Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: How to stop a VN-VS seat from reclining automatically while driving.
    VP Exec
    Jun 2005
    Default How to stop a VN-VS seat from reclining automatically while driving.
    The seat creeps back because the the little piece of foam rubber that acts as a brake has deteriorated. The foam can (or not, if it has disintegrated) be found behind the seat recliner knob.
    The fix will cost you nothing and takes about 5 mins:
    You need a gasket scraper (or perhaps a wood chisel), a pair of outside circlip pliers, a blade or knife and an old VN-VS live axle anti-roll bar link rubber. You could get creative with something other than the link rubber. Something like a piece of an old computer mouse mat or stubby holder would do.
    Use the gasket scraper to lever out the centre cover from the recliner knob (if you are careful you won't mark the cover or knob) then push the circlip pliers into the split in the recliner knob to spread it, allowing you to pull the recliner knob off the seat.
    Again use the circlip pliers to remove the circlip holding the recliner knob "brake" and retaining washer and remove any remnants of the foam still left.
    The "brake" can then be replaced with a slice of the link rubber (or mouse mat foam) as thick as you can use while still being able to push the washer on and get the circlip back into the groove - about 5mm give or take. Thicker will make the seat harder to adjust, too thin won't work.
    Then put everything back together. Easy.
    To cut the centre hole neatly out of whatever material anyone decides to use, a short length of suitable diameter pipe can be sharpened on one end using a a grinder (or I guess with a file if you like hard work) to make a punch.
    (Photos courtesy of 88GreenVN.)
    Attached Images Attached Images
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    good write up, but can you put bigger pictures up...cant see exactly whats going on with the small pics before i go and attack my seat.
    thanx,
    George
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    seat winding itself back! Can I tighten?
    Here are the bigger photos
    Attached Thumbnails Attached Thumbnails How to stop a VN-VS seat from reclining automatically while driving.-bits.jpg   How to stop a VN-VS seat from reclining automatically while driving.-circlip-.jpg   How to stop a VN-VS seat from reclining automatically while driving.-new-washer-.jpg   How to stop a VN-VS seat from reclining automatically while driving.-shaft.jpg   How to stop a VN-VS seat from reclining automatically while driving.-temp-mouse-pad-washer.jpg   How to stop a VN-VS seat from reclining automatically while driving.-winder-.jpg
    Last edited by 88GreenVN; 16-01-2009 at 01:59 PM. Reason: Added deleted photos again
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    88GreenVN's Avatar
    Jun 2006
    OK just did this repair while the seat was in the car. Took just over 10 mins to have the seat fixed. That included making the new foam (mouse pad) washer.
    One hint: when installing the circlip back use multi grips to hold the shaft out while using a screw driver to nudge the circlip into its grove.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    I will definately have to do this mod to my SV5000 seats as they recline quite easily over bumps, sometimes the passenger seat will go right back if no one has sat in it for a while.
    SW.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Surfwagon View Post
    SW.
    Yep do it - I'm glad I have - on 4 seats now - winner every time
    V8 WH
    Nov 2007
    East Melbourne
    VPcalais87 is offline CNBNVS
    VP Calais 5.0
    Mar 2009
    Mill Park, Victoria
    This is great guys. I can now prove to the mrs that "NO ONE ELSE HAS SAT THERE, IT MOVES ON IT'S OWN - I swear!" Can't wait to fix this. Thought I was going mad having to put both front seats up all the time! Glad it's not just me! Cheers
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    What about a when the winder thing just spins around and dosent move the chair at all?
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by mischa View Post
    Just replace the plastic winder. It can "go round" on the shaft as the wider is plastic and the shaft is hardened steel. Steel wins over plastic
    and 3 Dangerous non ABS VN's
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    No shit, Thats whats happening...
    I wound my seat up the other day thinking, hmm i don't remember setting it like this, thought the mrs might have moved it or i did cleaning, thought nothing of it, It keeps happening, Started asking my old man, Mum etc. about it, all to the same reply.."No, why would i do that...." I was so tripped out i thought someone was ****ing with me..
    Good to know i shall fix
    Ben
    There is no such thing as stupid questions, Only stupid people.
    VN Calais S2
    Sep 2009
    Melbourne West
    Quote Originally Posted by VPcalais87 View Post
    lmfao
    great how too, should save many a marriage hahaha
    PietroChocko is offline Nurses do it better.
    Was a VN Executive 5.0, but now a Ford Laser Auto.
    Sep 2009
    <RaBBiT>'s Avatar
    <RaBBiT> is offline Follow the White RaBBiT>>
    95 VS Berlina 5.0,VN Wagon 5Spd 5.0L
    Nov 2007
    [SA]
    nice one thanks for this
    If Barbie's so popular, why do you have to buy all her friends?
  16. #16
    VS SS 5.0 Manual
    Dec 2009
    Used to have to give my seat a wind up every 6months.
    Seems I have to give it a half turn every week these days, so this will have to be done next weekend!! (have just finished the Dash LED upgrade today!!!)
    Yay. I likes my car. Does you?
  17. #17
    vs
    May 2010
    Thank you for this information. I pulled my seats out and could not figure out how the reclining worked, again thanks alot
  18. #18
    VP Calais '93
    Mar 2006
    SA- NE BURBS
    I used this guide the other weekend and it seems to be working for me so thanks again Cheap6 and 88green!
    wtb: rockford fosgate sub rfp 3412
  19. #19
    VE 3.6 Calais V
    Jun 2010
    South East Vic
    just followed the instructions on here. I think its worked. I only did one seat, will take her for a spin to make sure its done properly before I do other seat, then other car. great info.
  20. #20
    JazzyJezza77 is offline Jezza
    vr berlina
    Feb 2009
    1997 VS Esteem
    Jan 2007
    Well I'll be buggered. Just lately I've had to wind the seat a couple of times a week. Good to know it's not just me.
    cheers mate !
  22. #22
    vs ute
    Mar 2007
    still trying to get the plastic plug out of the seat recliner wheel, seems like its stuck in????
  23. #23
    calais
    Feb 2009
  24. #24
    vs commodore
    Aug 2011
  25. #25
    Jan 2007
    sorry to bring this up from the dead, but i looked at fixing mine today and couldnt get the recliner knob of in the pics looks like its got a circlip but how the hell do u get it off??? i couldnt even see the circlip behind there
  1. cooling fan doesnt automatically cut in
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2006, 11:55 AM
  2. VS indicating automatically
    By bobza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2006, 05:18 PM
  3. changing automatically
    By Tom04 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2006, 08:36 PM
  4. reclining front seats
    By vkberlina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-08-2005, 11:09 AM
  5. Indicators dont go off automatically
    By Trewman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-01-2005, 06:56 PM
