but once you've changed your speakers enough times it is like second nature lol. best of luck
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    If you've tried using this guide and you still cant get it on, i suggest looking to see if the rod for the door lock is bent, or if you are actually getting the door trim on right, if the trim is out of place, you wont be able to get the lock on the rod, even though you can screw in the surround and what not, it wont stay on.
    check those things and give it another go
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    That trick with the cloth to remove the Jesus clip is effing brilliant!
    I haven't lost my mind, it's backed up on tape somewhere
    vy executive
    Jan 2010
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by s_ikari2015 View Post
    Cheers but i cant take the credit for it. I got it off this forum from another member (cant remember who used it) who probebly had the idea passed to him ect...
    Definetly effective though.
  16. #16
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Default Great work.
    @ Ozzie
    Thanks mate, I've got to change out the speakers in mine (too old and buggered). This thread was very helpful.
    Again, thanks.
  17. #17
    VZ SS
    Dec 2009
    Is there a trick to those little metal clips for the grill? i really had to work them to get them off and now they wont go on. Any ideas?
  18. #18
    VZ SS
    Dec 2009
    Quote Originally Posted by SS245 View Post
    I just answered my own question. If you use a pair of side cutter and snip the clip just in one spot it lets it expand just enough as you push it down it fits nice and snug. It holds it pretty tight as well.
  19. #19
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
  20. #20
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    ok well i went and put a tool to remove them for 10 bucks so meh all done GREAT how to thread very detailed.
    Ill add something ozzie didnt in the rear door grille there is 7 clips not 6 and no screw.
    thanks very much mate went off with out a hitch this should be changed to VT, VX, VY. VZ
  21. #21
    VX S pack
    May 2010
    hey would this be the same procedure for auto windows because i am about to remove my trim because my window of the frivers side has managed to come completely off the rails but the motor still brings the rails up and down
    sso if its the same this post is a great help
  22. #22
    LthlThrt's Avatar
    02 VU II SS
    Mar 2009
    Port Douglas
    it is simpler, you dont have do worry bout the winder, just be carful of the electrics, had the same problem w/ my VT a few months ago, ended up welding the rails together, works like a dream
  23. #23
    VT Commy
    Mar 2010
    Adelaide!
    How long does this take, i was thinking of getting a start on this whilst the folks are out today.
    EDIT: This window winder is being a B***h!!! any tips?
  24. #24
    VT Commy
    Mar 2010
    Adelaide!
    Sorry to double post,
    Had a go at this myself, Dissassembly was going smooth until i got to the vent cover trying to remove it (slowly) and the clip happens to snap..no biggie i can fix this with industrial strength super glue ( I couldn't) and so i continue and everything goes smoothly. Re-assembly was fantastic all i had to do was put the door lock back on...but it wont go on... the lock case was fine the rod-thing? wouldn't go in properly so i spent hours trying to fix it all to no avail, so now my car has no door lock. Thankfully it still functions properly, i can still lock and unlock the car, however it looks like the rod that goes into the button/case is slightly bent and is the cause of all this trouble. Am I able to replace it??? To make things soooo much better I happened to drop my precision screwdriver, it happened to fall into the lock case, right between the hole and fall somewhere into the door card. So i will have to spend another day taking it all apart and fixing it again -_- /end rant
    EDIT: FIXED IT! WOOOOOOOOOOOOOOOOO!
  25. #25
    2001 VX Commodore
    Feb 2011
    Sydenham
    if only it was that easy, i sat there for an hour with a pin tool prying each little tab up in the clip until it came off. you'll find some come off easy with a flathead screwdriver and others NOT!
    by the way if your REALLY anal about little damages in your car(like me) i recommend drilling a tiny holy in the orange tab on each door lock (step 2) rather than sticking something flat in and prying it out because chances are you'll leave tiny marks. atleast with the tiny hole its neat incase you wanted to leave it or you could buy new orange tabs without having to buy the whole plastic lock
    good post though i'd be completely lost without it
  1. Replies: 47
    Last Post: 10-10-2008, 02:51 PM
  2. Please remove thread "Please ignore post"
    By colk in forum Site Feedback / Site Problems
    Last Post: 10-11-2007, 10:45 AM
  3. Where is this thread? "Keep your radio on until you open the drivers door"
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2007, 04:33 PM
  4. VT II Acclaim wagon door and tail gate "creaks" when going over bumps.
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2006, 11:11 AM
  5. What is "Q" in reference to a speaker?
    By shaggerz in forum Car Audio
    Last Post: 04-10-2005, 03:33 PM
